| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
#21 | |
However, Matt, you should get the Logo700, so I can take it around the block ![]()
Marshall |
#22 | |
T-Rex 450 V2 HS-65 MG's, Quark/9257 Logo 500SE VBar - Scorpion 4020-1100, Jive 100LV, DS610's, BLS 251 |
#23 |
While I like the looks of the Rave ENV I think it will be quite porky.
#24 |
The Rave ENV is designed as a nitro, then electric, extremely difficult to optimise structure for both power source. Henseleit did quite good with the MP line.
Michel Cote |
#25 |
RCH reports this:
The approximate delivery times of these new items are as follows. • LOGO 600 SE April 2010 • LOGO 400 Carbon May 2010 • LOGO 500/600 Carbon Chassis May 2010 • VBar Plug and Play April 2010 • Governor and Logfile Software mid 2010 There is much talk about the new LOGO 700. This model is still under development. They plan to bring it into the market in the second half of 2010.
Blade MCX, Blade MSR, Protos 500, 600ESP, 700E Last edited by harrier808; 03-12-2010 at 10:01 PM.. |
#26 |
Hi!
Just got the info that all of these dates will be delayed by 2 months... -Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-DJI-F550 |
#27 |
It seems like that the 700 would not be till end of year or early 2011???
#28 |
There was no note about the 700... I thought I could get the new belt for my little 700 before my next "inspection".
-Klaus
#29 |
Was looking forward to the 600se next month .
That's a bummer. |
#30 |
Convert your own, there is not much to it
#31 |
Yeah i'm thinking about it.
#32 |
I want to see some Logo 700 spyshots! I can't wait to see how it looks. I want one so bad!
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!! No helis right now! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Maybe I'll be back in another year! |
#33 |
I have a T700LE-E. With 12S 5000, Jive 80HV, 8.4V to servos with AR7100, 4035-500 motor, 16/164 gearing.
The weight is 5.35kg with 2800mah TX lipo and 5.2kg without it. Both my nitro fbl and my electric fb has hs 1950. The electric has power, but not any impressive power. If you want to feel the power, i would go for a logo. I want the big size instead.
#34 |
That is a heavy heli! All my 90 electric 4.5KG and 4.1KG! 4.5KG is just right.
Someone will fly a real logo 700 at the 3DM. |
#35 | |
I'm planning to get a 700 size electric this year. Can I run everything off a Jive 120HV or should I use a seperate 2s LiPo for the rx?
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos |
#36 | |
I can save about 145gram by removing the RX lipo.
#37 |
Well, itīs the fat pig, Trex 700
#38 |
Are you confident the JIVE's BEC can power the rx + servos safely in a 700 size machine?
#39 |
I like the decreased weight of a integrated BEC in a 600 (of course with small buffer), but it makes sense to use a separate power source for 700+ machine. A stretched Logo 600 with 4kg+ sound quit heavy for me. A 600SE configuration with Jive, small buffer and light components would be 3,8kg (heavy batteries) or less.
-klaus
#40 |
Not with master connection. I heard that you must use the slave also when using 8717 servos.
