| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
#41 |
You mean the slave connection must be buffered with a seperate battery or just connect both master and slave connections to power the rx in parallel?
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos |
#42 |
Its much better to use 2 cables with the jive and if you like also a buffer pack, or just set the BEC to 5.6V and there will be no problems.
I have TDR/MPXLE/Stretch logo all on 12S. |
#43 | |
How do you wire up the buffer pack when using both cables to power the rx?
#44 |
Just plug a buffer pack into any spare channel in the RX.
The 5.6V is a good number because once you have savox or 8717 servos etc or high current draw servos the back emf created can be a higher voltage than its output and so the BEC circuit shuts off, kontronik released a statement about this.\ On 5.6V no problem, on 6V its a problem. Unless you run BLS servos then 6V is no drama. |
#45 | ||
BUT NOT ON THE AR7100/AR7100R RECEIVER! It will burn.
#46 | |
#47 |
I have yet to buy the rx for my Logo 700. Which Spektrum rx would be best for 6V with Jive, master, slave + buffer pack? Which would be best for 2s lipo and HV servos?
#48 | |
Jive, master, slave = No 2S lipo. An uregulated receiver. I donīt know if you can use a step down with lipo.
#49 | |
It depends, if you want to use the BEC with no buffer pack its fine on 5.6V for 8717 etc or 6V for BLS servos. You will not notice a .4V drop in voltage, speed is not king with vbar so do not worry about that. If you want convenience use the internal BEC, if not use a buffer pack with it or a 2S lipo by itself. The way I see it adding a buffer pack with a BEC is like running one with a 2S lipo, anything can fail at any time. |
#50 |
As much as I like a chat, this topic is about the release date for the Logo 700. The last two pages are mostly covering BEC's.
I would like info on the release date please.
Regards, Jayson Logo Xxtreme 800 Silverline, Pyro 800-40L, Kosmik 200A, 14S, 157 & 256 @ 8v Logo 600SX, Silverline, Pyro 700-45L, Helijive, 12S, 272 & 256 @ 6v, 623, 105 Logo 400SE Mini Vbar, Mini Pyro 20-08, Jive 80+HV, 6S, 9660A+ 8900G @ 6v |
#51 |
2nd half of the year, there will be a german pilot flying the L700 at the 3DM, so until then we won't know much most likely
#52 | |
Sorry right now there is no release date or ETA.
#53 |
maybe start a sticky on setup logo 700?
0utrage fusion 50, hk-4025 630kv scorpion.12s, v-bar, kontronik, Sponsored by hobbymaniac Proud to be a Maniac! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#54 |
Not until gear ratios are known.
#55 |
Not to mention blade length, weight, battery compartment size and ... just about everything!
#56 |
Yup exactly, and HONESTLY I do not know anything of this model, I wish I did but it is all pretty hush hush on this one.
#57 |
The outline I got was that it will be huge, can take way more power than what's common, it's a 3D machine... and btw it will fly straight ahead too
![]() Of course that doesn't say much... and I'm eager to see one in the air or better in my fleet -Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-DJI-F550 |
#58 |
14s 5000 packs , hummm ! that would do it.
#59 |
#60 |
You can always give it to me if you don't really want it
