Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 03-02-2010, 10:18 PM   #1
Don McCullough
Default How to Convert Blade SR Tx to Mode 1
Today I got a Blade SR (sucker for new cool-looking helis). Only problem is they don't sell the transmitter as mode 1. Being lazy, I did not want to set up my JR X9303 for the first flights -- so, I dug into the TX to see if I could convert it.
It turns out it is very simple, no soldering. Just swapping out two switches, swapping two plugs, and relocating the ratchet and spring/lever parts is all you need to do. While you are at it sand smooth the plastic where the ratchet matches.
The only hard part was putting the spring on the lever. I used thin solder wire to hold the spring in place using tension and to hook onto the tension hook. This took about four tries. Alternately you can loosen the two screws on that side of the left stick to get access. Note, the plugs have small clips that need to be loosened.
No other changes were needed, all servos worked the same.
Good luck,
Don
Name:	Mode 1 ModA - cropped - small.jpg
Don McCullough is offline        Reply With Quote
Old 03-03-2010, 12:37 PM   #2
SCFarm
Nice!!! Good job finding your own solution!
I would change the title of your thread, if you can, to say "HOW TO convert blade SR to Mode 1". When I first saw it I assumed you were looking for some guidance on how to do that.
SCFarm is offline        Reply With Quote
Old 03-03-2010, 03:43 PM   #3
Don McCullough
Thanks ... done.
Old 03-04-2010, 07:34 AM   #4
Nothings4ever
Forgive me for my complete newb question.... but what is the difference of how it comes and mode 1?? Thank you!
Nothings4ever is offline        Reply With Quote
Old 03-04-2010, 08:25 AM   #5
lostoften
Its reversed in the sticks. See the manual, it gives detailed pictures.
Blade MCX, Trex 450 SE V2, Blade MSR, Blade SR, Blade SR 120
Planks: FlyZone Cessna 180 Skylane, HobbyZone Champ
lostoften is offline        Reply With Quote
Old 06-26-2010, 03:13 PM   #6
BENJY D
Hi Don,
I mistakenly bought a mode 1 instead of mode 2 and trying to convert the opposite way round (and am a complete newb to electronics!) I have 2 questions that I hope you can help with.
1 - Would the conversion work opposite way round?
2 - The back of the sticks seem to have a completely different set-up and requires moving the whole section not just the ratchet/springs set-up. Am I overcomplicating things?
3 - Do you have a higher resolution pic of the conversion you could post?
Any help gratefully received......
Thanks in advance for your time,
Ben.
BENJY D is offline        Reply With Quote
Old 06-26-2010, 03:46 PM   #7
BENJY D
Figured out the ratchet and springs..........
Ben
Old 06-26-2010, 06:10 PM   #8
Don McCullough
Cool, the ratchet and springs are the hard part. Just flip the switch and optionally relocate switches if needed.
Old 06-26-2010, 09:55 PM   #9
cedron
Do not sand it. Instead put a small piece of fuel line tubing there instead. I did that and it works great.
cedron is offline        Reply With Quote
Old 06-27-2010, 03:51 AM   #10
BENJY D
Thanks very much Don, all converted!
Now I believe the fore/aft cyclic has a short - (great).............
(and stuck in the middle of countryside with NO hobby store close by.)
Servo is continually rotating at high speed soon as connect batttery. Tried taking the casing off the servo to see if anything 'looks' wrong or broken but no joy (in my limited knowledge.) Any ideas?
Thanks again,
Ben
Old 06-27-2010, 05:43 AM   #11
BrandonB
Did you try the switch on the circuit board inside the stock Tx? It's been rumored to be the mode switch. Check my mod for Spektrum compatiblity http://helifreak.com/showthread.php?t=213344
BrandonB is offline        Reply With Quote
Old 06-27-2010, 01:33 PM   #12
Don McCullough
Yes, the inside switch is the Mode 1/Mode2 switch. See my picture in the first post.
Good Luck,
Don
Old 10-17-2010, 04:42 PM   #13
Aussie Jon
Hi Don,
We are visiting the US at the moment and I Got one (ELFH1500) of these the other day, I have its little brother (ELFH3000) back in Aus and that uses mode 1 so I have done half the conversion as per your instructions, I've changed the throttle and elevator spring/damper over and switched the mode switch. Now I'm not sure why I would move the other switches and not leave them where they are already labelled.
The instruction book shows them in the same location for mode 1 and mode 2 - does flipping the mode switch alter the functions somehow?
Aussie Jon is offline        Reply With Quote
Old 10-18-2010, 01:57 PM   #14
Don McCullough
Jon,
I moved the switches to match the location of my mode 1 JR x9303 and 11x. If you ever upgrade to a mode 1 transmitter with non-relocatable switch functions (like the x9303) then transitioning will be easier. The internal switch does not move the external switch functions.
Enjoy,
Don
T-500 V-Bar, T-450 Pro 3G, T-250 V-Bar, SR, mCX, mSR, mCP X
Old 08-04-2012, 02:02 AM   #15
VicSR
Default No throttle?
Hi guys, just followed the instructions to change from Mode 1 to 2.
Everything works fine except for the throttle.
No response from the stick.
However, if I switch the throttle hold from 1 to 0, then it throttles up immediately, but still with no response to the stick.
I have to switch throttle hold back to 1, as I fear that it might go in to full throttle.
Any idea please?
VicSR is offline        Reply With Quote
Old 08-05-2012, 12:04 AM   #16
VicSR
Worked it out. I did a rebind, and it's all good.
