| Belt CP E-Sky Belt CP |
ok so I got asked by a friend if i could strap a camera to my belt and film some stuff, "sure " I said how hard can it be.......................
![]() have made a mounting plate see attachment however getting some bad vibrations http://www.youtube.com/watch?v=x-YRa...ature=youtu.be any one have some ideas on vibration control? cheers |
Dan, a couple of years ago (in Christchurch, as a matter of fact
) I did similar tests using Sony Bloggie strapped to a Blade 400, with identical results. A 450 heli doesn't have lifting power to carry a stabilized gimbal, so you'd need to have zero vibrations, a virtual impossibility on a plastic-frame 450.I have abandoned the project at the time and I'm having another go at it right now, but I changed the platform to a 450-sized quad, and the initial results are much more promising. I'm afraid a 450-heli based APV platform is a dead end
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
#3 |
Try to use a lot of dampener between the heli and the platform. You can try PU gel.
It also possible that the white plate vibrate, causing the camera to shake. I have seen this problem before, but can not recall where did I read it. |
#4 |
Thanks guys, I'll try to sling the GoPro under the Heli, CG anyway. That way I can use more dampening. Just have to make extra skids. Pretty keen to make it work have seen some footage that looks good from other 450size Heli. But a quad would be better.
#5 |
I just relized we typically wind up giving advice of staying away from Belt CP here on Belt CP forum
