| RealFlight Flight Sim All versions of RealFlight Sim |
Just upgraded to 3.5 and was wondering if the control sensitivities are really ramped up from v3.. Prior to upgrading, I could land helis on benches, tables, rocks etc with little effort.. Now I find it VERY touchy.. Is it just a different perception or is something really different?
Even the planks fly "odd" now..
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I've noticed this also, just more around center stick though. At full throw, they still seem to have the same amount of deflection, so im guess just some expo should fix it, pretty much all ive done
T-Rex 450 Pro - Mars 388mm stretch - hs5065 - GP750/DS520 - Maverick G5 PRO - HW40A/1950kv-12t/6S Atom 500 soon to be flying. RDS 8K |
Testing... 1...2...3
Good! I thought it was just me!
I'm not mean, you're a sissy! |
With G3, I flew with no expo and didn't have much problem. I always seem to be "behind" the helicopter now and get into some really nasty PIO (Pilot Induced Occillation) from time to time... Makes the hover training very interesting.
Like Amaxx said, I think it feels touchier around center stick. I didn't use expo on G3 either, and I'm using 20% in 3.5.
#6 |
I can't do the hover training at all....it's so touchy that the slightest stick movements make the heli crash. This plus being able to fly through the trees in the race course makes me think there's a few bugs to work out....
. . Sport Flying ain't so bad To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. [SIGPIC][/SIGPIC] |
#7 |
Just got #.5 myself and it does seem touchy near center. I must have had a bad download though. When doing the install, a screen popped up noting that the 'fury' fliles didn't make it. Is there supposed to be a fury in 3.5?
Mark Webber wai-rc.com |
#8 |
There's no Fury in my copy of 3.5. But...do you have Expansion Pack 2? The Fury is included in EP2.
#9 |
OK. Wonder why that window popped up like that.
#10 | |
#11 |
Flip the dual rate switch to slow things down a little.
Chris D. Bergen Bergen R/C Helicopters |
#12 |
Off topic but does any one have Multiplayer issues? I cant seem to connect anymore but maybe this is a thing of the past that i was up to date on.
#13 |
No problems connecting here..
#14 | |
#15 |
yea my god it is very touchy got to level 14 on the trainer and stopped just wayyy to hard.
Avant RC Factory Pilot / A Main Hobbies Customer Service. Representing: Team Avant,A Main Hobbies, YS Engines, Edge Blades, Thunder Power RC, Scorpion Power Systems, Spektrum RC, Aerospire RC, Insane Canopy, Castle Creations |
#16 |
Anyone know why the heli, (in hover training), gets dropped from the sky and crashes a lot, or am I the only one that has this problem?
I haven't messed with it much, but there must be a setting off or something. I have been using Reflex mostly, but just got G3.5 for some of the kool features, and better runways for landing planks. If anyone knows what my problem is with the heli's dropping in on startup/reset, please post, thnks... |
#17 |
gordohigh
Before you start up/reset in hover training, move your collective/throttle stick to more than half way up, sounds like you are in idle up and the control is at the bottom which means 0 or negative pitch, that why it drops Try that Tom |
#18 |
I did that also, and it still usually drops in at full speed and crashes. I calibrated the tx, and it works fine in the other fields and with the other aircraft. It's only in hover training that it starts out like this.
I will try to mess with it again this eve. thanks |
#19 |
OK, If I go a little over half throttle on the stick, it will drop in and not crash, (usually...lol)......just wasn't sure if it was working right or not but guess it is?
#20 |
It is, hover training assumes you are already in the air so you need to set your throttle to a bit over 3/4 at the start or you will crash.
Jermo
Jerry Moore, AMA #878954, IRCHA #2988 Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL Ok, you can fly...but can you HOVER?? To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. KISS = Keep it simple stupid (to maximize fun and reduce costs!) |
