Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 05-03-2010, 05:53 PM   #1
cruzroy
Default Hey guys will these work....resettable fuse
Hey guys will these work.for the honeybee fuse mod..they come in 7.5 to 30 amp range .resettable fuse
get them on ebay..... http://cgi.ebay.com/ebaymotors/JEGS-...ehicleQ5fParts
JEGS 10531 Manual Reset Fuses/Breakers JEGS
Resettable Breakers
10 amps
Ever been stranded on the road or in the pits due to a blown fuse from a voltage spike? Tired of scrambling to find a fuse and fuse puller? These manually resettable breakers replace ATO blade-type fuses using a push-button, on-the-spot breaker. They're available in a 7.5 to 30 amp range and sold 2 per package. Made In USA
cruzroy is offline        Reply With Quote
Old 05-04-2010, 01:59 AM   #2
Viet-Lama
As long as they are "quick blow" fuses they should work fine. I wouldnt use 10amps though, thats about when the V2 4in1blows. Use an 8 or 8.5 instead.
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 05-04-2010, 04:16 AM   #3
Bugster
Sorry to be a prophet of doom but I've heard they are far too slow.
VL is right - automotive quick blow are the best
Cheers, Bugster
Bugster is offline        Reply With Quote
Old 05-04-2010, 04:27 AM   #4
jperkosk
+1 Bugster. We're trying to protect the output transistors on 4in1, anything resettable is electromechanical and will be too slow. Fast blow fuse is what's called for here.
Jerry
jperkosk is offline        Reply With Quote
