Old 01-21-2013, 04:13 PM   #101
Thunder Fighter
Originally Posted by taszo View Post
Hi if you are still in this thread !!, can you tell me if when instructions followed I now leave the end points at 150 or do I move them back to 100
Neither, you leave then where they end up during the CC throttle calibration in Step 6.
You can also use the External Governor mode with then CC if you have the Hobby wing phase sensor and upgrade to the 4.02v of the CC firmware.
//Dennis.
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720
SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A
Thunder Fighter is online now        Reply With Quote
Old 01-21-2013, 11:35 PM   #102
nickyd
Since the castle software now supports external governer, does this procedure need updating?
I just tried the procedure but had the sk software set to Gov mode. I could not get the esc to see the high end point in this config. I then turned off sk Gov mode and got the calibraton.
If I set the Castle software then to Heli mode the esc will arm. If I set the Castle sw to External Gov, however, the esc will no longer arm.
Rcmike is helping me resolve this in another thread, but I think the procedure will need an update for using External gov mode.
Nick
Mini Titan E325 V1, SK720, FBL , Scorpion HK 2221-8, Ice Lite 50, CC 10amp BEC, MKS DS95 ,DS95i , KBDD 61mm Tail Blades, 2200mah lipo. DX6i . AP with Panasonic LX3. Sport Flyer
nickyd is online now        Reply With Quote
Old 01-22-2013, 12:27 AM   #103
taszo
Yes thank you done it last night and got, 127 high and 112 low which seams good.
taszo is offline        Reply With Quote
Old 01-22-2013, 01:51 AM   #104
Thunder Fighter
I don't think so, the only change is External Governor selection on the CC, otherwise it is the same. It worked for me and it looks like taszo.
//Dennis.
Old 01-22-2013, 02:02 AM   #105
nickyd
I apologise for a duplicate post but here is how I got mine working:
Just to summarize:
Ice 50 in External Gov Mode (Firmware 4.02)
SK720 with Electric Gov (Firmware 3.12)
Set up as per the following procedure (http://www.rchelination.com/sk540-governor-with-cc-esc/)
Plug in SK to comp
SK in gov OFF mode
CC in Ext Gov mode
Endpoints in radio on throttle channel MAXED out
Throttle at max and set High Throttle
Throttle at low and set Idle Throttle
Unplug SK
Throttle endpoints at 70 or so
Set High and Low endpoints as per normal CC procedure
Plug in SK
Throttle at Max and set High Throttle again
Throttle at low and set Idle Throttle again
NOW click into the Electric Gov menu in the SK
Low Ramp and High Ramp at 80
Reset throttle curves as per SK recommendation for Electric Gov mode
There is a note that the sk bailout will not work using the CC Ext Gov mode.
A workaround is to put the CC into Multirotor mode, however this produces a kick on startup.
Thanks to another Nick over on Rchelination for the info....
Nick
