Old 09-25-2016, 05:15 PM   #1
Shawn550
Default Dominator Canopy/ESC
Hey guys. Just finished up my 600L went to put the canopy on and it wont fit over the ESC. I have the align 130 installed on the front of the heli as shown in the manual. The only possibility I can see is to mount the ESC on the side of the frame. Thoughts and ideas are much appreciated. Thanks.
Shawn550 is online now        Reply With Quote
Old 09-25-2016, 06:32 PM   #2
Luvmyhelis
Either move the mount pins forward to give the canopy some room, or simply mount it on the side. I usually inside mount all mine, but have one 600 with a Castle on the side, doesn't seem to fly any differently.
Jeti//800Triabolo/Gob700/SHS800/Frankenheli600/Chase420/Compass/Coax/Sk720B/540/360 YGE/YEP/HW/MKS/Outrage/Turnigy/Mibl/Soko/KollDubroRcTek/Boca/Herc/Gryphon/ScottGray Scorp/KDE/Kontronik/TP/Tenax/Lynx
Luvmyhelis is offline        Reply With Quote
Old 09-25-2016, 07:41 PM   #3
Shawn550
Thanks for the idea. Id prefer to modify the least expensive parts if possible. I see a lot of photos of the castle 80 mounted on the side of the receiver mount in the triangle section instead of on top. The 130 doesn't fit but I can cut the mount to make it work. As of now that is my best option in my opinion. I'm going to wait until tomorrow to do it so any other ideas let me know. Thanks.
Old 09-27-2016, 08:40 AM   #4
lahannsven
The Align ESC 130A fits but without the ventilator.
The canopy is very tight and you should also verify, if the batteries are far enough in the frame.
I don't fly 3d, therefor the motor and ESC don't get too hot. Throttle is at 65% in Heli Elf governor mode.
Pitch curve is a straight line from 0 to 100.
Sven
lahannsven is offline        Reply With Quote
Old 09-29-2016, 06:50 PM   #5
GlideslopeRC
How did you get on/ Any pics? Im getting a 600l soon and would like a head start on what you found out works lol
GlideslopeRC is offline        Reply With Quote
Old 09-29-2016, 08:08 PM   #6
Shawn550
Fan mounted on esc canopy would not fit took fan off still would not fit. I was pressing canopy feeling it scraping and mashing on the esc. No good in my opinion not dealing with that every flight even if i could get it on. So my goal was to modify the cheapest part and that was to 20 dollar reciever mount.
Old 09-30-2016, 03:20 PM   #7
GlideslopeRC
Align didnt really think this through then!! i see you had to cut the receiver mount, are you still using a 2s lipo to power servos etc? i thought the esc bec was pretty good?
Old 09-30-2016, 05:05 PM   #8
Shawn550
I had to cut the mount to have it fit freely without having any part of the esc rubbing on anything. I have read the bec in this esc is good however I have no plans on using it. I prefer the rx pack.
Old 10-01-2016, 02:23 AM   #9
GlideslopeRC
Bit annoying but at least you got it sorted. Will be my turn to figure it out shortly too! I will be using the esc bec though I think!
Old 10-02-2016, 03:52 PM   #10
nabl74
Glidescope...The 600L dominator comes withe hv edge 80 which fits perfectly (not the 130). So i would say align did think this through
Trex 500l Dominator-HW100A Pro / i2rc tail blade holders / Gpro
Trex 600l dominator- BRAIN / edge 80 / 750MX
E7se 700 - BRAIN / edge 120 / gryphon bec/ 800MX / 815 &855 cyclics and tail/ halo 700s
nabl74 is offline        Reply With Quote
Old 10-02-2016, 03:56 PM   #11
GlideslopeRC
Align have updated the esc recently...https://www.align-trex.co.uk/t-rex-6...rh60e14xt.html
Old 10-02-2016, 04:04 PM   #12
nabl74
Gotcha.. US /AU distribution doesnt appear to offer this yet which is why i didnt notice.
Old 10-02-2016, 04:20 PM   #13
GlideslopeRC
No worries I'm wondering if a 600x is due soon after the 700x and the 550x just announced!
Old 10-02-2016, 09:42 PM   #14
nabl74
Hope they fix tail ratio issue and make more in line with other 600 offerings
Sent from my SM-G928I using Tapatalk
Old 10-03-2016, 02:36 AM   #15
daniel_ionut
It`s very easy to change the tail ratio to 4.5 on the 600L. You just need to replace stock gears with this:
Torque Tube Front Drive Gear Set M0.6/40T H6NG001XXT
180T M0.6 Autorotation Tail Drive Gear set-Black H60020AA
It performs awesome at 2000rpm after this change.
daniel_ionut is offline        Reply With Quote
Old 10-03-2016, 03:29 AM   #16
nabl74
Higher vibration on tail worries me
