Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 06-09-2010, 04:33 PM   #1
nexgen
Default Power systems that work
425 Power Systems that WORK!!
post em up boys.
GAUI Field RepbeastXTeam Empire Hobby
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
nexgen is offline        Reply With Quote
Old 06-12-2010, 02:53 AM   #2
Abala88
I'm running a
1600 kv mystery motor (started with a stock trex 1600kv motor, but switched it out for one that fit under the canopy).
Align RCE-BL6DG esc
Turnigy 6s 2200
13t pinion, 50t front & 61t main gear, stock one way gear (20t)
430mm wide chord Mavrikk blades.
5 minute 30 sec flight time, flying beginner 3d & FFF. Charge will replace on average 1500mah. So far batt, motor & esc temps have not topped 100 degree range, we will see what happens as the summer heats up.
Abala88 is offline        Reply With Quote
Old 06-20-2010, 01:57 PM   #3
M.Huerta
Scorpion HK3026-1600kv
14t Pinion
Castle ICE 100
Hyperion G3 VX 2600mah 6s
running about 80% throttle and it is crazy powerful, I love it
GAUI 425 - HK3026-1600, Phoenix 80, HS-5245MG's, GY520, DS20GMD, Hitec Optima 7 Rx.
M.Huerta is offline        Reply With Quote
Old 06-22-2010, 09:28 PM   #4
joe1l
Scorpion 3026-1210 ICE 75. 2x 3S 2650 25C zippy
15t pinion, 50t main gear, 20t one way bearing.
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
ElektroRC.com field rep (YGE, MSH, LAHeli)
joe1l is offline        Reply With Quote
Old 06-27-2010, 09:24 AM   #5
atkinson
Stock gearing with 14t pinion, scorpion 3026-1400kv, cc ice 100, spartan quark/jr 810g, 6c 3000mah zippy, align cf blades.
atkinson is offline        Reply With Quote
Old 07-07-2010, 07:57 PM   #6
joe1l
Anybody shopping a power setup, take a look at this calculator by castle. Had I seen it before i setup my my motor i would of saved myself a crash! Be very careful with the Scorpion 3026-1400...it runs pretty hot and likes to turn off on hot days!!
Old 09-21-2010, 04:54 PM   #7
spootman
I'm running a Hacker A40 1600kv with a Castle Phoenix 60 on 13/60/20/61, works out pretty good for fast sport flying. I get about 4:30-5:00 with 2650mah, everything comes down warm to the touch.
spootman is offline        Reply With Quote
Old 10-21-2010, 03:35 PM   #8
Hub Flo
Z20A 1700Kv, CC Ice Lite 75, Gear 13/60/19/61, 6s 2650mAh, Idle1 1900Rpm, Idle2 2300Rpm
Hub Flo
Hurricane 425, Z20A 1700KV,CC ICE Lite 75,BeastX,S9650, 3xS3152,AR6200
Spektrum DX6i
Hub Flo is offline        Reply With Quote
Old 10-23-2010, 06:46 PM   #9
coderzone77
ESc: Align 60A (the one from Trex 500)
Motor: Turnigy H3126/1300Kv
Pinion 14T (all the rest stock).
5:30 min with Zippy Flightmax 2200/25C / 3S x2 in series
it's Good!
coderzone77 is offline        Reply With Quote
Old 11-01-2010, 08:25 PM   #10
Epoweredrc
it's Good!
How is that motor working out for you ?
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL
Epoweredrc is offline        Reply With Quote
Old 01-02-2011, 03:33 PM   #11
racer75
Hi,
Motor: Align 500M / 1600kv
ESC: Turnigy Brushless ESC 85A w/ 5A SBEC ( a very good governor function and soft start in gov mode )
BEC: Turnigy 8-15A with Turnigy 2s / 800mah
Pinions : 14 / 60 / 19 / 61
7 min. with Turnigy 6s / 3000mah
Very Powerful setup with 86% in TX ( Headspeed 2600rpm )
Regards
Marc
racer75 is offline        Reply With Quote
Old 02-07-2011, 11:47 AM   #12
Dracx
Scorpion 3026-1600kv (6-pole, 8kHz PWM)
Phoenix ICE 100 (Set RPM mode at 2600, normal motor advance)
Turnigy 6s 2200 40C
15t pinion and stock gears (61T rear main, 19T one-way, 50T front main)
Stock plastic kit, no upgrades
430mm wide chord Mavrikk (Red) blade, sometimes the Align blades
Pitch +/- 10 degrees
Cyclic +/- 8 degrees
5 minute flight time, moderate 3D (loops, rolls, flips) & hard FFF (hard turns, stall turns, Immelman's, S-turns). I started as a plane pilot
Winter flying (32F - 50F): Motor temp ~97F, battery temp ~98F.
I used to run the above setup with the Scorpion 3026-1400kv (10-pole, 8kHz PWM) but motor temps were ~130F and battery ~115F even on low motor advance. And, the motor was hitting 100% output on moderate to heavy maneuvers. Fortunately, these motors are rated to 356F. Switching ot 1600kv brought all temps down and it rarely hits 100% output.
Dracx is offline        Reply With Quote
Old 03-24-2011, 09:38 AM   #13
firehopper
I'm using this motor, with stock gearing. and 14t pinion
http://www.hobbyking.com/hobbyking/s...idProduct=7243
a ice 75, and a dimention engineering sport bec, and a zippy 2650 40c battery.
waiting on parts to get it back in the air. had a CC standard bec, but somehow it fried and took out my bls251 tail servo.. I hope.. I hope it didnt toast the rest of the gy611 gyro setup.. I dont have money to replace the rest of that.
Proud owner of a Hitec Aurora 9
firehopper is offline        Reply With Quote
Old 04-17-2011, 01:46 PM   #14
Dracx
Turnigy 6s 2200 40C
I should also state that I fly in Colorado at 5200' - 5500' altitudes. Thin, dry air makes a big difference. Though I haven't flown at sea-level, I hear the thicker air makes your heli more responsive and higher head speeds unnecessary.
Old 05-11-2011, 04:30 AM   #15
fusionsx00
heres mine , inever got around to it
gaui scorpion 504 (3026-1400kv)1680 watts
cc ice 75
stock gears except 20t one way, 15t pinion
stock 425 blades
+/- 13 degress pitch
10 cyclic
fbl sk720
xf frame full size servos
flight time 5 min on sport
4:30 moderate 3d
4 min hard 3d
motor does get hot, but not above 110
esc is hot but not bad,
hyperion packs 2950 35c cool, maybeewarm , but barley
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is offline        Reply With Quote
Old 07-23-2011, 02:24 PM   #16
omerhan
hii i need little help..i have a new huricane ep425 but i cant find good power conversation..
motor : turnigy 1300kv (15t pinion)
lipo : turnigy 6s 3000mAh 20c
cyclic : futaba s3003
rudder : kds800+ n590
esc : ?? choose 1-) turnigy plush 80a(maybe with turnigy sbec5a)
choose 2-) turnigy super brain 80a
what should i do? thanks
omerhan is offline        Reply With Quote
