| Hurricane 425 Discussion and support of the Gaui Hurricane 425 |
Like the titles says. Lets seem 'em guys and gals.
That's purdy mightymouse.
My YouTube Channel: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Xbox Live - TheBiffTannen
My first
Trex 500ESP - Gaui 425 - Gaui 550 - MCP-x |
nice rides guys.
#6 |
Hi all now we have our own forum
here's pic's of my new 425 XFES ( also seen in the 550 pic's forum ) my setup 3G - CC ICE 75A - DS510 - HP-DS20-GMD - AR6200 - ON 6V. Not maidedned yet still waiting on batteries.
"Dragons, huh?" Saint George Hurri 550 STD LBoom / FBL Hurri CF 425 TT T-rex 600 ESP - T-rex 450S Spektrum DX7 |
#7 |
Ivan There is a very fine line between "hobby" and "mental illness." |
#8 |
Mines not too much to look at but I like it.
#9 |
Here is my stock 425 and plastic canopy. Learning to use an airbrush is almost as fun as figuring out a piro-flip...
#10 |
Greetings.
I from Russia. I do not know English language, I translate from the computer, therefore do not take offence for that as I write. J Here mine 425 helicopter. I have altered accumulator fastening under one 6S. It turns out to establish Turnigy 2650mAh 6S 40C Do not prompt what better turns of the main rotor to put? |
#11 |
Nice video 9sec240, looks good.
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL |
#12 |
Here is mine. Scorpion hk-3206-1400kv, cc ice 100, spartan quark, 810g tail servo, align 425d carbon fibers.
#13 |
And finally mine too
![]() Gaui 425 IRCHA with: 550 Canopy (that was the ugly white one that I transformed into an horror with red/black adhesive , lol ) Flybar cage upgrade Metal bell crancks for pitch/roll/elev (installed today) Gaui 1400kv motor Align 60A ESC Hitec HS485 on cyclic Gy240 + S9650. Hope you all like it (i installed something to reinforce the frame too)and btw: a big thanks to Nexgen. bobbybe and MikeJ for their help ![]() ![]() ![]() |
#14 |
looks good, what is that behind the motor? looks like a silver bracket between the frame?
mine does not have that. something you added? Hope i can take pictures mine all complete w/o motor/esc next week maybe.
#15 | |
as I wrote, that is a piece I mounted there to help having the frame stiffener (and avoid flexing). I read that solution some time ago and someone wrote it helps with frame flexing and stripping the gears ... I hope it will really help ! |
#16 |
does it really have a issue flexing? Never heard of it you must be a Hard 3D'er.
#17 | |
But no... I'm not a 3d'er Anyway one of my friends had a lot of problems with 61T stripping in normal fast forwards flights. Then, looking for infos, I found someone here on this forum having the same trouble... Then I found this solution reading helifreak and .. yes, I just did it ![]() This is the thread I refer to |
#18 | |
#19 |
With the motor mounted on the frame, you can hold the motor, then grab the frame at the top where the main shaft is and give the frame a twist. You will see that the frame flexes very slightly. It don't flex much, but is enough to cause the gears to not mesh properly, and sometimes cause gear stripping.
I added an aluminum plate to mine when I built it, based on Marco's "stiffy" and it does not flex at all. Never stripped a gear in it yet either. Sorry for the crappy photos. ![]() ![]() ![]() ![]()
I don't need the latest and greatest. I just need more time to fly what I have. Helipro 450se, Gaui 200, Gaui 425 x 2, Gaui "HeadHunter 500, Gaui 550 |
#20 |
Oh, you attached the bottom to the motor mount. looks nice.
I can not really see how big the one coderzone77 has, but all you need is just something across the top right. doesn't really need to go all way down to the motor mount? I do not have a motor yet so cant do the test you said to see it moving, if i just grab the frame and head it doesn't move at all seems super stiff to me but under flight conditions understand how it could change.
