Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 09-16-2012, 11:30 AM   #81
gimballina jolie
Default here is mine
having hard time with pictures upload
Name:	heli photos 020.jpg
ID:	349930   Click image for larger version
Name:	heli photos 027.jpg
ID:	349931   Click image for larger version
Name:	heli photos 021.jpg
ID:	349932   Click image for larger version
Name:	heli photos 018.jpg
gimballina jolie is offline        Reply With Quote
Old 09-17-2012, 04:28 PM   #82
stark
flybarless and all !! good stuff gimballina jolie
-roger
Compass Atom 500 FBL, GAUI hurricane 425EP
stark is offline        Reply With Quote
Old 09-18-2012, 06:37 PM   #83
ncrkceo13@gmail.com
Default mine
this is mine and its for sale....
plus a few other stuff i have
ncrkceo13@gmail.com is offline        Reply With Quote
Old 12-01-2012, 01:10 PM   #84
SQRT(-2)
My new (to me) Gaui 425 with the quick paint job I threw on it. I plan on trying some fancy stuff this winter with an air brush, but I just wanted to get something on the stock canopy to get in the air. The stock canopy is actually pretty easy to put together, I found the Testors orange plastic model cement worked perfect.
The theme is "Visibility":
Ya, the monocote trim sheet I used on the tail is not a perfect match, but I think it will work. Next time I am in St Louis I will head by Mark Twain Hobby and see if I can find a better match in person.
I was able to do a test flight this afternoon, it flew great. A couple of twist of a link to get the blade tracking in and a bit of trim and it would hover without my thumb on the cyclic. Wow 500 class rocks!
EDIT:
Here it is with the boom and tail blades painted. It looks much better I think.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks!
EFlight Blade 450 3D, Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 01-09-2013, 10:17 AM   #85
SQRT(-2)
I just wanted to share the Gaui FBL and with new wiring.
I made a bottom plate in the body with plywood, I drilled a hole in it and put a thin plywood bottom that slid between the skids and the frame. I hid all the coils of wire between these two bottoms.
Old 02-04-2013, 06:26 PM   #86
fiveflat
Thank you PTcaflyer! Got it put together this afternoon... Now to learn what I need to look over and check out before the first flight.
fiveflat is offline        Reply With Quote
Old 02-04-2013, 08:12 PM   #87
PTcaflyer
You are Welcome!
You will have fun and soon you too will have the"Gaui Grin"!!!
PT
Gaui 500 / Tarot Quad 450 KK2.0LCD/ X525 (2X) DC 450 FPV 500mw 5.8 / SC10
AMA 953414
PTcaflyer is offline        Reply With Quote
Old 02-05-2013, 08:10 AM   #88
stark
Awesome job with the wiring. I also see that you have made your own flybarless head out of the original 425 head. How is it working out for you? Would love to know how you made it .
cheers,
-roger
Old 02-05-2013, 08:19 AM   #89
SQRT(-2)
Works just fine for me.
I ran the Jesus bolt through the flybar seesaw bolt hole to lower the head. The links I made out of threaded rod. I bet you could find a rod that is the correct length, but I could get the threaded rod local.
The extensions are these:
http://rcdumbthumbs.com/G-204706.aspx
For the swash follower you can mod the FB ones our use this:
http://rcdumbthumbs.com/G-204707.aspx
I imagine a Trex 500 FBL head would also work, Tarot has one for $45
http://tarot-rc-heli.com/Tarot_RC_He...less_Rotorhead
EDIT: Sorry, man did not see you were in Finland there. I don't know where to get those in Europe, but I bet you can figure it out. I'll keep the links to where I know to find them so you can see exactly what I am talking about.
Old 02-05-2013, 02:44 PM   #90
Mikej
I di dthe same mod for my 550 - I used some rods that I had for the swash to grips - they are either the cyclic servo to swivel links from the Gaui 550 / 435 or from a Raptor
Mikej is offline        Reply With Quote
Old 02-05-2013, 06:54 PM   #91
volvochef
Default Gaui 425
I like this... are parts hard to get?
volvochef is offline        Reply With Quote
Old 02-06-2013, 03:33 AM   #92
stark
Thanks for the info. As long as I know the part numbers I can do the finding
cheers,
-roger
Old 02-12-2013, 02:03 PM   #93
fiveflat
Slighty off topic here, but I came back to this thread just to see SQRT's FBL setup. I have also read that the Trex 500 FBL head is a direct fit to the stock main shaft, anyone see any reason why the Trex 500 DFC head wouldn't work either?
Old 02-12-2013, 08:57 PM   #94
SQRT(-2)
DFC uses a shorter main shaft. (I think.)
Old 04-06-2013, 11:28 AM   #95
milliotseb
My gaui 425 before my first take off (boom is medium boom but blades are 425mm)
Hacker A40-12S 1350kv
CC ICE 75
Futaba S3152 on cyclic and BMS 661DMG on tail
2 lipos turnigy 3S 3000mAh 30C
I bought it on ebay (no motor and no esc) nearly 18 monhs ago
And I did not put the canopy for the flights
milliotseb is offline        Reply With Quote
Old 04-06-2013, 01:40 PM   #96
Davy Crockett
Looks great...love that canopy!!
Blade mCPx, Align Trex 250, Align Trex 500, Gaui 550 Hurricane, HK600GT H.A.L. Quadcopter
I have a perfect record in helicopter flight......I've never left one up there!!!!!
Davy Crockett is offline        Reply With Quote
Old 04-06-2013, 01:47 PM   #97
PTcaflyer
Looks Great! Those canopies are collector items!!
Try bumping that gyro gain up at least 10% and go to 500mm blades...!PT
AMA 953414
