Old 06-16-2010, 12:42 PM   #1
Finless
Team Taco VP
Default 720 Setup Files
Per a request by Skint Eastwood, here is a sticky for you all to post 720 setup files.
Below are links to posts that already have some setup files.
http://www.helifreak.com/showthread.php?t=221969
http://www.helifreak.com/showthread.php?t=215330
http://www.helifreak.com/showthread.php?t=209860
Bob
"Don't Taco My Pack Dude!"
Old 07-03-2010, 11:53 AM   #2
Silverexpress01
Default Trex 250 SE setup files as of July 03, 2010
being updated
Coaxial setup example:
To be added..
Default values:
For reference...see attached
Name:	Default SK-720 Advance Options Values.jpg
Jose (Youtube -> Silverexpress01
See also Helifreak Blog)
MCPx 76/7 | Trex 250 DFC 667/19 | Hurricane 200 FES 143/7
Last edited by Silverexpress01; 08-21-2010 at 12:13 PM.. Reason: Being updated....
Silverexpress01 is offline        Reply With Quote
Old 09-10-2010, 09:00 PM   #3
RoToR ChAoS
heres one from my 450 Hybread (work in progress)
RoToR ChAoS is offline        Reply With Quote
Old 01-04-2011, 08:23 PM   #4
Cirkus
It's not a setup FILE, but it may help someone setting up for the first time. Be advised this is how my own setup is, and it is an unregulated 7.4 "HV" setup. I think that's important to note.
________________________________________
lipo polarity is incorrect, please observe,
georgi UK
FlightCam
http://ryanbarnes.smugmug.com/
Last edited by georgi UK; 04-07-2011 at 03:17 PM.. Reason: mis-leading, potentially problematic.
Cirkus is offline        Reply With Quote
Old 01-05-2011, 04:13 PM   #5
georgi UK
=] lipo polarity is incorrect, please observe,
georgi UK
Last edited by georgi UK; 04-07-2011 at 03:48 PM.. Reason: mis-leading, potentially problematic.
georgi UK is offline        Reply With Quote
Old 01-26-2011, 04:37 PM   #6
oldschool269
Trex 700e
5.7v reg !!! , i am finding that the voltage needs to be stable .. needs to be !!
451 bls 3rd hole out , star horns
torq tail 3rd hole out star horn
hs 2200 st2 1950 st1
bell cranks set to high range (long throws)
Align 690 d mains , align CF TAIL BLADES
+- 12 deg collective
+- 10 deg cyclic
version 2.04 firmware
enjoy
hot dog 3d setup .. tail gain may be a click or two high
rename the file download as .sk7 ... not .zip
.zip is just to post it up on server here ..
jason
File Type: zip trex base 700e 2 feb 2011 take 4 final .zip (263 Bytes, 256 views)
oldschool269 is offline        Reply With Quote
Old 02-02-2011, 04:13 PM   #7
georgi UK
Default ALERT
=] awaiting updated lipo polarity corrections, RED / BLACK.
georgi UK
Old 02-02-2011, 08:42 PM   #8
Cirkus
georgi UK
Note to potential diagram users:
I mislabeled the colors on the battery wires. Use common sense and don't plug your batteries in backwards. If you put your EC5 and EC3 connectors on properly, you can't plug them in wrong anyways. Also please note that I miscolored the servo leads, but I figured you would manage to figure that out too. In addition, if you do not use the same brand of HV servo or tail servo or regulator, you will of course swap those out and use your particular brand of device in it's place. Batteries shown are not to scale. Apparently if I don't mention things like that, certain people will not be able to figure out how this junk gets put together and it will all be my fault.
Georgi, get off my nuts.
FlightCam
Old 02-03-2011, 06:55 PM   #9
hjscm
well thanks for that but a little too late. i followed your diagram and was really confused how you got it to work without any servo wheels on the swash servos. it has been driving me nuts. next time please put them on so i know. you did on the 251.
hjscm is offline        Reply With Quote
Old 02-03-2011, 10:19 PM   #10
Cirkus
My bad. You got me there.
FlightCam
Old 02-18-2011, 06:20 PM   #11
Tisondm
Default TREX 600 Set Up File 2-18-2011 Ver2.04
Here's the setup file on my Trex 600 with Version 2.04
CHP TREX 600 Esp FBL, SK720, 8S, Scorpion 4025-740, 19T, CC Ice 100, WR Bec
I started out with 50% cyclic gain and 40% tail gain. It's flying awesome with these settings so I don't plan on changing them. The setup file was saved after 4 flights with self tune bell gains on. I started out with the Basic 3D setup. I hope this helps.
Governed HS 2100
+/-11 Collective
10% Cyclic
ID:	211386   Click image for larger version
ID:	211388   Click image for larger version
File Type: zip Trex 600 3D setup file.zip (322 Bytes, 215 views)
JR X9503
TREX 500 ESP FBL, Skookum SK720, Scorpion 3026-1600, 14T
CHP TREX 600 ESP FBL, SK720, 8S, Scorpion 4025-740, 13T, WR Bec
TREX 700E FBL, SK720, 12S, Scorpion Comm 130A ESC & 4035-500 , 12T, WR Bec
Tisondm is offline        Reply With Quote
Old 02-24-2011, 05:43 PM   #12
rickywu
How can i upload my file here??
rickywu is offline        Reply With Quote
Old 03-01-2011, 09:33 AM   #13
alexf1852
Default Protos Setup file
MSH Protos FBL - Jive 60LV, Hyp. 880Kv, S9650s w/MG, SK720 w/ DS650. This is the non-stretched Protos flying 425-430mm main blades and stock tail blades.
Note that you will need to adjust the mid, upper, and lower servo travel limits to level the swash since mine won't be exactly the same as yours. I'm also using the Futaba s-bus receiver with my 8FG tx. So you'll have to change this setting as well to your RX. And I have self-leveling on at 90% on bank #2 with tail gains adjustable in the TX in both banks. I have 40% overall tail gain and that is working good for me with the ball at 10.5mm on the tail servo horn.
Don't forget to rename the extension on the file to .SK7.
File Type: zip Protos_Default_v2.04_Tail_Gain_Adjustable.zip (263 Bytes, 172 views)
MSH Protos * 2, SAB 630
alexf1852 is online now        Reply With Quote
Old 03-08-2011, 10:30 PM   #14
Silverexpress01
Originally Posted by Silverexpress01 View Post
being updated
To be added..
Default values:
So I never got around to providing a Co-axial setup. Simply because it's so easy to setup Self-Leveling with SK-720. Also as I've learned all heli's are different, and so a fixed set of numbers can be a crapshoot in applying to all. In order to redeem my promise...try this...
http://www.helifreak.com/showpost.ph...6&postcount=38 and once I figure out how to set it up for self-leveling...you shall have that too and some cake.
Update: I figured it out!
Old 03-10-2011, 06:01 PM   #15
CHIEF-X
i would like a setup file for a trex450 sev2 with airtronics 94809 servos on cyclic and ino lab hgd-210hb on the tail. and would also know how easy i can make it fly for a newb. i can fly a 4g6s fine in fast foreward flight.
FUSION 50 12S SK540 TORQ WITH QUANTUM/HOBBYWING POWER SYSTEMALIGN TREX 450 PRO V2 BEASTX 6S MKS SERVO'S GAUI X5 FES BEASTX DX8
WINDANCER
COMANCHE TRIBAL MEMBER 4TH GENERATION
CHIEF-X is offline        Reply With Quote
Old 05-12-2011, 07:01 AM   #16
Lorenzo
cannot open file; can you do a pdf
Lorenzo is offline        Reply With Quote
Old 05-23-2011, 10:37 PM   #17
mudfish911
Does anyone have a setup file for Trex 550e, using the standard align servos as supplied in the combo?
mudfish911 is offline        Reply With Quote
Old 07-04-2011, 12:50 PM   #18
Wishmaster83
Does someone have a setup file for a T-Rex 450 Sport withan RJX head and the stock servos (DS410)?
And maybe also a tipp on where to place the SK720 with a Spektrum AR6100 reciever already installed in it?
Greets
Wishmaster83
Wishmaster83 is offline        Reply With Quote
Old 12-06-2011, 11:30 AM   #19
CHIEF-X
dang this thread has grandma'ed lol at least i know i will post my sk720 files when i get the unit flying great. it will be on a outrage fusion 50 running yge 90hv esc, xera 4025 560kv 3y motor torq servos all the way around and a western robotics herculese super bec.see y guyz in a while!! hell ill still prolly be the next post up lol
WINDANCER
Old 12-06-2011, 12:33 PM   #20
georgi UK
=] yes we can go over the setup log for you, just say how you want it to fly mild or wild!!
georgi UK
