| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#21 |
I just started with a SK540 on my Compass Atom550.
So here's my setupfile: posted in : http://helifreak.com/showthread.php?t=445041&page=4 I disovered I couldn't upload the same file on 2 posts, so linked it. My setup is as follows: Atom 550, stock blades, KBDD tailblades 84.5 mm swashservo's align DS510 Tailservo : align DS650 ESC kontronik Jive 60 amp with heatsink My endpoints for cyclic in the TX are 30/32 (bank 1 / bank 2). I locked the tailgain, and switch the tailbank with thesame switch as the cyclic banks. Only difference in the tailbanks is the controlrate. If you have improvements, be my guest. I'm still in the adjusting fase. Finding the best settings for my flyingstyle (mild 3D).
LOGO 400SE : Skookum SK540, Scorpion 3226 1230kV SJM180 : Tarot ZYX Rigidheli.com: The place where Dutch Helipilots meet |
#22 |
Anyone got a file for a 450pro?
Sent from my LT26i using Tapatalk 2
7HV,EL Brute, HW120 hv, bls 451,251, SK540 Warp, mks92a, ds525,hw40pl, sk540 Lynx team pilot |
#23 | |
Yes I would like to know what other 450 pro fliers is using. I'll post mine when I get a chance tonight or tomorrow
Trex 450 Pro V2 FB spartan quark trex 250 beastx Fusion 50 beastX |
#24 |
I'm still working on getting my 450 Pro dialed in on the 540. Once I get it worked out I'll post up my file and specs. Like Spork I'm curious to find out what others are running.
#25 |
Would be great to get the set-up from someone who has fully tuned their 450Pro with the SK540. I'm gradually getting mine where I like it, but it still tends to drift with the wind, and I'm not sure what I should be adjusting to make it more stable.
#26 | |
check this thread out in the sticky section http://www.helifreak.com/showthread....26#post4710626
FUSION 50 12S SK540 TORQ WITH QUANTUM/HOBBYWING POWER SYSTEMALIGN TREX 450 PRO V2 BEASTX 6S MKS SERVO'S GAUI X5 FES BEASTX DX8 WINDANCER COMANCHE TRIBAL MEMBER 4TH GENERATION |
#27 |
HI all
I am new here especially with the Skookum so please help? I have a Skookum 720 setup on my heli. I have done all the wizard setups as were told. Now I have the issue of when I test and tilt the nose down, the Skookum is not countering the swash and instead gives extra pitch. this goes for Aileron as well as Elevator? Is there any values I need to setup to negative instead of positive or what do I need to do or is this normal. As far as I know and have learned that it is suppose to counter? And what would be the ideal pitch settings neg , mid and pos? Any help will be much appreciated please? Heli: Scale BO 105 OS 90 SZ JR 8301 digitals ALign ds 655 tail Vario 4 blade head and Vario scale blades Robbe Shluzer Millenium 90 size frame Regards |
#28 |
=] have you set the handset to 1 servo 90 deg swash type? all mixing is done in the SK....
georgi UK |
#29 |
HI
yes, 1 servo 90 degrees setup. I cant upload the setup file cause it's a .sk7 file extension. Any way I can change it? thx so far |
#30 |
=] if this is a dx6i change the swash mix to a negative value, mail me the setup file = gmcallister@ocvc.ac.uk
georgi UK |
#31 |
Sorry forgot. I have the Aurora 9 with Optic 9 RX
#32 |
=] what swash type / mechanics is this? we set the Tx to 1 servo 90 deg. then set the SK software to (usually) eCCPM swash types, ie, how many servos are connected to the swash? in your settings you have a one servo (raptor type) cradle selected, this is probably not the case?
![]() goto the preferences tab and select advanced for the interface, reset the servo travels to defaults, and use the 60/60/45% swash mixing to get the travels you want for collective and cyclics, ![]() we can look at the tail after she has flown, it's currently in rate mode, you may well want this? but the travels are limited on one side, see how it performs as is first. georgi.
georgi UK |
#33 |
Still no success. eCCPM not working bud. Do u have Skype?
Can u maybe check the Robbe Shluter Millennium Frame> there u can see the servo setup? |
#34 |
GOt it sorted Georgi
Found that the 1 servo 90 degree was correct. The problem found was that I had to reverse the aileron on Skookum software and put Elevator to Norm, then had to change my stings on the TX, had to reverse my Ail and Ele to reverse. NOw all is working like a well oiled machine and the swash is staying level and countering as it is suppose to be. Thx a lot for your help and much appreciated. ALso like to thank Grant aka thefrog for helping me via Skype and landline for almost an hour. Thx buddy, Much appreciated. Ur one superstar and now she will be ready for Scale Fun FLy day here in Gauteng, South Africa!! Regards all u good friends Ta! Z |
#35 |
=] just be sure the swash type is correct, you have a 90 deg 4 point type
![]() not a 1 servo raptor setup, ![]() just playing safe here!......
georgi UK |
