| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
#41 |
I was curious if anybody has the logo 500/600 tail gear above the main gear - part number mik4059. That would be greatly appreciated, readyheli is out.
I also have available a used set of blade grips/spindal/thrust bearings assembly for a logo 500 if anybody is interested. I just upgrade the grips to the logo 600 14mm size. Let me know! |
#42 |
I don't know if Jason found one of these parts, but I'm also needing a MIK4059 to finish up a Logo 600.
I've got a bunch of new and used Logo 400 parts and a few 500 parts. Let me know what you need and I'll see if I have it. |
#43 |
Anyone local that have MIK4183 (Main Gear 106T)? I have couple of parts i can trade, I have the full head that includes shaft, grip assembly, swash driver and swash. I also have 600 belt (Non SE). All parts I have are used BTW...
#44 | |
TRCHK |
#45 |
Sil40sx....I have one, but am down in SD......Let me know if you want to try to work something out....
#46 |
I've already placed my order from RH,.. do you need sumtin I have though?
#47 |
I'm converting to mod 1 gearing, so I've got some mod 0.5 maingears and pinions that are free to a good home:
http://helifreak.com/showthread.php?t=250419
trex 450: 350mm, 4s 2200, 450m 12T, hs5065mg, beastx+s9257, ice 50, 3000rpm, R6203SBE logo 500se: 623mm, 12s 3000, xera 4025 560 15T, ds20-fmd, beastx+s9254, ice 80hv, 2000rpm, R6203SB member ACM, AMA, AOPA |
#48 |
I have a 600 boom and belt, has 9 flights before I installed a 600SE boom and belt.
#49 |
anyone want to swap a pyro 700-52 for my pryo 700-45?
Dan |
#50 |
I have a full size back sensor vBar with 5.0 Pro to swap for a Blueline miniV!!!!! Preferably NIB.
1 - LOGO 600 stuffed with angry hornets 2 - A sad & lonely looking Rush 750 that I can't find time to finish. 3 - 7HV stuffed with over-tired honey badgers |
#51 |
i have some maniac 553mm blades i would like to swap for some edg fbl 553mm blades.
there as good as new but have to much pop for me,
0utrage fusion 50, hk-4025 630kv scorpion.12s, v-bar, kontronik, Sponsored by hobbymaniac Proud to be a Maniac! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#52 |
NVM
Brian Tran Amainhobbies.com Protek R/C ( ͡° ͜ʖ ͡°) Last edited by brian94066; 11-08-2010 at 07:07 PM.. |
#53 | |
I might want to swap....
TRCHK |
#54 |
I just upgraded to a SE, so I've got a stock 500 boom, belt, struts, and pushrod that need a home.
#55 |
Im looking for the quick uk tail or rjx tail and can't seem to find them in stock anywhere. does anybody have one of these
#56 | |
TRCHK |
#57 |
Konrad, how does that compare to the original one for the logo. Im not too sure how the design differs and what I need to change. Please let me know! thanks.
#58 |
Jason, I just bought one from rjxhobby.com. Complete tail blade assembly, slider and arm cost me US$ 88 delivered to my door by DHL.
Perfect fit - all I had to do was cut off the untreaded part of the brass slider - a 2 minute job. They have a choice of CNC or plastic blade grips I went for the plastic because they would have a little more give. It is also beefier than stock Mikado. |
#59 | |
T-Rex 450 V2 HS-65 MG's, Quark/9257 Logo 500SE VBar - Scorpion 4020-1100, Jive 100LV, DS610's, BLS 251 |
#60 |
Ok go to rjxhobby.com. go to Extreme 50 Nitro spare parts,
X800-60528 is plastic tail blade holder assembly or X800-60528M if you want metal one. X800-60050 is Tail pitch slider assembly. XT60054 is tail pitch control lever. Like I already said its a perrfect fit - all you have to do is cut off the untreaded part of the brass slider and round off edge wyth a little bit of sandpaper - a 2 minute job and you are set to go. Doing this adds more throw on that side. Hope this helps |
