| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#41 |
Yup Video Link ->Pro's and Con's of Scan mode vs Normal mode AND some anomalies of the LEDs??? (57 Megs) link failed.
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol The heli virus has infected me and i hope that there is NO CURE! |
#42 |
its friday night guess Bob is away. he fix it when gets back on i am sure i got same message
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL |
#43 |
It's okay its no big deal we all can wait.
#44 |
Question Finless,
If you know the answer, if your flying a electric, and you have a speed control hooked up as normal to power motor and servos what would the telemetry tell you on the radio would it give the lip voltage or just show the put put that the esc is giving to the servos? is just the 8 channel have that feature or do the 6 channels rx's as well thanks
#45 |
Bob,
The Pro's & Con's link isn't working......... |
#46 |
"Question Finless,
If you know the answer, if your flying a electric, and you have a speed control hooked up as normal to power motor and servos what would the telemetry tell you on the radio would it give the lip voltage or just show the put put that the esc is giving to the servos? is just the 8 channel have that feature or do the 6 channels rx's as well thanks" I'm not Bob, but I know the answer. If you are powering the RX thru throttle lead on your ESC, the telemetry voltage is going to read what the BEC on the ESC is outputting. The only way to monitor pack voltage is to use a seperate power source to the SPC on the RX. You want to solder this lead in before ESC on the main battery connection. I believe I read somewhere that the RX can handle up to 35 volts??? I have this setup on two of my planes and it works great! Tells actual voltage of the pack...
ElyQ Vision 50 Competiton Trex 500 NITRO Team KBDD |
#47 | |
#48 |
This is the correct link for the normal vs scan video.
http://video.helifreak.com/?subpath=...ame=n_vs_s.wmv |
#49 |
This card comes with the A9 and every RX hope it helps explain the lights on the module and Rx
#50 |
Keep up the good work Bob loving the vids so far cant wait untell you get in to flights cond
#51 |
I like the radio I'm just not so sure all the bugs are worked out based on what I just watched, but I'm sure Bob will get it all sorted out.
Thanks Bob for the great review.
Helicopter: A mass of parts, all trying to kill you since the day it left the factory ! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#52 | |
At least we know w can plug servos and all in backwards and will not hurt a thing
#53 |
Team Taco VP
Link for that video is fixed.
As for the Card showing the LEDs. It still does not tell you some of the things I saw like holding the button down for 3 beeps? or the screaming beep when the RX is turned off "sometimes". Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#54 |
The screaming maybe the low voltage for the RX after being turned off for a little bit I get it once in a wile when I unplug the main pack from the heli if I leave the radio on for a minute.
Hitec Aurora 9 Beam E4, Hitec HS5065MG, Scorpion 2221-8 V2, Castle Phoenix 45, Castle CC BEC, Hitec HG-5000 HS-5083, Turnigy 25C 2200mah 3s Compass Knight 600E 8s, Scorpion 4025-740kv, Castle Phoenix 85-HV, Align DS610, Futaba GY611 S9256, Zippy Flightmax 25C 5000mah 4s |
#55 | |
Just about every radio I ever had worked like that because you're just connecting the signal into the negative side. There used to be a time when manufacturers keyed the plug so it went in one way only also so you couldn't mix say Futaba, JR, KO Propo etc., not that we listened lol just trimmed off the key and Viola it worked ! I'm with Bob on this one, till he says it's just normal I wont buy one !
Helicopter: A mass of parts, all trying to kill you since the day it left the factory ! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by nighthawkron; 06-26-2010 at 09:43 PM.. |
#56 | |
#57 |
Wow thats not good to hear !
#58 |
yeah i looked in the radio thread for it, seems to be about 3 or 4 driffrent people posted this same issue, not the complete going out but that when they cut on the power switch the screen did not come on at all, like the radio did nothing, they cut it off and waited then back on and it came on, seems few had this happen, someone posted maybe its a "Soft switch"
I love Hitec I really do thats all I flew for many many years and i still fly my Prizam 7, on 72, i have the module where can set it on any channel I want, when get extra money going get a 2.4 module for it from skydream. I want all my planes to be on 2.4. But issues with new radios scare me, i do not want to be w/o radio for month for a fix. most the time hitec service has always been great I have sent in RX's for fixs and got back in days but i can understand with a radio it take longer.
#59 |
No that aint good to hear that sucks technology is awesome now but has it draw backs and lil kinks at first but gotta love technology it has grown alot and i dunno where i be without it....does anyone have pics of the radio i cant see vids with my phone
#60 |
Here ya go
