Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 07-12-2010, 04:20 PM   #1
vernon7026
Default main shaft thickness
Hi all
What thickness is the raptor 90 se main shaft ?? I want to buy a leveling tool that will fit the shaft ?
Any suggestions ??
regards
vernon7026 is offline        Reply With Quote
Old 07-12-2010, 04:25 PM   #2
capebob
A swash leveling tool will probably be hard to find on your Raptor 90 because the main shaft diameter is 11mm. The swash on a Raptor 90 is easy enough to level without a tool.
Bob
Samuel Adams field rep
Buffalo Wings field rep
Success is the ability to go from one failure to another with no loss of enthusiasm.
Churchill
capebob is offline        Reply With Quote
Old 07-20-2010, 10:59 PM   #3
seanh
I was looking for the same thing and never did find one. But really didn't need one after all. I adjusted the links as per the manual and that was it. Just kind of eyeballed it and it was basically perfect.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote
Old 07-21-2010, 03:20 AM   #4
fixnfly70
Them raptors are easy to set up........an eyeball look here, a tweek there, and usually within real close to neutral lift off...... I'm sold.....
Raptor 90SE - OS91SX-H - GY611 - 9CHP
Raptor 90 3D - YS91SR-GY611-CY atg V3
Memberships: NRA (life); AMA 840156; Tripoli Rocket Association 11843 L3
.........It rubs the lotion on it's skin or else it gets the hose again.........
fixnfly70 is offline        Reply With Quote
Old 07-22-2010, 08:32 PM   #5
seanh
don't know if this will work or not.
http://cgi.ebay.com/Swashplate-Level...item3a5d2045ea
if it's too large a hole then maybe get some aluminum tubing and make a bushing
