Old 08-11-2010, 05:54 AM   #1
nightflyr
Default The laboratory has been buzzin' again
The midnight oil has been burning bright and hot....
Brace yourselves for the awakening.........
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 09:28 AM   #2
Stumblebee
One day you are going to in spite of yourself, build something that needs a license to fly. You go for it! I am not even going to speculate what this new beast will be like.
You "DA MAN"
Stumblebee is offline        Reply With Quote
Old 08-11-2010, 09:40 AM   #3
nightflyr
Possible.... but until I convert to liquid fuel Which holds no interest to me), I believe I can get away with E power
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 10:51 AM   #4
Navigator53
Yet another "had an idea this afternoon, by midnight it's flying" creation
Buddy, you're too much
Mel
When the people find that they can vote themselves money, that will herald the end of the republic.
~Benjamin Franklin ~
Navigator53 is offline        Reply With Quote
Old 08-11-2010, 11:02 AM   #5
nightflyr
Mel
Almost flying... need to swap out the pinion first, and if mother nature will permits
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 11:12 AM   #6
nightflyr
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 07:22 PM   #7
nightflyr
Default It's Alive...Alive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The Creature flew this afternoon........
But due to a poor judgment call on my part ( and I knew I should have done what I did before)
The present TT has insufficient rigidity, hence causing a very nasty vibration in the tail section.....So tomorrow a new and improved and much more rigid TT will be made and fitted into the creature....
This I'm sure will solve the problem, if all goes as planned you'll meet it
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 07:26 PM   #8
Navigator53
Hey Night,
Is it that added brace you put on Were Wolf after the horizontal fin?
Old 08-11-2010, 07:48 PM   #9
vanguy
Night, what insanity are you unleashing upon our quiet and tranquil world. What madness have you hatched from that untamed mind of yours? The world waits in shock and awe to this creature with no name. Oh the humanity.
vanguy is offline        Reply With Quote
Old 08-11-2010, 08:30 PM   #10
nightflyr
Don't be too quick to run out and buy that 600ESP just yet........
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 08:43 PM   #11
nightflyr
Hey Night,
That has been replaced with a one piece boom tube now
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-11-2010, 11:28 PM   #12
Navigator53
Oh that's just tubular man, tubular, far out
Old 08-12-2010, 12:52 AM   #13
Stumblebee
Default Can't touch this...
Night I know you really like the "Monster Mash". Still, with you I keep thinking about M.C. Hammer's "Can't Touch This...". It doesn't have the legacy or classical appeal of "The Monster Mash" but it is certainly fitting with the toys you are creating.
Old 08-12-2010, 04:46 AM   #14
nightflyr
Well, the general idea is that to make these easy and affordable enough to build so that others who are interested, can move up the size class if they feel comfortable doing so.:o
For me it just the challenge, I get bored very easily
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-12-2010, 10:00 AM   #15
Navigator53
I want one, I want one
C'mon professor, give us a sneak pre-view
Mel
Old 08-12-2010, 10:03 AM   #16
nightflyr
I just got the new TT material, and made the O-rings for the bearings...Gheezzzzzz. I still have to size the TT mount the bearings and spline ends...with any luck the creature will be unleashed tonight
Mel
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-12-2010, 12:06 PM   #17
pril250
Suspense is a real killer
Blade400
pril250 is offline        Reply With Quote
Old 08-12-2010, 12:38 PM   #18
nightflyr
But.... I never disappoint
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-12-2010, 08:15 PM   #19
vanguy
Night, getting close to pulling the trigger on a 600 ESP. What's your advice?
Old 08-12-2010, 09:15 PM   #20
nightflyr
Do what you feel is best for you,
the creature is alive, but flying in the dark I can not tell if everything is working correctly and with lighting flashing across the skies it makes it even tougher.
Assorted
Mix Fixed Wing.
AMA # 972083
