Old 08-12-2010, 09:27 PM   #21
pril250
You will now have to wait the night out buddy
Blade400
pril250 is offline        Reply With Quote
Old 08-12-2010, 10:06 PM   #22
Navigator53
Originally Posted by nightflyr View Post
Do what you feel is best for you,
the creature is alive, but flying in the dark I can not tell if everything is working correctly and with lighting flashing across the skies it makes it even tougher.
Hey Night,
I always wanted to try this with a Helicopter, you go first
When the people find that they can vote themselves money, that will herald the end of the republic.
~Benjamin Franklin ~
Navigator53 is offline        Reply With Quote
Old 08-12-2010, 10:17 PM   #23
nightflyr
Thats about what it looks like around here.....pitch black with nice bright flashes...makes it real tough to see whats happening...hoping for better weather tomorrow
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-12-2010, 11:00 PM   #24
nightflyr
Ok boys...here's the skinny...
everyone has been asking about an Align 800 though no hard proof has been put out there as of yet ..the talk is some type of conversion for the 700 but nothing more than talk so far..
Well with the nice parts from RJX......
There now sits a hybrid RJX/Align 800LE CPII/VBar on my kitchen table...(don't ask what the rest of my house looks like right now)
Been tinkering with the HS to get that tuned in for a shake free flight( even @ 1400 this beast will launch itself... but due to darkness and storms rolling through..test flights are now on hold.
Also been working on making (MUCH) longer boom stays and tail fin extension...
But it's coming up to the witching hour and this old man need a few hours rest before heading back to work, so this project is getting parked for this evening till tomorrow
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-13-2010, 12:54 AM   #25
Stumblebee
Summer storms are always dramatic.
Stumblebee is offline        Reply With Quote
Old 08-13-2010, 12:57 AM   #26
Navigator53
Default Tick, Tick, Tick..........
So you do sleep Buddy??
We hold our collective breaths until the sunrise rises on yet another day for the "Creation"
Old 08-13-2010, 01:00 AM   #27
Navigator53
Go to bed John, you're up much too late Metric time
Old 08-13-2010, 06:06 AM   #28
nightflyr
The final pieces of hardware are complete and installed now.... will get the HS tuned in this afternoon after work and hopefully have a hop test video if weather permits....
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-13-2010, 11:44 AM   #29
Bri
Brian
T-Rex 700F3C / T-Rex 450 Pro / Blade mCPX / Blade mSR / Blade mCX / Walkera 53Q3
JR X9503 /
Spektrum DX7
Phoenix Sim
Bri is offline        Reply With Quote
Old 08-13-2010, 05:28 PM   #30
nightflyr
Default And the wait is over!!!! RELEASE THE KRACKIN>>>>>
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-13-2010, 05:46 PM   #31
pril250
Well, well, well worth the wait
Blade400
Old 08-13-2010, 05:47 PM   #32
rojack
It's a MONSTER!!! Run for the hills!!!!
rojack is offline        Reply With Quote
Old 08-13-2010, 05:57 PM   #33
Bri
Holy Frijole.....
Brian
JR X9503 /
Spektrum DX7
Phoenix Sim
Old 08-13-2010, 06:04 PM   #34
nightflyr
Still need to get the HS dialed in, but it LIVES!!!!!
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-13-2010, 06:42 PM   #35
pril250
Night, sorry to lumber you with more work, it is about time to do a revised photo of all your Airforce as it stands
Blade400
Old 08-13-2010, 06:48 PM   #36
nightflyr
Well that last group photo took almost an hour between getting the fleet out side and fitting them across the drive way..
But you are correct the family portrait needs an update
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-13-2010, 11:02 PM   #37
Navigator53
Awesome Buddy
At .52 in the video, it sucked a branch clean off the tree
Then blew it away!
Old 08-13-2010, 11:58 PM   #38
Stumblebee
Night, as usual you have lived up and surpassed all expectations. Like I said earlier, "Can't touch this..."
Old 08-14-2010, 05:37 AM   #39
nightflyr
Thanks all...
Though now after getting a couple of flights in now...I can see I'll need to replace the motor and ESC..
The NEU 1920 though is 510 kV wasn't meant to swing a rotor dish this big...
Going to order a Scorpion 5020-450 series motor to use,
and the ICE80HV is getting up to 180 degrees, I can relocate the ESC and install a cooling fan, but I think the ICE120HV should do the trick.
I'll be ordering the new parts this week.
But the laboratory isn't quite done yet......
I have another project on the design table and this one is insane even in my creatively confused mind....
In short,
I've done a few scale projects and thought they were fun, but never really prove to be anything more than standard helicopter mechanics stuffed in a fiberglass shell...
So I thought (which is a frightening thing) what if.....
I were to take this.....
Airwolf
60-90 size RC Helicopter Scale Fuselage
Part# CN4029A
Install the mechanics of a 600 ESP flybarless on 10S..
Ok now your thinking nice but it's still just a fancy and very large scaler..this is true, but the tricked out part is to have it with twin 70MM or larger electric ducted fan jets.
A true jet powered hybrid helicopter,
The concept has been tried, but just for appearance and effect on a 500 scale build. Which was very nicely done.
The EDF units that were use do not provide enough thrust to move the helicopter.
My thought is to flip a switch in a hover and have the bird rocket itself.
I've been working on the designs for about 6 months on and off, but this will be the most costly project to date.
So far...
Scale fuse.....................$700.00
600ESP mechanics .......$700.00
Dual EDF units..............$400.00
Triple ESC's..................$700.00
11+ ch Tx/Rx................$800.00 +
Vbar.............................$490.00
Or HC RIGID.................$550.00
Misc parts....................$800.00
This one is for real folks, at this cost failure in not an option, and if it works, it will be the mother of all helicopters
Assorted
Mix Fixed Wing.
AMA # 972083
Old 08-14-2010, 08:09 AM   #40
pril250
All these sleepless nights are affecting your sanity man It is big bucks and you don't even get a gas turbine but EDF is good if the required thrust will be there.......Now if that is what you fancy......that will be what we fancy
My favourite fuses are the monstrous looking gunships like the Hind CH-53, Cobra, AH-64 Longbow and such like rather than the smooth looking Bell 222 Air Wolf but hey this is me
Blade400
