Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 08-29-2010, 11:41 AM   #1
AzChopp3r
Default New (to me) Raptor 90SE
Hi folks, Im new to the Raptor forum and have a 90SE on its way from a member of this site.
I have a few questions:
Has somebody made a test stand for a heli this size. Its easy to tune a plane while someone holds it but how do you tune a heli engine before flight? This has a OS91 engine. I think a heavy stand will enable engine testing as well as control. It would have to be high enough so that main blades are above head height. And stable enough not to topple over. Just curious if this is feasible, stupid or whatever.
I bought radix 710mm CF blades for it and a Co-Pilot II system that I may need a hand on the install and setup. If I do I will make a new post in flight stabilization.
This will be my first nitro bird and any other tips and suggestions would be great. I do have some raptor buddies that can help me out locally here as well.
SR120, MCX2, Trex500 CF, Blade 400 ,Trex450XL, Outrage 550. Raptor 30 V2 OS37
Raptor 90SE, OS91 Max SZH (sick heli)
AMA# 950209 White Mountain Bald Eagle Squadron
Jesus is Lord Happy Flying
AzChopp3r is offline        Reply With Quote
Old 08-30-2010, 08:43 AM   #2
nocontrol1
Test stand= bad idea. Get local help for tuning and initial setup if possible. Nitros aren't brain surgery, but there are a few things you will need to learn. Local help can save you a ton of headaches and a bunch of time.
Rob D
nocontrol1 is offline        Reply With Quote
Old 09-02-2010, 01:36 AM   #3
AzChopp3r
Flew the raptor for the first time today. The heli needed 19 click rear elev and 6 clicks right aile trim to hover. So something is off and wondering what I might need to look at first. With so much rearward trim this eliminates alot of further rearward movement by the stick normally. Nothing added to the nose to make it so nose heavy. Ill check CG tomorrow morning as soon as I can but I cant imagine anything wrong here as there is only the RX lipo, RX, speed control mounted on the nose. Blades were tracking nicely.
Old 09-03-2010, 12:34 PM   #4
seanh
were you trimming with a full tank? if so, try half tank.
what engine and muffler are you using?
what size is the rx pack?
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote
Old 09-03-2010, 09:52 PM   #5
AzChopp3r
Th CG is perfect.
I pulled down the head and leveled the swash perfect. Then went up from there. all mixer arms lined up and main blades zeroed out at 50% throttle with elev/aile centered. I did see that a paddle was just a bit off and towards positive pitch which would cause the heli to nose-forward. I adjusted that and will see tomorrow morning how it goes.
As for the setup it has now it couldnt be better.
