I have installed my 3026-1210 Scorpion motor in a Trex 500. The motor was bought brand new and has never been used. I am running a Castle ICE controller. I have set it up to operate this motor and double checked my setup. When I try to run the motor, I only receive a chatter from the motor and it wont turn. Any advice for me?
I am running the heli on 8s and it makes the same noise on 4s.
Brian |
Did you set your Throttle limits before you set up your ESC ? Was the ESC working before you put this motor in ?? Swap any 2 motor wires and see what it does. Doesn't matter what 2 ;just swap 2 and try that.
Blade 130X : Bilnged out with Lynx & Microheli Metal ./ Batteries : Zippy Compact 500mAH / Glacier 450mAh /Eflight 300mAh iCharger 206B, P.S 350 power supply. Spin 8000kv motor. |
I did try reversing two wires last night. The motor actually ran backward. I also tried increasing my softstart, but that didn't help. I have another esc. I'll see if I can hook that up
The esc was new. By setting throttle limits, do you mean plugging the pack in while the stick is at half and then reducing it to zero? I am running futaba and did reverse the throttle
Brian |
See Finless Bob's part 1 video on this link:
http://www.helifreak.com/showthread.php?t=36194 |
I ended up getting the motor to turn. It was apparently just really tight. It works now. I pulled the pinion back from the main gear and helped it get started a few times and oiled it some. It works fine now.
Brian |
#6 |
The Castle you can set motor start power... Could be that with the lower KV you needed to turn that setting up 20%
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 | |
Trex 450 Pro Stretch Neu Scorp 1630, 8s, CC30HV. Mini V Trex 700 DFC V-bar |
#8 |
so how does the 1210 do on 8s? scorpion site shows it as a 6s motor. just curious as i am about to try this.
-trex700n -trex600n -trex500 -trex450 -trex250 ...blade mcx...best cat toy so far. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ...& Aurora9 |
