Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G3
4G3 Walkera 4G3 Helicopter Support
Old 09-03-2010, 01:14 PM   #1
RaymondJ
Default Set up pics?
Been looking around for pics of guys' 4g3's.
I've done the double BL conversion, but I'm having a hell of a time trying to fit the two escs in a nice fasion. No matter how I tape everything in there, it looks like crap.
I'm just curious how you guys have squeezed everything under the canopy.
RaymondJ is offline        Reply With Quote
Old 09-16-2010, 11:13 AM   #2
pitchp
choose one.
ID:	180444   Click image for larger version
ID:	180445   Click image for larger version
ID:	180446   Click image for larger version
ID:	180447   Click image for larger version
pitchp is offline        Reply With Quote
Old 09-16-2010, 01:19 PM   #3
RaymondJ
What skids are those on the one heli? Looks agressive, I like it. How much do they weigh if you know?
Old 09-16-2010, 08:20 PM   #4
pitchp
It's from the FF EP200. It has helped me so much on my landings, I use to land to hard, so these were more ideal, also when I fly it in small spaces like my living room, it is more docile + the flybar weights. I use the other one for outdoor use. I'm still trying to get the right Emix and Pmix and DR settings, to get this bird more stable. Dialing this bird is not that easy, but once I figure it out, I'm sure it will be easy then. However It would be nice to know if someone actually got their stock 4g3 dialed in solid and stable. I would love to see their Pmix,Expo,P&T Curves, and DR settings. I know a few people has it, they just don't want to share it.
Weight: 5 grams You can make it less by trimming the skids, but I didn't think about it back then, so may be if you trim it, about 3-4 grams.
P.S I put on the EP200 Flybar Paddles, and it slowed this little animal to almost like a Blade MCX. It's SUperkool!
ID:	180546   Click image for larger version
Name:	EP200 Paddles.jpg
Old 01-21-2011, 01:40 PM   #5
jlcoolio70
how slow dit it make the heli with the paddles? and can you show a better pic of the bottom for me to see how you mounted them skids..er landing gear
*sorry for the double post..I thought I had deleated the first one wont happen again my keyboard is junk*
jlcoolio70 is offline        Reply With Quote
Old 01-21-2011, 01:56 PM   #6
jlcoolio70
really like the mod's just want to know how much did the fly bar paddles take away from the speed.do you think it took the 3d flight capabilities away from the helli.and the landing gear what mods did you do to make them fit any way to get a better pic of the bottom..i have both the novus cp and the 4g3 and want to set mine up the same one outdoor and one in
Old 02-12-2011, 05:55 AM   #7
pitchp
Just how deep does the rabbit hole go?
Old 02-28-2011, 08:03 PM   #8
CrashmanEd
Here's how I did it on my HeliMax Novus CP. WOW Hobbies upgrades:
Fusion 50 w/ Quantum 4125-560 motor, AR7200BX, Kontronik Jive 80+ HV, Torq servos, Radix 600FBL blades, Radix tail; Align 450 Pro DFC stock, except for AR7200BX.
CrashmanEd is offline        Reply With Quote
Old 03-07-2011, 04:06 PM   #9
Steven87
I chopped mine up to reduce weight and get it to fit properly (Buzzfly 3D is just a rebranded 4G3). With the reduced weight the canopy is required for it to balance properly and it flies great (definately made a difference to the throttle response).
I explained it all in this thread: http://www.helifreak.com/showthread....07#post1561207
Steven87 is offline        Reply With Quote
