Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 09-14-2010, 09:09 AM   #1
seanh
Default SE blade grip...what balde thickness can I use?
Does anyone know what the gap is on the metal SE blade grips? What I'm trying to find out is if I'm limited on blade choice if the grips are made for 12mm blades. I don't have a set of these but am considering getting a pair if I can use the 14mm blades.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote
Old 09-14-2010, 10:04 AM   #2
AzChopp3r
I bought the radix 710mm blades and they are excellant.
their specs:
Root Details
Root: 12mm
Washers included for: 14mm, 16mm, 18mm
Bolt Hole: 5mm
Sleeve inclued for: 4mm bolt
Now I have an SE with metal grips and these blades fit without shims/washers or sleeves.
SR120, MCX2, Trex500 CF, Blade 400 ,Trex450XL, Outrage 550. Raptor 30 V2 OS37
Raptor 90SE, OS91 Max SZH (sick heli)
AMA# 950209 White Mountain Bald Eagle Squadron
Jesus is Lord Happy Flying
AzChopp3r is offline        Reply With Quote
Old 09-14-2010, 11:51 AM   #3
maizor
I know some one is using the Plastic blade grips on larger roots then 12mm with luck. But metal grips are limited to 12mm
JR Sylphide EX with Super Gracy
JR Sylphide with MB391
TDR jive120 4530-540 scorpion CGY750
Mikado Logo 600SE V-bar
maizor is offline        Reply With Quote
