| 600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support |
I'm building a scale bird and could really benefit from a longer main shaft for my 4 bladed head to clear the fuse. I have the CF with the third bearing now. Does anyone know of a longer main shaft? Or perhaps another brand shaft that is still 10mm diameter that might work?
Thanks!
All scale all the way. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Have you tried a 600N shaft yet?
#3 |
I looked it up and it's about 10 mm longer, but not sure if it fits at the bottom in the main gear the same way. Does the N have three bearing blocks?
Thanks!
#4 |
Yes, a 600N has a third bearing block on the bottom. The extra 10mm may be used for the third bearing block on the bottom, so it may not help you there. I may have one laying around in my room. I'll take a look at it tonight whenever I get home.
#5 |
Thanks, I fitted the mechanics in the fuse last night and think it will work...barely. I appreciate the help though!
#6 |
I don't have an 600ESP main shaft, but I found a 600N and 600EFL main shafts. the 600N is longer than the 600EFL on the bottom which is used to fit a third bearing block. However, it is also longer than the 600EFL on the top. I'm sorry that I cannot find any 600ESP around my house. I sold them all. Please see the picture for more detail.
#7 | |
#8 |
What version 600 is this going on? The original 600 uses the third bearing block too, but the extra length is on the bottom and not the top. The DFC shaft is shorter than the standard E or ESP main shaft.
Trex 450 Pro - AR7200BX / Trex 500 - beastx / Trex 600E Ikon |
