Old 10-11-2010, 01:05 PM   #1
Leon Luke
Default Modifying 3G for better performance
Hi,
I have been testing a mod to the 3G, that will help some of those that are having issues with the system. I've been flying it for a while now to test and confirm my findings before making any comments. I have forwarded my findings to Assurance and Taiwan. Not everyone is having issues or concerns as evidenced by so many of the factory pilots, and local pilots I speak to are not having any issues. I was not having any issues, but wanted to go the extra step to make things even better, continual developement. I find that most of the issues are vibration induced as the sensors are very sensitive.
If you want to try this mod, do it at your own risk, as it may void any warranty, I don't know.
The mod involves taking the sensor appart by the 4 screws on the bottom. Lift the top off of the base and carefully remove the the sensors from the top of case. Use some silicone, I used high temp silicone, as it was the only kind I have, I have just been told to use electronics silicone as it is non corrosive, and apply a gob to secure all 3 sensor units to each other. Do not put too much on. You do not want the glue to touch too much of the sensor case, this way the case transmits less vibration to the sensors. I did not put any silicone between the bottom of the rudder sensor and the square plastic base of case.
You should find that the heli is much less "nervous", less tail artifacts, you will be able to turn all your gains up,
Your heli will be much more solid.
You must minimize vibrations, and use FBL blades.
You will note from my settings below, the gains are about 100% now, and rudder is at 85-90%
Leon Luke
Team A Main Hobbies, KDE, Cool Power, Hatori, Thunderpower, YS
XFC 2006/7/8/11
Leon Luke is offline        Reply With Quote
Old 10-11-2010, 07:59 PM   #2
jondabear
No faster said than done.
jondabear is offline        Reply With Quote
Old 10-11-2010, 08:17 PM   #3
mikejr718
Can we see pictures of a modified sensor to understand better?
mikejr718 is offline        Reply With Quote
Old 10-11-2010, 09:42 PM   #4
Leon Luke
I should know better, but I did not take pictures, sorry. I have it on 5 machines.
XFC 2006/7/8/11
Old 10-11-2010, 09:59 PM   #5
mikejr718
I have seen pics of the inside of the 3g sensor from another thread. I have tried to attach a copy of the pic. Thanks to tgilton for the original pic. I have outlined an area that I believe you are referring to. [IMG]file:///C:/Users/Owner/Desktop/3G_PINS2.jpg[/IMG][IMG]file:///C:/Users/Owner/Desktop/3G_PINS2.jpg[/IMG]
Old 10-11-2010, 10:09 PM   #6
Leon Luke
I put a glob of silicone, and shaped it like a cube to touch all 3 sensors, the dimensions of this cube of silicone was a little larger than the dimensions of the actual sensors on the 3 boards. The glue encapsulated the sensors and parts of the boards. I just made sure that I did not put so much that the glue would squeeze out when I put the top of the case on. I am sure the glue contacted the 2 locating tabs on the top of the case.
XFC 2006/7/8/11
Old 10-11-2010, 10:14 PM   #7
mikejr718
I am going to try this tomorrow. I have Hondabond hi temp silicone sealer and also some shoo goo. Would either of these be ok?
Old 10-12-2010, 12:04 AM   #8
Vinger
Silicone sealants/glue normally produce an accidic reaction and are corrosive to the electronic tracks and copper components. Better to use some specialised silicon glue that are made for electronic use.
http://www.mgchemicals.com/products/...ronic_app.html
TSE399-C Clear, one part, neutral cure, non-corrosive, flowable, RTV silicone sealant for electronics applications with primerless adhesion to most metals and plastics.
http://www.dowcorning.com/content/et.../etronicsseal/
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC
Hyperion 1420, Mega Power Gemini Chargers! JR XG11
Old hand at Planks
Vinger is online now        Reply With Quote
Old 10-12-2010, 12:34 AM   #9
Leon Luke
Default 3G
Good to know.
XFC 2006/7/8/11
Old 10-12-2010, 02:05 AM   #10
jondabear
I completely forgot all about that. Wow....now there's a blast from the past. Noncorrosive rtv's for base level board work and adhesion. Haven't had to use that in a very long time.
I DO concur though. Noncorrosive would be preferable. Not a must. As the actual corrosive effects would probably show themselves AFTER this tech is obsolete but, I rather have pice of mind. To ELECTROTEX I go! Peace!
Old 10-12-2010, 08:54 AM   #11
Wizzard
Not sure about the cover from your 3G unit Leon but mine had 2 little tabs inside that had to be removed in order to allow the silicone to connect all 3 sensors together. The tabs appeared that they are/were some kind of support for the 2 upright sensors?
Align 450Pro FBL, BeastX
Blade 500X
Blade 550X Pro
Spektrum DX8
Proudly Sponsored by "MasterCard"
Wizzard is offline        Reply With Quote
Old 10-12-2010, 09:31 AM   #12
Leon Luke
Yes, the tabs were in mine too.
XFC 2006/7/8/11
Old 10-12-2010, 10:16 AM   #13
uragano47812
Hello Leon great work! Can you post also some pics of the software parameters you have used in your 450 flybarless?
i'm asking this because a friend has the 3G on a 450PRO and we want to try your "silicone" mod but we don't know how to fine tune the parameters.
thanks
Compass 7HV - Vstabi 5.3Pro
Trex 600 EFL Pro - MiniVstabi 5.3Pro
MiniProtos 3s - MSH Brain
uragano47812 is offline        Reply With Quote
Old 10-12-2010, 10:46 AM   #14
jockstrap
What about using hot melt glue? Too hot? Too runny? Too stiff when hard?
Just an idea..as it's non-corrosive..
DX7 Mode-1 | T-Rex 250 | EP200SE V2 | Tricopter | Quadcopter
450 pro 6s fbl 3X1000 | 450 pro fbl beastx | Schweizer 300C Gasser Scale |T-Rex550e 600 vbar | Aeolus 50
HeliX T-Rex700 fbl Gasser | HWC600 321puh Gasser fbl| Henseleit TDR
jockstrap is offline        Reply With Quote
Old 10-12-2010, 11:04 AM   #15
ForceFedDSM
What about shoo goo?
ForceFedDSM is offline        Reply With Quote
Old 10-12-2010, 12:31 PM   #16
Felt
I'm getting 90 gain on aileron and 85 gain on elevator on my 600n without this mod. I also set my tail up using 100% 100% on the gain channel and setting my rudder total adjustment to 34% in the software. My 3g is working great. I guess I'm one of the lucky ones.
Felt is offline        Reply With Quote
Old 10-12-2010, 12:33 PM   #17
Felt
I also forgot to mention. I am using Edge 603 Flybarless blades.
Old 10-12-2010, 08:46 PM   #18
mickeyjohnston
I did this mod last night to my 450. I would say it made some improvement. The tail felt better as well. Zero wag. I also took Leon's advice and turn up my swash return speed to 70 and the heli felt a lot better. It felt more locked in. I was previously running it at 30.
BTW I used shoe goo. It's harder than silicone. Personally I don't see an issue with silicone, in 3 yrs from now, we'll all be running a different system.
mickeyjohnston is offline        Reply With Quote
Old 10-12-2010, 11:28 PM   #19
tgilton
I think this is a dandy idea! It basically increases the mass of each of the three sensors and eliminates some of the vibrational modes by coupling them into a new shape. I don't like the way they cantilever the little boards out there to vibrate like saxophone reeds. I will be doing a version of this tomorrow using sticky clay instead of RTV.
Compass 6HV (Beastx, JR8717/Futaba BLS251)
Atom 550 (mini-VBar, Savox)
Trex 450 (BeastX, MKS DS92s/DS95i)
Trex 250 (3gx 410/MKS DS95i)
tgilton is offline        Reply With Quote
Old 10-12-2010, 11:44 PM   #20
akamullen
Please take pics or video of your mod. I am curious to see how your version goes..
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 500/630/770 * TREX 500DFC / 450DFC@6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all
akamullen is offline        Reply With Quote
