Old 10-14-2010, 08:28 PM   #41
jondabear
Out of all the REGULAR stuff that i could pick from, Id say GOOP adhesive is about the closest thing to what Im using. PEACE!( goop is Denser, heavier and dries a little more firmly than silly cones!)
jondabear is offline        Reply With Quote
Old 10-14-2010, 08:41 PM   #42
ForceFedDSM
I can't wait to try my heli now. I modded my 250 already and I did the LHS owners 700 tonight. We have some bad weather the next few days...so it might be a bit before I get to try it
ForceFedDSM is offline        Reply With Quote
Old 10-14-2010, 08:56 PM   #43
mickeyjohnston
Originally Posted by jondabear View Post
No pics or vid YET.
BUT..............Holy son of a CRA%!
This mod is AMAZING on my 700. Didnt change a thing!
Heres a quick run down, Feels MORE locked in, ALOT more locked in. Helped with Cyclic movements. I make an input and....its THERE!.
Even helped with my PITCH. Thought I was just runnung a rich motor and didnt have alot of punch. With this mod AND my heli running 180 f i now have morre punch out than ive ever experienced.
THIS might be our holy grail guys!
Weird what a good sensor will do when its not fighting vibes!
VERY VERY happy with my results. wish I had tried this a LONG time ago. PEACE!:YeaBaby :
If you havent already try turning up your swash return speed to 70.
mickeyjohnston is offline        Reply With Quote
Old 10-14-2010, 09:13 PM   #44
mikejr718
Flew my velocity with the 3g some more tonite and am still thrilled about how much better it flies.. Its not just a little better, its game changing better!
I took apart the sensor on my 700e tonite to mod it and found it already had some adhesive behind the pins? It was spread across to the sensor mounted flat on the board. Makes me wonder if this hasnt been in the works for a while.
mikejr718 is offline        Reply With Quote
Old 10-14-2010, 09:46 PM   #45
salmonson63
Getting ready to do this. Do I need silicon or will shoe goo work or either.
Team RC Heli Nation / Team Compass / Team Scorpion / Team Gens Ace
7HV, Warp 360, N5c
salmonson63 is offline        Reply With Quote
Old 10-14-2010, 09:53 PM   #46
jondabear
goop.
Old 10-14-2010, 09:54 PM   #47
jondabear
Swash return is at 55.
Old 10-14-2010, 10:28 PM   #48
Leon Luke
Default modded
No pics or vid YET.
Glad to see another satisfied with the mod!
Team A Main Hobbies, KDE, Cool Power, Hatori, Thunderpower, YS
XFC 2006/7/8/11
Leon Luke is offline        Reply With Quote
Old 10-14-2010, 10:31 PM   #49
HiroboFreak
Hmmmmm,
Should I or shouldn't I?
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro
| JR DSX9 Limited
Team RCBits | Team Lynx
HiroboFreak is offline        Reply With Quote
Old 10-14-2010, 10:54 PM   #50
zoomtt
I am doing this mod once I go pickup some goop. Overnight is enough time to dry?
Edsel Labao
TEAM HORIZON HOBBY
Blade Helicopters - Spektrum - Revolution
zoomtt is online now        Reply With Quote
Old 10-14-2010, 11:10 PM   #51
daveblazer
well took the plunge in to this mod took some pictures and will have results tommarow on a 450 pro cleaning that conector out was fun the tooth pick man is gunna like me this month this thing feels a lot heaver now lot's of mass well that's all for this experiment till we try it
ID:	184991   Click image for larger version
ID:	184992   Click image for larger version
ID:	184993   Click image for larger version
ID:	184994   Click image for larger version
ID:	184996   Click image for larger version
ID:	184997   Click image for larger version
ID:	184998   Click image for larger version
ID:	184999   Click image for larger version
ID:	185001   Click image for larger version
daveblazer is offline        Reply With Quote
Old 10-14-2010, 11:12 PM   #52
simonf123
Originally Posted by Corrari View Post
Does it have to be a certain type of silicon? I am a plumber and have roof and gutter silicon and bathroom silicon on hand.
you need silicone that is non corrosive, neutral cure
Trex 250 ESP | Trex 450 V2 | Trex 500 ESP Stock & Spartan 760 | Trex 500 Align 3G FBL & Scorpion | JR 11X | Phoenix Sim
simonf123 is offline        Reply With Quote
Old 10-14-2010, 11:27 PM   #53
jondabear
Neutral cure...Is that noncorrosive? Ive seen that stuff when I looked for this e6000 at the electronics store. Didnt know what it was for.
Old 10-14-2010, 11:35 PM   #54
jondabear
DO IT HIROBO.....its what weve been after for soo long.....well , at least most of it.
I still believe that ALL the answers to my 3D questions are at the bottom of a 300 gallon vat of NITRO fuel. PEACE!
Old 10-14-2010, 11:44 PM   #55
HiroboFreak
Mine are performing well, but I'm keen to see what you're so excited about Jon.
I've just modded both my 700n & 550e.
I've removed the tabs on the case too as I feel they would most likely transmit vibes.
In the process I found something interesting....
My 700n sensor was originally V1 before I flashed it to V2.1, my 550e sensor is factory V2.1
The cyclic sensors on the 550e have metal attenuation plates attached, the 700n cyclic sensors don't.
This shows that Align are listening, and, V2.1 is more than just a firmware upgrade.
| JR DSX9 Limited
Old 10-14-2010, 11:57 PM   #56
akamullen
In the process I found something intereting....
VERY INTERESTING INDEED!! So by doing this mod were extending the vibration attenuation plates so they are MUCH heavier and have more mass..... I also agree about the 2 tabs transmitting vibs, Thats the first thing I thought of when I took it apart. Got rid of mine as well. Insted of Glue or silicone I went with a gel tape fitted in-between the sensors. Cut it into a cube and seems to work. The gel tape I am using is the K10457A Align PU Adhesive Gel
Same principle different material. I used the blue align gel tape. cut it so there is a tiny bit of pressure when I put the case back togather, holding the sensors and gel tape in place. I have a couple more sensors to do so I will take photos when I do another one. Made my 250 fly WAY better... cant wait to test on my other machines...
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 500/630/770 * TREX 500DFC / 450DFC@6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all
akamullen is offline        Reply With Quote
Old 10-15-2010, 07:44 AM   #57
Canadian Man
Well my report:
This mod is a night and day difference.! My tail wag is gone. No bobbing. I copied leon's settings from the screen except my aile and elev gains were not as high of a final number.
the heli feels more locked in. A bit more soft feeling. Fly's kinda more like a flybar heli but has the locked in part of a flybar less system.
GREAT MOD!
Trex 700
velocity 50
trex 450
Canadian Man is offline        Reply With Quote
Old 10-15-2010, 11:18 AM   #58
mikejr718
Finished the mod on my 700e 3g last nite and flew it this am. It took less than 15 min including reprogramming the 3g unit. Found the same drastic improvement. If you have flown the 3g and dont like it or have taken it off I encourage you to give it another chance, the improvement is that drastic. On my 700e I can now do tic tocs where the heli stays stationary and it just rocks back and forth like its pivoting on a point close to the main shaft-really cool. No tail kicks at all(I always thought they were vibration related)
I hope anyone comparing flybarless systems does this mod before they compare systems. It makes that much of a difference.
I also think that the sensitivity to what tape is used and how the sensor is mounted are related to vibration entering the unit. The whole tape issue was a symptom of the problem, not a real solution-just a band-aid. Time will tell but I think with this mod that how the sensor is mounted will become much less critical.
THANK YOU LEON FOR SHARING THIS MOD.
Old 10-15-2010, 11:49 AM   #59
jondabear
Dont know about everyone else but.... i think this thread should be a STICKY!
How bout it mods? This mod has changed our 3g experience entirely. VERY few things have ever done this with our systems.
Thanx.PEACE!
Old 10-15-2010, 11:51 AM   #60
jondabear
Speaking about tapes and such....Im about to REMOVE the plate and go with just a single piece of 4010 w no strap. Ill report back later.
