Old 04-19-2011, 07:04 AM   #101
spikestabber
Blue antenna is for the TM1000 telemetry unit.
Eagle Tree RPM sensor sends its signal to both the SK720 and TM1000.
The little microswitch in the top left of the first picture is to workaround the SK720/Ice50 cold start bug some people have with certain models of SK720 units. It also serves as a reset switch to reset the SK720 without having to disconnect the battery. Its rated for 5 amps at 120VAC, more than enough for the 5A at 6V the Ice 50 puts out.
ID:	222780   Click image for larger version
ID:	222781   Click image for larger version
T-REX 450Pro DFC, SK-720, CC Lite 50, TM1000, KDE 450XF, MKS DS95's, Futaba BLS-257, KDE, DX8
T-REX 700Ev3 DFC, SK-720, CC 160HV, TM1000, KDE 700XF, Outrage BL9180's/BL9188, KDE, DX8
spikestabber is offline        Reply With Quote
Old 04-22-2011, 11:40 AM   #102
pas2knut
Here is my T-Rex 450 Sport with Micorbeast wiring.
Gaui X5/AR7200BX
Nano CP X BL
pas2knut is offline        Reply With Quote
Old 04-22-2011, 02:18 PM   #103
UJSTIN
Default 6s FBL Trex 450 Sport
It took awhile but It's finished!
Ive been flying this beast for about 2 weeks now. It's worth the money if your into helis like that...
Name:	6s FBL 450S.jpg
ID:	223535   Click image for larger version
ID:	223539   Click image for larger version
Name:	Align FBL Head.jpg
ID:	223540   Click image for larger version
ID:	223541   Click image for larger version
Name:	Tail Match.jpg
Name:	Main Shaft for Perfect CoG.jpg
ID:	223543   Click image for larger version
Name:	Scorpion 2010kv  6s brushless motor.jpg
ID:	223544   Click image for larger version
Name:	CC Ice 50.jpg
ID:	223545   Click image for larger version
ID:	223546   Click image for larger version
Name:	Spectrum telemetry unit.jpg
ID:	223548   Click image for larger version
ID:	223549   Click image for larger version
Name:	Micro Beast (Brains).jpg
ID:	223550   Click image for larger version
ID:	223551   Click image for larger version
Name:	Hitec 4x Charger.jpg
Align: 6s FBL Trex450 Sport (a lot to say)
E-flight: MCX 1 & 2, MSR, SR, SR120, MCP X
UJSTIN is offline        Reply With Quote
Old 04-22-2011, 02:59 PM   #104
lazor 22
6s? Nice
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies
7HV, Warp, 3D+
Lincoln
lazor 22 is online now        Reply With Quote
Old 04-22-2011, 03:24 PM   #105
UJSTIN
It's a "High voltage unbogable rocket on crack" it feels like its always in idle up.
1300mah NRG lipos x4
CC Ice 50
CC 10 amp BEC
Scorpion 2010 kv motor.
I have the gov'na (lol) on set RPM
3000 rpm
3100 rpm
3200 rpm
I get 5 min of sports flight and some sloppy piro flips. The telementy tells me when the voltage is low it gives me 1 minute heads up to land.
Old 04-22-2011, 03:27 PM   #106
lazor 22
Get that thing up to 3800rpm's
7HV, Warp, 3D+
Lincoln
Old 04-22-2011, 03:35 PM   #107
UJSTIN
I was thinking about it, but there's a point of efficiency over power its kind of a balance you have to find. 3300rpm really makes the collective really smooth or it might be the MicroBeast. lol
Old 04-22-2011, 03:50 PM   #108
lazor 22
7HV, Warp, 3D+
Lincoln
Old 04-22-2011, 05:21 PM   #109
UJSTIN
I wouldn't want to get hit or see a blade fly off at 4000rpm that but hey you only live once...I wonder how many watts are being pulled contentiously to hold that rpm.
Old 04-22-2011, 10:29 PM   #110
daddoo
Here's the wiring of my newly build 450 Pro.
ID:	223645   Click image for larger version
ID:	223646   Click image for larger version
daddoo is offline        Reply With Quote
Old 04-25-2011, 12:10 AM   #111
kevinbattista
just finished it , maiden today
http://helifreak.com/album.php?u=103444
it's not a competition, it's a hobby
EXI 450 + FUTABA t7c Tx =
Phoenix Sim "it's free to crash on a sim"
kevinbattista is offline        Reply With Quote
Old 04-27-2011, 03:12 PM   #112
halcyon32
Default My first build
Just finish with my first build. I would love feed back on the wiring.
Photo Album
http://helifreak.com/album.php?albumid=6960
halcyon32 is offline        Reply With Quote
Old 04-27-2011, 07:04 PM   #113
DewFuss
Default OK here's my 450 Sport...
Be kind.... it's my first build.
Any constructive criticism is welcome.
General view left side:
General view right side:
Tail View:
Close up of gyro plate left:
Bottom ESC View:
Tailblock view:
Inside Frame view:
Underside gyro plate view:
Close up right side view:
Thank You for your time.
May all your flights be good ones.
DewFuss
DewFuss is offline        Reply With Quote
Old 04-27-2011, 07:11 PM   #114
Steve Evans
Check out post 21 in this thread, especially for the ESC wiring.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 04-27-2011, 07:20 PM   #115
DewFuss
Steve
Thanks Steve, I wish mine was that nice... But the 450 Sport frame doesn't allow the mounting of the ESC in the same location as seen in yours. Also my motor wires come out the top of the Align 450M that came with the super combo kit.
I definately didn't post mine to brag but someone wished to see it so I posted them up.
If you see anything dangerous in my wiring please let me know.
DewFuss
Old 04-27-2011, 07:33 PM   #116
rdlohr
In a number of these posts, I see a lot of hard work, but some of the basic best practices have not been followed:
In general it is good practice to physically isolate your high current components (battery,ESC, Motor) and related wiring from the low current components (receiver, gyro, antennas) and wiring. The three ESC to motor wires in particular generate lots of electrical noise. Todays receivers are more immune to interference, but if you have glitches, consider shifting the high current stuff to the front more and remember this guideline when running wires.
Gyros on top the boom block are at risk of a flybar strike. Tail servos on the right side of the boom are at risk as well. Any wires going under skids are at risk when you rip your skids off in a crash.
Hope this helps. Happy flying!
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
rdlohr is online now        Reply With Quote
Old 04-27-2011, 07:54 PM   #117
DewFuss
Rick
I'm guessing that was a general statement... But If you see anything I did that doesn't follow the best practices... Please let me know. I followed best practices as I understand them but I'm always willing to learn more.
DewFuss
Old 04-27-2011, 08:29 PM   #118
rdlohr
Yes, I was being general. I've seen a lot of posts go by that I wanted to say something, but people are so proud of their babies that I've held my tongue. I remember how I felt about my first build. Then this guy named Finless saw my pictures and said EEEEEK.
If you have glitching, your ESC wires are closer to your receiver than I would allow. If it works flawlessly, I guess your electronics can handle it.
Rick
Old 04-28-2011, 02:00 AM   #119
Steve Evans
I must admit I'd not realised how short the bottom plate is on a sport compared to an SEv2! Looking at the basic layout I'd be inclined to put the ESC under the battery tray as that would allow for easy wiring to the motor, ease of disconnection of the motor wiring for safe setup, and keeps the power wiring well away from the rx/servo cabling. How's the balance? The ESC is the heaviest component that can easily be moved to affect CoG.
How stiff is the rx tray on a sport? On a 500 it's generally considered too flimsy to use as a gyro mount, especially on the overhang. Can the gyro be mounted under the boom block on a sport as can be done on the earlier models?
Steve
Futaba 8FG 2.4GHz
Old 04-28-2011, 02:52 AM   #120
DewFuss
Steve
The balance is spot-on currently.
The battery tray is also a bit short. Over 1/3 of the battery hangs off the end of it. The ESC would also hang out past the end of the tray, where I don't believe it to be the safest mounting location incase of a nose first strike. The motor is right behind the batter tray. I've mounted the Gyro per the manual.
The Gyro tray, not RX tray, is plenty stiff. The 450 Sport owner's manual doesn't even mention the RX or suggest a place to put it. It does reccommend 2 locations for the ESC. One of which is where I placed it. The other location is roughly the same location but on the lower side of the frame just under the main gear.
Mounting the RX on the underside of the Gyro tray is the only place, short of mounting above the tailblock where it is in danger of a blade strike, and still keep the manual reccommended 3cm distance between the RX and the ESC that I could find.
I'm not real sure what align was thinking when they designed the frame layout.
DewFuss
