Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Multiplex FunCopter
Multiplex FunCopter Multiplex FunCopter Helicopters
Old 11-27-2010, 09:20 PM   #1
AtTheCross
Default Funcopter Upgrade: Tail Pitch Slider
ok, happened twice to me, the push rod hook popped out of the pitch slider. Fortunately I was doing some other testing so I had very little altitude so no crash damage.
Here’s my solution: add a ball to the slider and a ball link to the push rod. I used the stock push rod and one of the extra links. Used thread to bind it and sealed the thread with CA.
Name:	pitch slider.jpg
1 Corinthians 1:18 For the message of the cross is foolishness to those who are perishing, but to us who are being saved it is the power of God.
AtTheCross is offline        Reply With Quote
Old 11-28-2010, 03:27 PM   #2
TomC
This is a very good idea and it will help reduce a little slop in the FC tail system, which is already very sloppy.
If you are using the FC boom and tail pushrod guides (which you are not using) I don't think that this mod is necessary. Just to be on the safe side though, I used a Dubro E/Z link for 0.072" pushrods to secure it. These cost ~$0.35 each and take ~ 10 seconds to install.
Thanks for the heads up mate!
You can get these at most hobby shops, for example at;
http://www.allerc.com/dubro-e-z-link...roducts_id=225
Cheers,
TomC
Name:	Dubro ez link.jpg
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, HC3-SX
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote
Old 12-28-2010, 01:32 AM   #3
tengarang
Default speaking of Tail on the FV
Hey Fellers,
I been dying to find out the updated place to get my paws on the belt drive mod for the FC.
Any ideas?
better off with or with out it?
T.
tengarang is offline        Reply With Quote
Old 12-28-2010, 04:07 PM   #4
TomC
Originally Posted by tengarang View Post
Hey Fellers,
Any ideas?
T.
Just my opinion, but I think that as long as you add a ~1 inch extension to the rear tail fin (to help keep the tail blades out of the dirt/grass) and remember to chop the throttle before a crash, the stock TT gears should last a long time. I've only gone through one set of rear TT gears in the last 2 months.
The replacement TT gears seem a bit tougher and less brittle than the original ones that came installed on both my FC's. Maybe Multiplex changed/improved the gear's material slightly? Also a good idea to lube the rear 2 TT gears with a little silicon lube once in a while (~every 25 flights).
Also, if you are still learning to fly, a set of training gear on your skids will help minimise any crash damage.
If you find you cannot manage to keep from continually going though TT gears, then it might be worth trying the belt drive conversion. Just don't expect this to be a cure-all. If you are still planting the tail into the dirt, you may not strip TT gears, but you are going to break something (possibly tail blades and/or tail rotor shaft). Also, belt drives can be more prone to static discharge problems.
Anyway, just my honest opinion.
Cheers,
TomC
