| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
As we've had in all the other forums a chance to share your pictures and your videos, now of your MSH Mini Protos.
To get the ball rolling here is my Mini Protos:
Flybarless / Mikado Mini V Blueline with 5.0 Pro Futaba 6108HS - SBUS Cyclic: JR 285MG Tail Servo: MKS DS-8910 ESC: Stock YGE 60, Soldered XT 60 End Motor: Stock Motor Provided in kit, Scorpion 2580kv Pinion: Stock 16tooth to start with Lipos: 3S - 2250mah Thunder Power 45C Pro Power Main Blades: Thunder Power 325mm CF TR: Stock Provided plastic TR Blades All up weight RTF = 854 Grams (Heavier then I expected), this is FBL, Flybar version would be abit heavier Less weight of pack with connector = 205 grams Dry weight = 649 Grams **Notes** for the JR285mg and other JR Micro servos you must bore out the case hole to use adaptor "A" that are provided in kit, otherwise it's tough to get solid fit and feel on the servos to the frame. Currently I am at 13.5mm out for FBL setup as first trial and only 5.2mm on tr servo horn for distance. I will update later once optimum distances are found on FBL and of course will share my file in sticky thread of sharing files. Here are some pictures for all of you ![]() ![]() ![]() ![]() ![]() ![]() ![]()
...Once upon a time there were Nitros, flybars & frequency pins...Shawn To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by OICU812; 12-05-2010 at 08:24 PM.. |
Nice helicopter.
Avant RC Scorpion Power Systems ThunderPower RC Kontronik Drives |
sick!! i cant wait to get mine in the air next week. I will be going with a mini-v too!! post some vids of that smack crack 3d you do!
MA FURION 6 VBAR!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. MSH MINI PROTOS VBAR |
Some warm weather is needed real bad first my friend!
#6 |
Looks great! I cant tell the difference comparing to regular Protos. Hope to see that heli in air soon.
Come on, Shawn! Yesterday weather was great . -8C and sunny. I had 10 flights on my Logo 400 |
#7 |
I understand what you mean by cold. It's about 65F (18C) here in Dallas today. Much too cold to fly.
#8 |
Nice electronics install, OICU812! Very clean.
T-Rex 450 S, T-Rex 500, Pantera 50, Turbulence D3 (one can dream) |
#9 |
Shawn's builds are always clean. Probably that's why I moved to Logos
#10 |
OICU812 is the Futaba 6108HS S-Bus, i thought it was just the high speed only RX and the 6108SB was the high speed + S-Bus RX ?
The heli looks great how much flying time have you got on her ? and now a dumb question, hows it fly ? ![]() |
#11 |
Yes it is (S-Bus) version, can be used either way, but all mine are all S-Bus now, just cleaner and well easier to. Flown it 3 times now, brutal cold here so not much of an evaluation as my flights are super short. Got the tail locked in now nicely though and almost all the disc stuff done. So first warmer day at least above -15 would be a treat I can work at completing the tune, and go from there. To soon to say to be honest.
#12 |
#13 |
So doesn't that mean you have the R6108"SB" and not the R6108"HS" is that right ?
#14 |
Correct sorry for confusion.
#15 |
Total-G with HS-5065MG on cyclic, S9257 on rudder
Scorpion 2221-12, 16t pinion, CC ICE Lite 50 (2700 rpm governor mode) Edge FBL blades 900g AUW w/ Hyperion VX 3S 2600 pack Wires will be rerouted later once I am happy with the setup. For now, just wanted to see it in the air! Way too cold to fly outside, so only hovered in the basement, so far.
Goblin 700, Protos Stretch, JR E6-550 |
#16 |
PRÔTOS CARBON BRAIN FBL – PRÔTOS STRETCH BRAIN FBL – PRÔTOS STRETCH CARBON BRAIN FBL – PRÔTOS MINI STRETCH BRAIN FBL – PRÔTOS MINI BRAIN FBL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#17 |
#18 |
nice flying!
#19 |
#20 |
