| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#61 |
#62 |
PRÔTOS CARBON BRAIN FBL – PRÔTOS STRETCH BRAIN FBL – PRÔTOS STRETCH CARBON BRAIN FBL – PRÔTOS MINI STRETCH BRAIN FBL – PRÔTOS MINI BRAIN FBL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#63 |
Did you drill the hub out for the bigger main shaft or turn down a solid shaft for the head? I am curious to find out if the spindles will interchange, can an RJX hub be used with the stock MSH spindle and blade grips or would a guy need to use Trex parts to use the RJX hub with plastic grips? I have a hub drilled for the bigger main shaft. I actually drilled this for someone else who wants to use this hub with plastic grips instead of using the whe whole RJX fbl head, he just wants to lower the head and get rid of the big hole in the hub.
#64 | |
I drilled the hub out for the bigger main shaft (really hub was drilled by who sold me it). But I don't now if stock spindle is compatible with RJX hub. Now I can't check it, but tomorrow I will examine this possiblity. However stock spindle is 4mm dimeter and I think RJX spindle is the same too. I use this head because I don't like the big hole in the stock hub as your friend, and use all parts of this head because it combines well by color of all hely. Overall I like more alluminium grips rather than plastic grips. Fabio |
#65 |
-Chris |
#66 |
Great flying and lot of fun!
#67 |
#68 |
icrberg, lets see some video of that stretch mini in action!!
#69 |
New mini upgrades
#70 |
-Chris |
#71 |
these parts are availiable ?
Can't wait for the FBL Hub ^^ |
#72 |
What's the purpose of the metal tail pulley?? Lookin good!
#73 |
Light strong and very nice :-)
For the moment the metal pulley have the same number of teeth. |
#74 |
Me too and for protos 500 ?
Trex-600nsp,Protos,Mini Protos,Trex-450 Pro,Gaui-255,Futaba12fg,Phoenix sim |
#75 |
#76 |
absolutely no!
#77 |
Thats what I like to hear!
So what other goodies are under development? |
#78 |
New stabilizers from Fusuno, with upper part reinforced (looks like these guys are reading the forum).
#79 |
#80 |
Rumor has it Fusuno will be doing neon-colored G10 frames for the Mini P as well...
-Chris |
