| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#21 |
MicrobeastX
2221-1650kv Ice 50 1200mAh 6S Edge 3500G After 4.20mins All temp. good 118F - motor 86F - ESC 91F - Batts. http://rc.runryder.com/helicopter/rr...s=-Welcome.txt Last edited by integy2; 02-17-2011 at 08:21 PM.. |
#22 |
converted my flybarred mini to fbl and it was my first fbl heli and i must say, i thought this was a great heli flybarred but i actually like it more now its fbl....heres my setup
Stock motor and esc align 410m's on cyclic 3500g on the tail sab blades minivbar Voltz 3s 2200mah 45c batteries...
AleeS Rush 750 w/Silverline Logo 600 w/minivbar Synergy E5 w/minivbar |
#23 |
I'm going to use HS-5065mg servos and a microbeast.
My ? is do I put the ball on the servo horn at 15mm from the horn screw? ![]()
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#24 |
I'm using the 410's and I have them at 15mm and it works great, I get the blue light at 6deg
#25 | |
#26 |
Building one now with the following setup
-Stock Motor / ESC combo -MKS 95's on Cyclic -9257 on Tail -Mini Vbar 5.1 pro -Thunder power 3s 65C 2250mah -17t Pinion Hoping to run a headspeed of around 3300-3400rpm. Cannot wait till its maiden, should be good.
John Logo 600, Vbar, Jive 80HV, Pyro 700, BLS. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Synergy N5, OS55, Vbar Mini Protos FBL, Vbar, YGE, 3S TP 65c's. |
#27 |
Turnigy H2218 2100Kv16T
CC Ice 50 Lite Spektrum H3000 cyclic Futaba 9650 tail Minibeast w/Spektrum Sat Turnigy Nanotech 2200 3s/4s Running 2400/3s 3000/4s |
#28 |
After long moaning over decision and deciding that a 600 needs to wait a couple of months, Mini Protos is on its way.
Setup: Mini Protos Carbon kit YGE+Scorpion+SAB MSH41501 Hitec HS5065MG Digital Servo HS5065MG x3 Futaba BLS257 Brushless Digital Mini Servo P-SBL257 Voltz 2200mAh 3S 11.1V 35C Lipo Pack VT220035C3S Waiting for Futaba CGY750 to get back in stock... p.s. can you run BLS257 @ 5.5V?
TDR/VBar Logo 600SX 12s VBar MSH MINI PROTOS/CGY750 |
#29 | |
now MINI V
STOLEN GOBLIN 630 + Icharger 3010 + Meanwell 1500 PS + JR 12X + Honda 2000i Generator. If seen for sale please contact me THANK YOu |
#30 |
Just converted my mini to FBL.
stock motor CC Ice lite 50 esc stretch kit Radix 350mm FBL blades hs-65mg s9257 Microbeast Im loving this thing right now! With the radix 350 fbl blades I even had a perfectly successful auto despite people saying that the single belt system is not suited for autos.
MSH Mini Protos 4s stretch with Beastx! |
#31 |
My Mini Protos Flybarless setup is as follows:
Align 3GX Spektrum AR600 Hitec HS-5065 Digital Metal Gear Servos (cyclic) Align DS520 (tail) Motor, ESC and blades (kit suppled stock) Flybarless hub low MSH41103 I'll try this configuration next week end![/QUOTE] |
#32 |
Occurs to me I didn't share, shame on me
Here goes:Stretch MiniP with lowered FBL hub BeastX Microbeast v2 Scorpion 2221-12 / 14T pinion MSH YGE 60A Cyclic: Savox SH-0257MG Tail: Savox SH-0253 Spektrum AR8000 + 1 Satellite Radix 350mm FBL + stock tail blades Zippy Flightmax 4S 2200mAh 40C I want to change to Microbeast v3 with a DSMX satellite and buy a couple other FBL blades to try out this summer.
Tom To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB Goblin 700 HC3-SX, Quantum 4530-500 Goblin Edition, YGE 160HV-K, WR Super BEC, MKS HBL 950 / HBL980 MSH Prôtos Mini FBL Stretch 4S vBar 5.3Pro, MSH 2010kV, YGE-60A, MKS DS95 / DS95i |
#33 |
Futaba CGY750 FBL controller (I run this on my 550e as well)
Futaba 6203SB receiver (nice and small) Updated low profile FBL Head Hitec 5065s on the cyclic Futaba BLS 257 on the tail Stock motor and pinion (16T) CC Ice 50A ESC EDGE FBL blades
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar Kasama Srimok ECO CGY 750 Voodoo 400 Mini Prôtos CGY 750 |
#34 | |
Just to give you a tip, I've had servo balls at 13.5mm and it gave me too high AFRs (elev was in 70s). 15 mm works much better, aile/elev are in 50-60, pitch is 47. Flies like on rails.
#35 |
My Mini Protos Flybarless setup :
BeastX Microbeast v2 + Satellite with adapter Motor and blades - stock ESC - Kontronik JAZZ 40 (waiting for YGE) Cyclic - Savox SH-0257MG Tail - Savox SH-1257MG Voltz 3S 2200mAh 45C lipos Last edited by Millo; 07-21-2011 at 02:06 AM.. |
#36 |
Nothing fancy but I'll share anyway:
Flybarless stock skyscraper hub ;-) BeastX Microbeast v2 Stock Motor + 16-tooth pinion MSH YGE 60A (stock) Cyclic: JR 287MG Tail: JR DS3500G Spektrum AR6200e EXI FRP 325mm + stock tail blades Zippy Flightmax 3S 2200mAh 25C Wish I would have found the Mini-P a long time ago. It's a great heli.
mini-Prôtos, Prôtos 500, Nano CPx |
#37 |
Mini Vbar 5.1
Short FBL Head Stock Motor and Pinion MSH YGE 60A Cyclic MKS DS95 Tail MKS DS95i Stock Main and tail blades for now but have some Edge FBL blades to use Rock amp 2200 - 2500 3S cells
Goblin 700 V-Bar, Logo 500SE V-Bar, MSH Mini Protos V-Bar, T-Rex 500 V-Bar, E-Flite Blade 130X A few planks |
#38 |
BeastX V2
JR Sat Cyclic MKS DS95 Futaba 9257 MSH 40118-1300kv CC Ice50 CC 10A BEC 6s 1300mah SAB 325 main blade align 450 tail blade and tail fin. |
#39 |
Here is my MiniProtos FBL:
Vbar Mini & DSMX satellite receiver Hitec 5065MG on cyclic Ino-Lab HG-D261HB on tail Batteries 3S 2650 Nanotechs Fusuno yellow racing canopy & yellow tail fins, white Trex 450 PRO landing gear AUW 830g, flies like a dream!
Gaui EP200 FES & V-Bar Mini Gaui X2 & V-Bar Mini MiniProtos stretched 6S & V-Bar Mini Blade 130X & Walkera Mini CP sub-micro FPV setup Last edited by Picofly; 08-22-2011 at 12:10 PM.. |
#40 |
How do you like the nanotech batteries?
