| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#41 |
They are ok but discharge rate could be higher. 2650 mAh Nanotech weighs 215g and gives me 5 min of flying (mediocre 3D). I will try a 45C Voltz battery next.
Gaui EP200 FES & V-Bar Mini Gaui X2 & V-Bar Mini MiniProtos stretched 6S & V-Bar Mini Blade 130X & Walkera Mini CP sub-micro FPV setup |
#42 |
My stretch.
4s 2010kv MSH motor (OEM Scorpion) YGE 60A ESC (bundled with the kit) SK720 FBL controller DS410's on cyclic MKS8910 on the tail 4s 2200 30C Turnigy packs SAB 350mm blades //Dennis.
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720 SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A |
#43 |
My stretch,
Stock motor Stock ESC 3s 2200 - planning to change to 6s and the 1300Kv motor when these die Mini VBar 5.2 Pro Cyclic - MKS DS95's Tail - Align DS 520 SAB 350's Flies awesome!
Logo Xxtreme Mini Protos stretch - Mini VBar |
#44 |
Here the list of my first proper heli (inspired by cruddbucket's video). I know this isn't exactly an entry level heli. Had fun building it though, setting it up right now
Mini Protos Carbon kit Naked MSH41502 MSH41106 Mini Protos stretch Kit with blades MSH51305 Gorilla Tail Blades Yellow MSH41103 Flybarless hub low MSH41112 CNC Alu pulley set MSH41104 Alu CNC tail pulley MSH41014 Pinion 14T MSH41113 MSH Scorpion Motor 1300Kv (6S) MSH41093 ESC MSH by YGE 60 Amp 3x MKS DS95 Micro Coreless Digital Cyclic Servo MKS DS95i Micro Coreless Digital Tail Servo MIK4357 Mini V-Bar Blueline 5.0 Express (upgraded to 5.2 pro) 2x NRG355C-13006 OUTRAGE 5C NRG35 6S1P 22.2V 1300mAH 35C XTREME Futaba 8FG Super 14-Channel SBus Radio Tx Futaba R6208SB 8-Channel 2.4GHz FASST Hi-Voltage Rx Futaba S-Bus Rx Gyro Link Lead P-SBC-LEAD
http://www.xs4all.nl/~rzavelli/rc_heli.txt |
#45 |
Swapped that clunky 8 channel S.Bus receiver for the 3 channel S.Bus receiver I should have chosen in the first place:
Futaba R6203SB 2.4GHz FASST Micro S.Bus HV Receiver
#46 |
My stretch FBL setup:
Stretch MiniP with lowered FBL hub BeastX Microbeast v3 + Satellite with adapter MSH41078 Brushless Motor 2010kv (4S) + 15T pinion MSH YGE 60A (gov. store) Cyclic - Savox SH-0257MG Tail - Savox SH-1257MG Radix 350mm FBL + stock tail blades Zippy Flightmax 4S 2200mAh DX8
Mini Prôtos Stretch 4S, YGE-60A, MSH/Scorpion 2010kV, Microbeast+sat, DX8+Tm1100 Telemetry |
#47 |
Stretch FBL setup:
Stretch MiniP with lowered FBL hub & Flybar swash balls Mini Vbar 5.2 Pro with Satellite MSH 40118 Brushless Motor 1300kv (6S) + 16T pinion MSH YGE 60A (gov. store) 80% TH curve P-Gain .9 I-Gain .03 Cyclic - MKS DS95 Tail - MKS DS95i Edge 325mm FBL + MSH yellow tail blades Voltz 6S 1300mAh 35C
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 (R.I.P.) - All on VBar 5.3 Pro GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster |
#48 |
Stretched with lowered hub
BeastX v3 Scorpion HKII 2221-12 (16T Pinion) Castle ICE 50 JR 285mg Futaba S9257 Radix 350's & KBDD 61mm 3s 2200 packs
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies 7HV, Warp, 3D+ Lincoln To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> |
#49 |
325mm Stock SAB, testing Edge tomorrow
61mm KBDD Lowered Head will be here next week Stock Motor and ESC. YGE Progcard will also be here next week for Gov Store etc. 18th pinion, 90% flat BeastX v3 DS95 Cyclic 8910+ Tail 3s 40C 2200 Big step up from 450 Sport, still have to get used to how tight this baby flies! |
#50 |
Non stretched
Low profile Hub Spektrum AR7200BX MKS DS92 on cyclic MKS DS8910A+ on tail (soon to be DS95i) Edge 325 flybarless main blades Edge 60 tail blades/MSH mini tail blades MSH/YGE 60 ESC 16T pinion 70% - 80% flat throttle curve Hyperion G3 2600mah 3s 35C
mini PROTOS GAUI X2 GOBLIN 500 |
#51 |
Non stretched
Spektrum AR7200BX Hitec HS65HB on cyclic JR DS3500G SAB 325 mains MSH Yellow tail blades YGE 60A 16t pinion 62-70-80% GensAce 3s 2200mAh 25C Low hub ready to be installed after next crash. ![]()
Mini Prôtos AR7200BX Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116 mCPx stretch uHeli head DX18 AMA# 448427 |
#52 |
Here's mine
Stretched tail KBDD tail blades 350mm Radix Blades Low FBL Head YGE 60A esc Governed MSH 1300kv motor Blue Lipo 1300mah 6s 30c CNC servo Blocks Alum pulley guides CNC tail pulley Upgraded servos and FBL unit: AR7200BX MKS DS95/DS95i
William Alees Rush 700-Kosmik 160A + KDE 700XF-495 Synergy N5C & E5-600 Protos 500 Last edited by wbefield; 05-01-2012 at 09:27 PM.. Reason: Setup Change |
#53 |
My first heli build. Completed about 2 months ago. I usually fly at Rancho San Antonio in San Jose, CA.
Mini Protos Kit (3s Scorpion motor, YGE) Spektrum AR7200BX Hitec HS65MG cyclic Futaba s9257 tail 325mm PRO 3D Fiberglass main blades 15t pinion ProgCard, gov store Yellow Fusuno canopy for better visibility Turnigy 2200mAh 30-40C Thunder Power 2250 mAh 45-90C Hyperion G3 2600mAh 35-65C ProTek Prodigy 610 Duo charger Feather Power (feathermerchantrc) 42A 12v PSU DX7s Throttle curve = 65% for ~2500 HS |
#54 |
Here's my setup...
std kit with 2580kv n yge 60a esc(gov store) msh tail blades(yellow) 325 align blades mks ds535 cyclic fut 9257 tail with beastx winmax lipo 2200mah 3s 30c/40c CNC 3rd bearing CNC tail pulley Low fbl hub 15t pinion 68-75% flat curve 8fg soon to upgrade: cnc servo blocks |
#55 |
Mini P not stretched
HS5065mg cyclic Futaba 9257 tail MSH scorpion 2580kv motor with 16t pinion Ice lite 50 no gov 100% flat throttle BeastX fbl gyro Align 325 CF mains ![]()
Trex 450 Pro V2 FB spartan quark trex 250 beastx Fusion 50 beastX |
#56 |
Here's my MiniProtos setup:
- MSH MiniProtos Carbon kit - MSH41093 ESC MSH by YGE 60 A - MSH41078 Motor 2010Kv (4S) - MSH41103 Flybarless hub low - MSH41112 Alu CNC pulley set Mini - 3x TGY-306G MG Digital Alloy Cased Servo 3kg / .06sec / 21g - Align 3g / SAB 325 CF blades - Mini V-BAR |
#57 |
this is for dr dremel :-)
mini Protos stretched but with 325mm Blades Motor: stock 2580kV Pinion: 14T ESC: Align 60A Beast-X V3.0 Cyclic : Align DS 410 Tail: Align DS520 Headspeed: sports flying: 2200 soft 3D: 2550 with old Lipo 2700 with new Lipo videos: http://www.helifreak.com/showpost.ph...&postcount=238
mcpx, T-Rex250, Blade400, HK450GT, mini Protos stretch. my sim: http://www.heli-x.net/ |
#58 |
New MP owner here, bought it used and after rebuild this is my setup:
MP stretch, 345mm blades Motor: Turnigy 2100kV Pinion: 15T stock esc Microbeast v3 Cyclic: Savöx 0261MG Tail: Savöx 1357 As this is a new heli size for me I mostly fly on 3S to get used to it. Also have the stock motor which is waiting for my skills to catch up. Tried 4S a few times, OMG |
#59 |
Hi guys,
was just wandering if the beast x users could share there pot settings. im kind of struggling a little bit on getting it locked in. currently i am on pot 1: -+2 from default pot2: defaults pot3: - 2 from centre. any info would be greatly appreciated! thanks Alex |
#60 | |
Pot1: +2 (almost 10 O'clock) Pot2: default Pot3: default I did have some pitch pump and increased tail precomp but I can't remember the colours sorry. //Dennis.
