| Realtime Video and FPV Discussions of receiving video in realtime from the aircraft |
#21 |
NICE!! I can't wait to see more from you - you were my inspiration for starting my Trex450 FPV and HK600GT builds.
Thanx for registering on FPVLAB - and I'll start a thread over there soon on my 450. This way you can correct all of my mistakes - haha. Sentry
"I Like Waffles" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#22 |
Cheers Sentry and the site looks good.
Regards Liam |
#23 |
what did you use to put your osd in? i used a project box from radio shack for my 500 but havent found one that small for my 450
jbob |
#24 |
It's just a small plastic cabinet box from Maplins in the UK £1.99
#25 |
ok .thanks ill try to look it up.Ive been waiting almost a week for my landing gear from crash9. I dont understand .If you read his message before you buy it says in stock items will ship the next buisness day.and i buy alot of stuff through paypal so? anyway it took almost a mnth to get my tricopter frame from him.So with all that sayn i plan on taken the stuff off my 500 and putn on my 450 just to playn around with.Maybe I wont be as nervous of recking.
jbob |
#26 |
Crash9 is normally great for delivery so I guess it's the postage services. As for switching your gear over to the 450, just put plent of expo in and you will be fine.
Liam |
#27 |
well he wont even email me back.But i need alot of patience i guess,Its just that I dont get alot of time to mess with my hobby and i like to be able to plan.most places i buy from and pay for priority mail .you get a tracking #. what kind of radio do you use?
jbob |
#28 |
I use a 9c with a Thomas Sheerer UHF long range system attached which is good for around 10-20 k.
Liam |
#29 |
Are you using a Long Range RX too? How are you mounting those antennas? I've got a standard range TS RX and that antenna is great! I figured I'd rather slap on a 7W booster instead of messing around with those two huge antennas on the Long Range RX. I know diversity is a really good idea, but I just can't be bothered trying to arrange all of the stuff on a little bird ya know?
#30 |
I'm running the short range antenna as well. I have friends who have had more trouble with string the long range antennas up and I only need a max range of 2 miles.
Regards Liam |
#31 |
Well love flyn my 450 fpv style. But today it got the shakes and crashed while I had my goggles on. Got it rebuilt and replaced feathering shaft and main shaft. Checked the young blood dampners and oiled it all. Heli flies good with some old blades but still have real bad tiny vibes in the new fpv landing gear and tail boom strutts. It was dark but that is what I seen. This is a copterx 450 and wondering if anyone has had this vibes before and what you done to fix them. Take in mind that the whole Heli isn't shaking but it's like you are touching a Dremel to the landing gear and struts . I haven't replaced the tail rotor blades and the main blades are used. Also this Heli after I built it had the shakes like this always causing the screws in the struts to shake out. Heli actualy flew smooth but it has always acted like I had a drimel hitch hiken a ride. Thanks
jbob |
#32 |
How did it track when you put the main blades back on? Also have you changed the main shaft. If I have any crashes now I simply swap out the main shat and feathering shaft for precautions and always check for tightness of the tail belt.
Liam |
#33 |
Replaced main shaft and feathering shaft. Blades don't track to good but with the other blades tracking still had the vibes. Prob a combo of things. Got new blades ordered
jbob |
#34 |
I've never bothered to balance blades but I did have a pair of Align 325 c/f blades once that wouldn't track and gave me really bad vibrations. I then tried to balance them and they were way out so just chucked them away. Hope you can track down what's causing your vibes.
Liam |
#35 |
Thanks man.
jbob |
#36 |
well replaced main shaft,feathering shaft,new blades and even put a new tail assembley on. still not good. The heli flew fine until i put the landing gear on. My thoughts= the extended landing gear i bought is flimsy not like the bigger landing gear i got for my 500,just wondering if it shakeing is causing the whole heli to act up? just flew good before.I dont know? any thoughts?
jbob |
#37 |
It could be high frequency vibes which maybe only visible with your extended landing gear.
I met up with a couple of friends yesterday and had my first proper flight of the year. Took off under goggles and it was so much easier. Flew out to about 700 meters and Rc link was blipping up and down between 99 and 85 so as it was my first flight this year I turned back and did some circuits. I was amazed that she was only pulling 13-14 amps in fff at about 25-35 mph and in a 5 min flight only burned 1000mah from a 4s 2450 lipo, so loads of juice left. Before I took off I had made my mind up to land under the goggles for the first time lols. I came into my approach with a slow forward hover and at 4 foot up hit the throttle hold and gave a slight amount of positive pitch and nearly landed on the Tarmac but just went over to one side by a foot or two and landed upright but in some long grass. No damage and am now fully buzzed up again Lols. Biggest let down after doing all my set up carefully and chatting with friends was that I didnt hit record on my dvr. Oh well at least I live to fly another day. Regards Liam |
#38 |
Rebuilt twice yesterday after two bad crashes. Good thing finaly fixed vibes. Two bad things blades balancing and tail rotor shaft bent. Smooth now
jbob |
#39 |
Well at least you've got it sorted now.
Liam |
#40 |
Long awaited vid, although only short its a taster for the comming weeks. Second time take off and landing under goggles need a little more practise on the landings. As you can see I have zero vibrations in my picture and the only drop outs were when I flew dirrectly above myself. Next project is to build a better support for the Tlrs nr antenna so it doesnt blow about in the downwash, I believe its giving me fluctuations in my signal but I'll soon have that fixed.
Regards Liam |
| Tags |
| trex 450 fpv |
