| Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
#81 |
no problem. when you spool up remember that you should keep the heli at zero pitch for the full 12 sec it takes to spool up then you will hear the rpm stabilize and then you go fly. if this is done in a hover your governed head speed will be lower than expected.
Team Kontronik Team minicopter Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256 Gaui X5 Kontronik 100 lv, Beastx |
#82 |
Success. Works perfectly. Thanks again.
-Kevin
Goblin 700, Trex 450 Pro DFC, Blade 130X, Blade mCPX BL |
#83 |
glad to hear it!
#84 |
Good to hear you got it solved. It had to be programming
Sent from my iPad mini using Tapatalk HD
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6 |
#85 |
At mode4, can i use linear throtle curve 0-100 to get heli in air.
Then switch to 1/2 60-65 with no problems ? ![]() |
#86 |
You have to use flat curves in order to have the headspeed governed.
You can use variable curves but then there's no governor offcourse.. Sent from my iPhone using Tapatalk
#87 |
Another question: if i adjust my endpoints, do i have to redo programming? I've programmed it with endpoints at 100 but would now like to adjust my endpoints.
#88 | |
N: 0-25-50-75-100 Idle1 60-60-60-60-60 Idle2 65-65-65-65-65 I dont want to strip gears when changing N > IDLE1 How safe is the linear curve? |
#89 |
If you want to be sure, try to adjust your normal curve to where you're close to 60% when hovering. This way it won't make a big jump going from normal to idle1. Or do like i did: make your normal curve 0-60-60-60-60. This way you can still take off and land with the throttle stick if you like. But adjust your normal pitch curve so you don't go full negative collective when you chop the throttle.
Going from 60 to 65 shouldn't strip gears imo. Sent from my iPad mini using Tapatalk HD
#90 |
No, don't use that normal curve for spool up. You will first of all confuse the slow start and then the governor. The way to do it is to set TC as a straight across value of say 50% ( not below that for mode4). Plug in batteries with TH on, after initialization and heli ready for take off, move collective to zero pitch, switch out of TH, wait for heli to spool up, it will give a slight kick or audible rpm stabilization when governor is engaged, then just take off normally and fly.
Don't worry about stripping gears when changing flight modes, the ESC will changed to the new headspeed at a rate of about 3 seconds for ramp up. Do not adjust endpoints AFTER programming, it was an idea earlier to try and get TC values to be the same across different radios for comparison purposes. Always program with TC of 0-100% and endpoints at 100%. The HeliJive in fact needs the bottom endpoint to be at the zero value in order for you to program auto bail out if you wish to do that.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC Hyperion 1420, Mega Power Gemini Chargers! JR XG11 Old hand at Planks To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
