Old 02-18-2011, 09:23 PM   #21
akouzmit
Hi Pete,
What is the flight duration in a hovering/sport mode?
I am looking for long duration flights.
Andrei.
akouzmit is offline        Reply With Quote
Old 02-19-2011, 07:24 PM   #22
MotorRotor
Set for a sport flying and hovering mode at a 1500 head speed, you will get over 30 minutes. And if you want more, it is easy to add saddle tanks as the carb in a gasser is pumped.
Leisure-Tech Rep
MotorRotor is offline        Reply With Quote
Old 02-20-2011, 10:24 PM   #23
helimanny
Name:	gasser   and nitro 030.jpg
Name:	gasser   and nitro 031.jpg
Name:	gasser   and nitro 033.jpg
ID:	209639 more photos
its what you learn after you know it all that really counts
helimanny is offline        Reply With Quote
Old 02-21-2011, 05:28 AM   #24
al_voisine
Congrats, that is a sweet looking bird!
AL
Century Predator Gasser NX V2.0 - GY701
Align T-Rex 550E 3GX V3.1
RealFlight 6.5
al_voisine is offline        Reply With Quote
Old 02-21-2011, 12:25 PM   #25
MotorRotor
Helimanny
I just love the paint scheme on that canopy!!! You certainly do have one sweet looking Radikal there.
Leisure-Tech Rep
Old 02-22-2011, 01:20 AM   #26
ngin
JoeyS and Helimanny. Those are very nice canopy indeed.
ngin is offline        Reply With Quote
Old 02-22-2011, 11:08 PM   #27
helimanny
thanks guys ...but i really want to see some more of your birds....come on guys show them off
Old 02-23-2011, 08:24 PM   #28
ngin
I would post mine but it only uses the stock canopy with the decals, so it probably looks like any other that is finished in the same manner. Hopefully this spring I will have time to paint the white F/G one I got awhile back. Then I will post a picture.
Old 02-24-2011, 09:53 PM   #29
nismo200sx16
here is mine. just finished the build tonight. beastx , rjx head , trex 600 le swash , ds610's , ds650 , castle bec pro , align reg for spark , g5 620mm blades . ar7000, hd clutch , 14t pinion.
heli list: 7HV beastx ,WARP 360 beastx, msr , trex 600e rjx beastx , Radikal g20 rjx beastx, mcp x, kk quad copter , and a micro quad.
my videos http://www.youtube.com/user/nismo200sx16?feature=mhum
nismo200sx16 is offline        Reply With Quote
Old 02-24-2011, 11:56 PM   #30
strat1960s
Very Nice!
I'm a week or two behind you. Started putting the tail together last night. Will finish that and possibly the electronics this weekend. Then next weekend I'll work on the radio set up.
Ted
Ted Schubert
I always have fun. Some times are more fun than others.
I can't remember half the crap I forgot.
strat1960s is offline        Reply With Quote
Old 02-25-2011, 07:50 AM   #31
helimanny
SWEET
Old 02-27-2011, 06:43 PM   #32
nismo200sx16
here is a better pic of the rjx head and trex swash
Old 02-28-2011, 08:08 AM   #33
strat1960s
Some newbie questions if you dont mind.
Ok, the manual for the Zenoah motor says do not mount the electronic ignition module on a flat surface due to heat issues. Are you guys mounting the EI unit to the front tray anyways or have you modified the tray in some way?
Also i received my 4.8V RX pack the other day. I see how to connect it to the EI unit, but how do you charge it up? I've got a lipo charger, but I don't have a plug to connect it to rx pack. I guess I could use the charger that came with my DX7, but how do I know how much is going into the pack??
Ted
Ted Schubert
Old 02-28-2011, 02:44 PM   #34
nismo200sx16
I have my ignition spaced up. just velcro on the long edges on the bottom. that keeps it from sliding keeps vibration out a little and also room to cool. then I ran a strap over top to keep it from coming off. I have an adapter for my charger than can charge rx packs. but I am using a lipo on my radikal. you can make a charge adapter from a servo extension. that is if your charger can charge you nimh or nicd pack.
Old 02-28-2011, 03:22 PM   #35
Chrisk7
Here are a few pics of my G 30 I am just now finishing. I have a Hansen G 26, Align 610/650's, Sparten Quark, Maverikk G 5 wide cords, Futaba 72Mhz, and GV 1 gov.
I painted it with rattle cans, Createx airbrush paint and clear coated it with an automotive 2-part.
http://rc.runryder.com/helicopter/gallery/8813/
http://rc.runryder.com/helicopter/ga.../DSCF3799s.jpg
"Don't believe everything you think !"
Chrisk7 is offline        Reply With Quote
Old 02-28-2011, 04:32 PM   #36
Joey.S
I can't see any pictures just a red X.
Radikal 30 SE with Generator,BLS Servos.
T-Rex 450 Sport, HS 65mg Servos
Jr11X Radio
Joey.S is offline        Reply With Quote
Old 02-28-2011, 05:22 PM   #37
Chrisk7
They are showing up on my end???
Old 02-28-2011, 06:13 PM   #38
gooberseptember
Blue square here.
gooberseptember is offline        Reply With Quote
Old 02-28-2011, 07:53 PM   #39
helimanny
still dont see any pics.....
Old 03-01-2011, 10:25 AM   #40
Billme
Nismo,
Looking at your RJX head i see you are using Button head bolts to hold the blade grips on the spindel..From a engineering stand point, I would not run button heads on a spindle...
Billme is offline        Reply With Quote
