Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90 > Thunder Raptor 90/G4
Thunder Raptor 90/G4 Thunder Tiger Raptor 90/G4 Helicopters
Old 02-12-2011, 02:29 AM   #21
maizor
Originally Posted by TCipolla View Post
I realize that's not going to be the final price, but they'd be foolish to charge that much for a kit. That's one quick way to price yourself out of the competition. $1300 for a kit and it better crap gold coins out of the muffler.
Maybe it does its a Thunder Tiger Heli
TDR jive120 4530-540 scorpion CGY750
Raptor 90SE YS 91
Raptor 90SE OS 90 SX BeastX gforce FBL head
Futaba 14MZ Fasst
maizor is offline        Reply With Quote
Old 02-13-2011, 09:30 AM   #22
TCipolla
I honestly hope they don't charge more than 800 USD for the kit. That seems to be the going rate for most of the 90 size birds, like the Rave ENV and Velocity 90. Obviously the Vibe 90SG and Hirobo Turbulence D3 are up near 1500, but that is out of reach for most people like myself.
Tim
TCipolla is offline        Reply With Quote
Old 02-15-2011, 02:30 PM   #23
maizor
Was told by TT europe on facebook that they try to get the E720 in stores by may
This year...
Raptor 90SE YS 91
Futaba 14MZ Fasst
Old 02-15-2011, 09:04 PM   #24
TCipolla
This year...
Nice
Tim
Old 02-16-2011, 10:36 AM   #25
airwolf crazy
This year...
I will believe it when I am buying one.
Christopher
airwolf crazy is offline        Reply With Quote
Old 02-17-2011, 01:09 PM   #26
madxxx
when will the nitro be availeble does any one no de relaese date?
trex 600n pro
trex 700 le
msr
madxxx is offline        Reply With Quote
Old 05-03-2011, 04:42 PM   #27
5.9Cummins
Just read on Thunder Tiger's Facebook page... pending release date in June sometime!
Raptor 30 V2 || Futaba 10C || GY401 || OS 37||
5.9Cummins is offline        Reply With Quote
Old 05-05-2011, 06:35 AM   #28
TTRAPTOR903D
Glad to see them coming out with a new line ... Its' about time.. I like the tail set up and CCPM no question. Beautiful FBL head , but IMHO I looked at alot of pics and the frames dont look like they have enough support. Also did anybody see a pinion support on the Electric? Just looks flimsy to me. It will have to see it in the flesh. Leaning to the Logo 600 instead. Welcome back TT. You WERE first heli.
700N 3GX DFC HEAD OS91HZR HAT SB20FH2
700E 3GX TP5000 45C 700MX CCHV160 EDGE693FBL BECPRO 8V
600E PRO 3GX 450 PRO 3GX KDE BLING MCPX STOCK
RAPTOR 90 3D OS91HZ HAT SB20FH2 JR8917HV AR7100R 8V GY401 TAIL 9254 5V
TTRAPTOR903D is offline        Reply With Quote
Old 05-05-2011, 09:58 PM   #29
Broken
I saw the E720 in person at Toledo, there is a pinion support. I even have a picture with it in. These are incredible machines, maybe more like works of art. Some of the new features are hands down some of the coolest things I have seen in a model helicopter.
Blade 400
Flasher 450 SEV2
Raptor 50 - Just because it smokes doesn't mean it's broke!.
Broken is offline        Reply With Quote
Old 05-08-2011, 02:33 PM   #30
hookmaker
I saw Tom Erik Rolfsson fly it at the Pitchbrother Smackdown this weekend. This is one bad A.. Heli! I'm really excited that TT will be back in the market for real. With this heli they certainly will
Henrik
Hookmaker
Kasama Srimok 90, Kasama Srimok 90E, JR Vibe 90 SG, JR Venture 90, JR Vibe 50 3D V-bar,
Bergen Intrepid Gasser, Vision-SX 90 (x 2)
MSH Protos "Monsterheli", HDX-450
hookmaker is offline        Reply With Quote
Old 05-09-2011, 05:01 AM   #31
maizor
Any pics from the event? So looking forward to build this heli .
Raptor 90SE YS 91
Futaba 14MZ Fasst
Old 05-11-2011, 07:14 AM   #32
spinzer
Will the new 90 electric frame be compatible with existing raptor 90 frame, i'd like to have the option to put in 12s batteries which is a bit difficult with the existing raptor 90 frame
spinzer is offline        Reply With Quote
Old 05-15-2011, 08:17 AM   #33
OverTemp
Originally Posted by EatMorePizza View Post
As TT being my first real Heli many years ago ( piezo gyro rate only days). I can truly say I'm excited about this bird. I love TT and hope they got something here. Curious on how the FBL works or what system. It seems the swash follower is also in control of pitch. Since it's not 1:1 like conventional FBL setups the setup intrigues me.
FBL helis should be 0.6:1.0, not 1:1. It's usually accomplished with the head links sloping outward as they go up. TT gets the ratio from the swash driver/mixing arm, so they can run straight links.
That thing a BBBAAADDDDD looking.
My only question about it... The bell cranks look too long for a good FBL setup. Thats the problem with building helis for both FB and FBL... Hard to get them perfect for both setups. Time will tell, I suppose.
1 - LOGO 600 stuffed with angry hornets
2 - A sad & lonely looking Rush 750 that I can't find time to finish.
3 - 7HV stuffed with over-tired honey badgers
OverTemp is offline        Reply With Quote
Old 05-15-2011, 11:03 AM   #34
Phaedrus
From the photos I have seen it does not appear that the frames will allow conversion from the older Raptors.
AMA Leader Member
Team Futaba
Raptor 90SE/YS91ST - T550E FB - T550E FBL w/CGY-750
Phaedrus is offline        Reply With Quote
Old 05-17-2011, 07:10 AM   #35
gwright
Currently flying a pre-production version and at first sight I thought the same about the arms, but they're really not too long. The ratio...i.e. servo output compared to final output on those arms is equivalent to most. I have another 90 size machine I converted to E a couple years ago, and if I measure the ratios on it, it's the same, but it doesn't look as drastic because both sides of the equation are shorter. If you need say .5 to 1 ratio (just using those numbers as they illustrate well), then you can have 5mm and 10mm on the two lengths, or 10mm/20mm, etc and achieve the same end result. They made everything longer here which enhances resolution and reduces the affect of any play in the linkage over time. That being said, with the enormous balls and links they put on the linkage going up to the swash I don't see how any play will every develop <G>. BTW, it's extremely smooth and quiet, and very very fast.
gwright is offline        Reply With Quote
Old 05-17-2011, 07:48 AM   #36
OverTemp
That's cool... Thought it might be the pics. As long as they have a better ratio than the Trex bell cranks they should be OK.
Old 05-17-2011, 03:03 PM   #37
TTRAPTOR903D
When is it coming?
Old 05-23-2011, 09:35 AM   #38
airwolf crazy
Greetings,
Here are some more pictures of these new helis:
Old 05-24-2011, 05:32 PM   #39
TCipolla
Tower Hobbies has them listed. 999 for the E720, and 1099 for the G4 Nitro. Don't know what that includes though, not to many details.
Tim
Old 05-25-2011, 06:25 AM   #40
airwolf crazy
It appears that it will just be the mech. There will be no ele. or blades included. I hope that the flybarless versions will at least come with the sablizing system. Unless I am missing it on the website Tower Hobbies has not posted any of the other required parts.
Christopher
