| Reflex Flight Sim Reflex Simulator Talk |
I have had Reflex XTR for years on my old WinXP computer and have now gotten a new Win7 computer.
How do I get Reflex XTR installed on my Win7 computer. I have the original Reflex XTR CD and try running the setup.exe, but it fails on installing the "dongle" driver and the program does not install. Is there an update for Win7?
Trex600N & Trex450SE. Dang! Another Radio Glitch! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
try to copy the reflex folder from the old xp computer to the new one and then you should be able to run the program by opening the folder and click on the reflex icon in that folder. directions are on there website.
raptor 90 fbl raptor 50 raptor x50 fbl raptor e620 fbl |
Mini Titan E325 SE, Trex 600LE, AURORA 2.4GHz AFHSS, Phoenix RC, Reflex XTR2. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I tried the suggested link, both EN and DE version, only the RMK is installed, I don't get any exe for reflex itself..
Anyone got the same problem? |
I installed it on my Win 7 laptop using the original Reflex CD..
You **MUST** install the program in compatibility mode. Insert CD, browse to the CD using windows explorer, in the root of that CD is setup.exe. You have to right click on that file, and choose properties. Under the compatibility tab, check off "Run this in compatibility mode for Windows XP service pack 3" Then hit OK. Then right click on the setup.exe file again, and hit "Run as administrator" You should be able to install with no probs. Once installed, find the icon for Reflex in your program menu. Right click on the icon, hit the compatibility tab, and make sure "run in compatibility mode for Win XP" is selected. Should be good to go!!!! |
#6 |
wont work missing dll and the dll wont work with windows 7
#7 |
I dunno then. Works for me.
#8 |
Just installed the above link after download and it appears to work on vista with blue dongle .I will now try to install on my win 7 machine and report back after I attempt to install .
I have been trying to install this program off and on for about a week or so,I have a xp machine that i installed reflex on but when I copied it to a flash drive it would not install no matter what configuration i tried ie admin compatibility mode nothing at all worked so I am happy to report this is a good download and it seems that all the files needed are intact . Eric L. ![]() |
#9 |
Hi I also tried the thread above, but then it only installed the Reflex Monitor and nothing else. Then I run the original cd that works well also, but in the end of installation it ask for usb joystick ( IVOL) connect it but no driver will install, the computer das not recognize the joystick.
This I bought when xp was installed and is ver. 5.03 something for the Realflex XTR from 2008 approx. Joystick is the original reflex XTR iVolbut no driver will install. Please does anyone know, I found this on WEB but please help. Monodrive |
#10 |
