Go Back   HeliFreak > R/C Electronics Support > Eagle Tree Systems
Eagle Tree Systems Onboard data loggers, telemetry, and OSD support
Old 03-09-2011, 09:59 AM   #1
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Default Hyperion phase sensor with eLogger v3?
I'm using a Hyperion phase sensor with my VBar and was wondering if it would work with the eLogger by splitting it out with a Y-adapter.
I know the eLogger brushless RPM sensor will not work with the VBar due to voltage issues, but I didn't know how tolerant the eLogger would be of the Hyperion sensor. I'd rather not attach another sensor to the ESC motor wires.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is online now        Reply With Quote
Old 03-09-2011, 02:48 PM   #2
MrMel
V-BAR Guru
Doubt it, suspect elogger measure raise or drop time of a signal where hyperion is length of square
MrMel is offline        Reply With Quote
Old 05-29-2011, 04:11 AM   #3
ollie2893
Have you tried, Alan? I am interested myself. You were thinking of running the signal wire only? vBar only feeds 3V - not sure whether this is enough for eLogger to register. You sure the vBar cannot tolerate the 5V signal from ET's phase sensor? If so, wouldn't that just be a matter of putting a small resistor into the signal Y-wire? I googled and found on RR that Mr Mel was gonna look into this in his lab but there never appeared a follow-up.
ollie2893 is offline        Reply With Quote
Old 05-29-2011, 08:45 AM   #4
ollie2893
Mr Mel has provided many of the answers over here http://www.helifreak.com/showthread....42#post2969542. Thanks again, Frederik!
Old 11-23-2011, 03:15 AM   #5
fusionsx00
switch the black and red wires.
i like the eagle tree, but what the the hell?
i grabed my multi meter, and yes the black colored pinout per the label on the v3/v4 is power.
so black is +
and red is -
also it would be nice to see a diagram of actual pin values, since red is ground
and not red,black white. which one is positive/power, ground , and signal
ect
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is offline        Reply With Quote
