| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#41 |
I wonder if the 601 is the same as the 401?
Jerry Moore, AMA #878954, IRCHA #2988 Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL Ok, you can fly...but can you HOVER?? To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. KISS = Keep it simple stupid (to maximize fun and reduce costs!) |
#42 |
My gear channel end points are 100%
I can only change the + travel to 150% and it does not change how the Gyro menu works Paul :glasses2:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spektrum DX7 Trex600, Hughes 500D W/Trex600 mech's To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. PicooZ, BCX2 I want to die in my sleep like Grandpa. Not yellin' and screamin' like the people in his car AMA 792875 |
#43 | |
that would mean with the 401 (yes he's talking about the 601 for bigger heli) if we move the end points to 50% that gives us a total throw of 100 so it would be 1:1 for the 401? I think that's right... Jermo
#44 |
PBMAXX will you run an experiment for me please?
Set the travel limits for the channel you are using for the gyro gain to plus/minus 50%, then re-run the settings. If I'm right we'll end up with 1:1 or pretty darn close. for test data use settings of: 50% = 60% = 70% = 78% = 82% = my hypothesis is that the gains will be 1:1 thus the expected results are: (plus/minus 1) 50% = 0 60% = 10 70% = 20 78% = 28 82% = 32 thank you in advance.. Jermo
#45 |
The travel limit for the gear channel will only let me change the positive setting. At 50%
I get 50% = 2 on the GY601 60% = 13 on the GY601 70% = 29 on the GY601 78% = 41 on the GY601 82% = 48 on the GY601 Is not being able to set the negative travel on the DX7 normal?Paul :glasses2:
#46 |
Team Taco VP
Thats about 1.5 and Jermo NO the gain amount is the same movement for a 401 as a 601 man... So it's "about" 1.5 steps. Interesting that channel end points for the gain channelk didnt effect the amount.... I find that strange as if it is already working on 150% anyway... think about it... 150%... 1.5 steps
So Jermo you need to state that for every 1 value in the radio the gain to the gyro is 1.5. so 70 gain = (70-50)*1.5 = 30% gain +/- 1 % Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#47 |
noted..
THANK YOU BUNCHES for the help on this.. Jermo
#48 |
just a note:
when you move the corresponding switch on the travel adjust such as Aileron or Aux2 you can change the negative travel. ONLY the gear channel won't let you change negative travel. Moving the switch does nothing Paul :glasses2:
#49 |
Depending on your radio you may have to change the function of the channel back to it's origional function to change the travel. On the DX7 you have to do this otherwise you have no way to access the negative travel setting.
Jermo
#50 |
Thanks J. I hadn't thought of that. I'm leaving it at 100 for now anyway
Paul :glasses2:
#51 |
First flight just now (in the dark) with the DX7 and the TREX600. Gyro worked great at 74% in the DX7 (35 on the GY601). And with Bob's videos mechanical trim was perfect (nice little double lines on all the trims
Final DX7 settings ended up being Swash 50% Reversed servos 2 and 3 Gyro HH and normal 74% Pitch curves Normal 44-47-50-75-100 ST1 0-25-50-75-100 ST2 0-25-50-75-100 Throttle curves Normal 0-50-80-90-100 ST1 100-95-90-95-100 ST2 100-95-90-95-100 Countdown timer 6 minutes small amount of subtrim on 2 servos... Remember I moved up from a Hitec Eclipse 7. MAN WHAT A DIFFERENCE Paul :glasses2:
#52 |
If you want to set the gyro up the Finless way just set the gear to gear and make the appropriate endpoints on the gear switch. Forget about the gyro menu.
Plus this way you can switch between HH and normal mode.
Jeroen - Just fly it! |
#53 | |
gw |
#54 |
Team Taco VP
On what a 450 or a 600? I can tell you setting up properly for rate mode on a 450 limits your full travel potential in HH mode as you dont have a way to set a different limit on each side of throw. The limit pot is it on a 401. To set up rate mode properly your pitch slider will not be center in the hover and thus your limit pot is lowered so you dont strike the tail hub. This in turn keeps you from going full towards the tail case and thus lowers resolution. This will also require you to lower gain.
On a 601/611 you have a limit value for each side thus this works OK. If the 401 had a limit for each side I would say go for it but it doesnt. Later when your trying to do harder 3D you will find your tail wont hold in all conditions. My 2 cents but trust me you wont see people like the Szabo's etc setting up a 450 like this. Bob
#55 | ||
My question would be why? (remember I'm new), I don't see why you would want to pop out of HH mode randomly. Just seems to make it more complex to feel around the radio for yet another button while flying I used to fly planks and always hated finding Gear and Flaps ..I never wanted to take my eyes off my bird. Jermo
#56 |
yea i agree. i don't intend to pop out of HH mode. i am new also so still wading through the reams of available info. let me go back and re-watch the videos again and see if it sinks in a little deeper this time. :wink:
gw. |
#57 |
feel free to hit by PM or Post, the entire HF community is supportive. Nobody looks down on anyone just because we don't know something or make mistakes. It's part of the process.
The main advantage I see of using the Gyro Sense menu is it allows you to adjust both modes independantly of a switch so you can theoretically change them in flight w/o changing modes/switch position. In addition it allows you to have TWO settings for the mode you want to operate in that's controllable by the flight mode switch (a switch you'll probably use and actually want to change the gain/mode..) so you won't have to hit TWO switches to change gain/setting for the gyro based on flight mode. Seems to me there's a reason for the Gyro Sense menu and why it's layed out the way it is..ie flight mode switch tied to changing Gyro gain. Answer me this: If you do use different Gyro gain settings in Idle up mode is it easier to just tie the gain to the idle up switch or have it on the gear/aux2 switch? hehe....I'm still new but maybe a hot 3d pilot can comment on different gyro settings in different modes. Jermo
#58 | |
I fool around a lot with different setups and I like to be able to switch my gyro in normal mode when I feel like it. I am not saying your way doesn't work, just another approach....... :wink:
#59 | ||
Jermo
#60 |
For everybody that hasn't seen it yet, there is a very good explanation of the 401/DX7 gain setting in this thread in the 2.4 Ghz forum:
http://www.helifreak.com/viewtopic.p...asc&highlight= Just scroll down a bit, kgfly gives a very clear view of the issue.
| Tags |
| dx7, programming |
