Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 03-12-2011, 03:16 PM   #1
jpbarcy
Default Gyro/Governor menu help
I am having issue going into the link to set-up the gyro/governor mode. I cannot open up anything when pluged-in. it won't connect to the computer or the G-view 2, but it can go into the flight control link.... I tried the total g repair software with no luck, I have rudder movement but can't get into the programing to set it up. please help.
jpbarcy is offline        Reply With Quote
Old 03-13-2011, 06:45 AM   #2
Mizark
This may be a silly question but are you moving the plug from the the top of the Total G down to the Gyro programming port?
I am thinkning you may be getting caught as many do & leaving plugged into the FC programming port.
Mizark is offline        Reply With Quote
Old 03-13-2011, 07:28 AM   #3
jpbarcy
Definitely not a silly suggestion however, yes I did move from the FC side to the governor/gyro side. But not able to program via the computer or the G-View on the gyro side... It won't even let me access the menu. Thanks though hopefully someone had this same problem and has a fix to it.
Old 03-28-2011, 05:08 PM   #4
jpbarcy
Had the problem resolved..... got in contact with Brian at CYE and they responded quickly. I finally did a maiden with the total g and was overall impressed, still have to fine tune the system but all is working well at this point.... I would like to thank Brian and CYE for the great customer service and quick turn around time.
Old 04-16-2011, 09:27 AM   #5
scientist
That' what CYE team!
Unmatched after sales support. Keep it up CYE
I really admire you guys,for helping people,and solving/answering any questions may arise.
Rave450 x Velocity50 x Logo600SE x ArducopterMulti.x Gaui 330X x Mikrokopter Hexa x MultiWii x XAirCraft X650V8
scientist is offline        Reply With Quote
Old 03-06-2012, 12:01 AM   #6
ch47c
What was the remedy?
It's not like a death in the family, just get another one.
ch47c is offline        Reply With Quote
