Old 10-28-2011, 09:52 AM   #121
AmmokSkater
MCPreX
Greetz, Ammok
AmmokSkater is offline        Reply With Quote
Old 10-29-2011, 10:57 PM   #122
vlz91
Hey sushka, sorry if you have already mentioned it, but what program do you use?
Your canopies are amazing by the way.
vlz91 is offline        Reply With Quote
Old 10-29-2011, 11:33 PM   #123
RCFlyer88
IM DYING TO TRY THE TDR CANOPY
....but my computer won't open it....
May someone post it as a .jpg? I would really appreciate it.
Thanks a bunch,
Pat
RCFlyer88 is offline        Reply With Quote
Old 10-30-2011, 01:44 AM   #124
CyLLlKA
Hi!
I use 3ds Max, Adobe Photoshop and Pepakura Designer
CyLLlKA is offline        Reply With Quote
Old 10-30-2011, 01:52 AM   #125
CyLLlKA
Thanks a bunch,
Pat
Use Pepakura Designer to open the file
Old 10-30-2011, 05:46 AM   #126
Mek73
very nice any chance that you post this file in pdo format ? and the green trex to ?
Originally Posted by CyLLlKA View Post
Under construction Coming soon
improved slightly. Align style
greetz mek
Mek73 is offline        Reply With Quote
Old 10-30-2011, 01:18 PM   #127
firedragon
firedragon is offline        Reply With Quote
Old 10-30-2011, 07:19 PM   #128
firedragon
Old 10-30-2011, 08:17 PM   #129
RCFlyer88
Unhappy
My problem is I use Mac OSX. Pepukara is Windows only
Any suggestions?
Old 11-02-2011, 04:51 PM   #130
AlexTheRC
what kind of paper do u guys use??
mCP X
Dx6i
AlexTheRC is offline        Reply With Quote
Old 11-03-2011, 03:41 AM   #131
lemaster
i used photo paper for mine
if you can get it to scale properly take it down to one of the photo shops on an sd card
they usually have some good deals
lemaster is offline        Reply With Quote
Old 11-03-2011, 07:25 PM   #132
j8086
I have acces to a big Roland printer/cutter in a sign shop. Can the .pdf be converted to .cdr so i can edit it in Corel draw . Also thinking of the best material to use , maybe relective vinly like the stuff on street signs
j8086 is offline        Reply With Quote
Old 11-05-2011, 06:13 PM   #133
DudeInMyrtleBeach
Does anyone have a black version of the tdr canopy? Something without the colors... The black carbon fiber look is cool...
Thanks to anyone that can help!
DudeInMyrtleBeach is offline        Reply With Quote
Old 11-07-2011, 12:15 AM   #134
Raggedyman
Default mCP X TDR Style Paper Canopy - Black and White
Yes, color ink can be expensive and the whole idea is to make it cheap and something not to worry much about damaging in practice. I really like CyLLika's design of the Henseleit-like TDR canopy at http://www.helifreak.com/showpost.ph...&postcount=120 .
To save ink, the color was removed from firedragon's beautiful design (http://www.helifreak.com/showpost.ph...&postcount=128) except for the green replaced by black of the "comet" (Proheli refers to the splash streaks by that moniker). This left a black and white version to color in. (Sorry, if you want to color the "comet" in, it will also have to be outlined and the black taken out.)
Some of the redundant tabs were removed and some marked with a dot for clarity. The hole marks were taken out as I found my flexed frame canopy pegs were in different places. One can mark the canopy after fitting it to the helicopter and then put the holes in. The Photoshop .psd and .jpg files are attached. I printed it without making the file "fit to scale" as the software requested.
A few tips for those who are thinking to do this and are not quite sure, whether they have the skill for it. It took patience and some dexterity to color in carefully with "super tip" markers, cut the many angles with an X-acto knife, and then very carefully put it all together without tearing, while folding and gluing correctly. Glue the side sections first. Fit the middle piece to one side next. Then glue the other side section to finish.
Additional tools used were a scissor, glue stick, and retracted pen to shape from the inside while shaping the outside of the canopy simultaneously. Some small additional pieces of paper were used to help glue everything in the right place from the inside and reinforce to get it just right. Beside cutting, the knife was also used to apply some extra glue with greater precision than the wide glue stick head allows.
It took me about 4 hours. To me it was well worth it and the effort sweetened the result. I may post pictures, when I have the time and some daylight.
Raggedyman is offline        Reply With Quote
Old 11-07-2011, 12:11 PM   #135
firedragon
do you know a plastic foil with an printable side A4 preferred for inkjet printers and weight lower than 250g/m*m that is for photo paper. mcpx canopy is 2,7g and photopaper canopy is 4.7g so i want an plastic foil printable and to do a canopy near stock weight... thanks
Old 11-07-2011, 01:50 PM   #136
Raggedyman
Default White / Blank Tail Fin Plus mCP X TDR Style Paper Canopy Photos
White / Blank Tail Fin Cover is attached as Photoshop .psd, Adobe Reader .pdf, and .jpg file. Cut over outline to leave blank tail. Color as you like.
As a continuation of my earlier post of the black and white Henseleit-like TDR canopy at http://www.helifreak.com/showpost.ph...&postcount=134 , some photos are attached below including a picture of the tools used to make this canopy (minus computer, and printer).
The canopy in these photos is preliminarily just draped and not attached except for the tail cover glued slightly to the fin at the bottom. One photo shows the overlapping bottom section to give a better idea how to glue that.
Lastly, notice how nicely this design allows for the concave surface of the windows. To create this shape, as a last step just pinch them in a little toward each other.
Further refinements are being contemplated, e.g. going to gray on some of the canopy outlines, in order to minimize these showing up, if not cut out. A straw may also be fitted over the tail boom.
ID:	265270   Click image for larger version
ID:	265272   Click image for larger version
ID:	265273   Click image for larger version
ID:	265274   Click image for larger version
ID:	265276   Click image for larger version
ID:	265277   Click image for larger version
ID:	265278   Click image for larger version
ID:	265279   Click image for larger version
ID:	265281   Click image for larger version
Old 11-07-2011, 02:01 PM   #137
ccnada
Default TDR canopy 1st attempt
This is probably the closest I can get to a TDR and I love it! Now just have to figure out how I can get similar skids!
I used photo paper and before cutting it out I covered it with packing tape. One thousand you's for posting these plans. I was about to cough up the $$ to have the original ones shipped over.
Now if I can only get the paper plans for my Logo and X5! Haha!
ID:	265287   Click image for larger version
ID:	265288   Click image for larger version
ID:	265289   Click image for larger version
ID:	265290   Click image for larger version
X5, DX7se
My son Enzo's - X5, mcpxBL, DX7se
ccnada is online now        Reply With Quote
Old 11-08-2011, 08:19 PM   #138
Raggedyman
Default Color Your Own mTDR-CPX Paper Canopy
This is a continuation of posts #134 and #136. It consist of the following updates:
  1. Color your own template files. Use Photoshop or color with pens. (Attached file types are .psd, .pdf, and .jpg.)
  2. Outlines are muted gray to reduce seam visibility, if outline is not cut out perfectly.
  3. Barely visible gray crosses are introduced as frame peg hole indicators should you wish to use them.
  4. Tail fin cover is included in slightly enlarged form over previously posted one.
  5. Muted Gray letter "mTDR-CPX" center panel file for coloring letters with pens.
  6. Black comet and lettering canopy.
  7. Red window, and black comet and lettering canopy.
Have fun!
ID:	265681   Click image for larger version
ID:	265687   Click image for larger version
ID:	265688   Click image for larger version
Old 11-11-2011, 03:11 AM   #139
CyLLlKA
For those who can work with 3ds Max. Three files with canopy and textures. Use it!
mcpx_stock_canopy
mcpx_TDR_canopy
mcpx_TREX_canopy
for 3ds Max 2010
Old 11-13-2011, 10:34 AM   #140
mepilot
Someone posed this question a couple of weeks ago but I don't see an answer. I really like the hensel carbon mtdr canopy but the file is saved .pdo I and the other guy use an apple computer which is not supported. Can the file be saved if a pdf or jpeg please.
Helicopters just beat the air into submission!
Blade MCPx
DX6i
mepilot is offline        Reply With Quote
Tags
free, hop-up, mcpx, paper canopy, red camo
