Old 06-09-2011, 09:30 PM   #61
Italian Ice
Originally Posted by Finless View Post
All of us (in my area) have removed the tabs to slide the battery back farther to balance the heli... MUCH BETTER!
Bob
WOW...BIG difference! Thanks again, Bob!
Italian Ice is offline        Reply With Quote
Old 07-09-2011, 04:37 PM   #62
FUNBOSS
Originally Posted by BHChieftain View Post
Hi Bob,
Great vids, thanks!
Question on battery install-- are you sure about having the battery stop with the plastic "tabs" on the lipo? I'm able to give them a little pinch and they slide right in so the battery is "flush" to the main plastic header piece-- seems to enable a nice tight grip.
Thanks,
Chief
This is exactly what I do and it's what the manual indicates. Just pinch the tabs and they will lock in nicely. No need to remove the tabs. They're there for a reason
FUNBOSS is offline        Reply With Quote
Old 07-22-2011, 06:44 AM   #63
beamen
Thanks for the great videos Bob!
Would you be up for making a rebuild video how-to for the mCP X? That would be cool and very informative! *crosses fingers*
beamen is offline        Reply With Quote
Old 08-05-2011, 05:15 PM   #64
BigBarryII
Bob
When you set up your 9303 do you use the F.Mode switch to switch Dual Rates as well as flight modes or do you keep the Dual Rates on the corresponding switches? I bound all of my D/R to the F.mode switch once for 3D planes but I cant remember how to do it and the manual does not explain it very well. Can you help?
Fly Low!
BigBarryII is offline        Reply With Quote
Old 08-05-2011, 06:29 PM   #65
Finless
Team Taco VP
I setup normal and idle 1 with no dual rates but 30% expo.
I set idle 2 with 0 expo.
I do not use dual rates I just set the travel adjust per the manual and leave it at that.
Bob
"Don't Taco My Pack Dude!"
Old 08-05-2011, 07:02 PM   #66
BigBarryII
Bob
I went through your video again and it answered my question. Duh! I kept forgetting to set the norm=pos-0, st-1=pos-1, st-2=pos-2 when in the D/R expo screen.
Thanks for the videos
Fly Low!
Old 08-05-2011, 07:06 PM   #67
Finless
Team Taco VP
Originally Posted by BigBarryII View Post
Bob
Yep! I cannot count how many people with 9303's "think" they have expo on when because they did not setup the switch settings they have none
Glad you nailed it!
Bob
Old 08-19-2011, 01:18 AM   #68
vova
Good!
vova is offline        Reply With Quote
Old 09-16-2011, 04:55 AM   #69
Kimono12
Today I picked up my Blade MCPX.
It is slightly larger than the Blade MSR but significantly smaller than the 120 SR
Set up and Binding was straighforward and it seems to be as robust as the Blade MSR
It comes with two sets of rotor blade.. The manual states one set is for high performance Indoor aerobatics and the other is for fast outdoor flight
The fast outdoor flight Blades have a forward facing prong about 1/3 out from the central hub.
I am still fine tuning the pitch curves to my personal preference but can highly recommend it as a next step if you have mastered the MSR or the 120 SR..
It is more stable and easier to fly than a 450 size helicopter.. which would be the next step after the MCPX
It was very windy today so I didn't fly it outside but I will try loops and rolls in the next day or so..
Here are 5 Videos of my first day..
helicopter enters Vortex Ring State.
This last aspect of the MCPX was a surprise.. I have rarely experienced Vortex Ring State with my MSR or 120 SR, but the MCPX will enter it very easily..
In simple terms Vortex Ring state occurs when the helicopter enters the downwash of air produced by its own rotor blades.. Here is the Wiki explanation
Normally if you apply more power and collective pitch the helicopter would climb, but when descending in the Vortex Ring, adding power only INCREASES the rate of descent... due to the extra downwash being produced.
The Blade MCPX makes it very easy to demonstrate this phenomenon..
Kimono12 is offline        Reply With Quote
Old 09-24-2011, 02:19 PM   #70
QYT001
Can someone please share MCPX config file for binding to JRx12?
Thanks in advance.
T-Rex 700N: JR DS8717HV; Vbar 5.3+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG; OS MAX 91HZ-R
T-Rex 700E: JR DS8717HV; Spartan Quark + Outrage BL9188HV; CC ICE HV 160A; RCM-BL700MX (470KV); WR Super BEC
T-Rex 250SE 350Watts
QYT001 is offline        Reply With Quote
Old 09-24-2011, 07:57 PM   #71
bolaurent
There are James Hadley videos on the mcp x Facebook page. I found his instruction on taking off particularly helpful, as a beginner w my first cp heli.
bolaurent is offline        Reply With Quote
Old 09-26-2011, 01:12 PM   #72
bannrikae
Great Vids.
bannrikae is offline        Reply With Quote
Old 10-09-2011, 04:17 AM   #73
jacky65
Hi guys,
Impossible to fly inverted with the DX4e. Binded right as described in Bob video. Once inverted, impossible to hover, maybe a negative pitch or AC problem in DX4e. Crashed each times.
Note the heli flies inverted well with my DX7.
Any idea ?
T-Rex 450 SE V2 AR7000 QUARK S9257 HS-65HB RCE-BL35X 430XL
T-Rex 600 CF DX7 AR7000 QUARK BLS980 BMS-621MG RCE-BL100G 600M
jacky65 is offline        Reply With Quote
Old 10-10-2011, 02:01 PM   #74
stevec
are you getting 0 degrees at centre stick?
are you getting the same amount of pitch down and up?
fold the blades back on themselves so they are parallel, go to full positive, measure the gap then do the same on negative. make sure there is no deflection at centre stick (both blades parallel.
if that is all ok then I'd say there is a screwy mix on the DX4e...
Cheers
Steve
Futaba 8FGS, WK2801.
blade mcpx, hk 450 pro tarot FBL, hk450 in align airwolf body, Trex 250DFC pro, Kyosho nexus 30, Raptor 90 SE Gasser
stevec is offline        Reply With Quote
Old 10-11-2011, 01:37 PM   #75
jacky65
Hi Steve,
Thanks for info.
Positive and neutral and negative pitch seems OK.
You are right, there is a bad mix in the DX4e.
I will use my DX7 with the Blade mCPx and DX4e with an airplane or simulator...
Old 11-04-2011, 04:36 PM   #76
1bad442
what could it be if i have a slight vibration on the heli?
also, do i need to grease the feathering shaft?
1bad442 is offline        Reply With Quote
Old 11-04-2011, 05:13 PM   #77
Finless
Team Taco VP
See the MCPx forum for many convo's and stickies about vibrations and wobble.
http://www.helifreak.com/forumdisplay.php?f=249
As for grease. No you do not need to grease or oil anything on this heli.
Bob
Old 11-16-2011, 07:34 AM   #78
prichard57
I have a brand new MCPX. Since I am not an expert, I of course crashed it a pair of times. However, no big deal. But when I hold it in my hands and look to the blades when increasing pitch and throttle, I see a visible tracking at mid throttle and end throtle. the blades are new, the main axe and the blade axe are OK... when hovering, the helis seems reasonnably stable with no shakes.
Is this a false issue or do I miss a point?
prichard57 is offline        Reply With Quote
Old 11-16-2011, 09:56 AM   #79
bobswika
Default Garage Flying
bobswika is offline        Reply With Quote
Old 11-16-2011, 01:11 PM   #80
Finless
Team Taco VP
Dont worry about tracking as it isnt perfect. However you may want to make sure the spindle is not bent.
Nice garage flying Bob!
Bob
