Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G3
4G3 Walkera 4G3 Helicopter Support
Old 03-20-2011, 05:03 PM   #1
ifly_65
Default WOW tail motor upgrade wires?
I have a double hot rod WOW upgraded 4G3/Nano CP (my avatar). No matter what I do, It wont quite hold 100% throttle. The tail 'wiggle's. Wow suggested soldering directly to the tail motor, but I didnt. Im using the 3 tiny wires off of the motor despite what they suggested.
Should I do this? Has anyone experienced a difference? Will this possibly fix my tail wag?
Trex 450 Pro DFC FL Belt Drive BeastX Scorpion Nexd 6
Gaui X2 MKS DS 95l Spektrum H3020 7200bx Scorpion HSC.
MCP X BL NCcraig Flashed HP05 9t MH. MCP X #2 BL NCcraig Flashed TA 915 9t.
DarkMatterBlades.com
ifly_65 is offline        Reply With Quote
Old 03-21-2011, 03:53 AM   #2
ifly_65
No help for the 'orange headed step child'?
Old 03-22-2011, 01:04 PM   #3
ifly_65
Wow...nothing
Ill take that as a "this thing is a piece of !@#$ and the tail cant be fixed ever".
Old 04-01-2011, 06:27 AM   #4
Dusty1000
That means it can't handle the amount of pitch on the blades. Just reduce the pitch range until the tail does hold at 100% collective.
The tail 'wiggle's.
That could be either too much gain, or too much vibration. The gyros on these helis are very susceptible to any vibration.
The best way is to solder the 3 wires directly to their terminals on the esc.
I would throw away all of the plugs (except the one on the main esc that connects to the lipo) and solder everything directly. That's what I did.
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote
Old 04-07-2011, 04:38 PM   #5
ifly_65
Thanks Dusty. I got it! After working on the head it now flies at 100% throttle.
I used two thicker shims to tighten the play in the grips. It flies great now, better than ever.
Tags
thr
