Old 08-12-2011, 10:04 AM   #201
Finless
Team Taco VP
Originally Posted by checkflag View Post
The links on your original post are dead.
Which links? I just checked my links in post #1 and they are working for me.
Bob
Old 08-17-2011, 10:16 AM   #202
pizmo
Hello Bob,
Will you do a review of the new 450pro 3gx super combo?
Regards, Mark
pizmo is offline        Reply With Quote
Old 08-17-2011, 02:47 PM   #203
Finless
Team Taco VP
Probably not. Align has not asked me to do anything since the 450 Pro came out. Not sure why but honestly I have no desire to buy the V2 3GX any time soon for myself. I am enjoying my Vbar 450 Pro. However if I ever do buy one, trust I will do a video on it.
Bob
Old 09-16-2011, 04:54 AM   #204
Kimono12
he items used in this build are as follows:Align T-Rex 450 SE V2
Align 430XL motor
Align 2100 18C lipo
Spektrum 6100 rx
Futaba 401 gyro
Hitec HS-56 Servos
Futaba 3154 tail servo
I will go through the build a step at a time. I have not followed the manual as the SE V2 comes mostly assembled. I built the model in the most logical manner given what is already assembled.
Kimono12 is offline        Reply With Quote
Old 09-26-2011, 10:56 PM   #205
bekbaev
Default Very nice Video to watch!
Dear Mr. Bob.
I have grown on your build videos over the years. )))
bekbaev is offline        Reply With Quote
Old 10-04-2011, 04:50 PM   #206
chr15tophe
Default Frame issue
Just building the trex450 sport, any tips on getting the frames to sit level on a glass table, as per manual page 9, I've loosened all the screws and slowly tightened them all but it always tweaks when I tighten the motor mount? Should I be concerned about a 1-2mm rock on the front right side, im guessing yes?
Thanks in advance
chr15tophe is offline        Reply With Quote
Old 10-04-2011, 10:19 PM   #207
Finless
Team Taco VP
Whats important is that all the bearing blocks line up e.g. the main shaft goes in smoothly into the blocks, etc. On a 450 with a plastic bottom plate it is no big deal if that is not level.
Bob
Old 10-05-2011, 03:59 AM   #208
chr15tophe
Thanks bob great advice
Old 05-29-2012, 03:32 PM   #209
Immi
Smile Thanx
Thank you Bob
i was rebuilding this week my T-Rex 450 SE V2 after a 3 year break and all i neede was to watch your Videos again,you did a great job back then :-)
Immi is offline        Reply With Quote
Old 12-30-2012, 04:28 PM   #210
Ibrahim Muneer
Default Need Help
Originally Posted by Finless View Post
OK here is a complete overview about the Trex450 "official" V2 heli. I show all the changes good and bad.
This does not show a build video as I think that would be redundant (it's not that different) but does go into all the changes and I do a good overview and build of the major change which is the head and thrust bearings.
If you all feel I need to cover some build things let me know and I will.
ENJOY!
VIDEO -> Align SE Version 2 overview PART 1 (50 Megs)
VIDEO -> Align SE Version 2 overview PART 2 (50 Megs)
Here is the V2 Manual in PDF High Resolution 20 megs
VIDEO -> Align SE Version 2 PDF Manual High Rez (20 Megs)
Bob
Hi Bob, I need your help setting up my HK 450 v2 heli from hobbyking, i need help only with ccpm settings and head assembly correctly. I am having alot of difficulties to set my heli up, because im new to this hobby, i have flown my heli with bad settings but it is so much difficult to fly it with bad settings. Kindly make a build video for trex 450 se v2 with hk t6a Radio plz. or build exactly hk 450 v2 if you can please. so that i will be able to set head rotor assembly perfectly. i have seen your build video of trex 450 se, its great , but it is not helping me with ccpm and head assembly and linkages, may be there are some differences between my heli and the trex 450 se, but not se v2 .
Regards
Ibrahim
Ibrahim Muneer is offline        Reply With Quote
