Go Back   HeliFreak > HF Vendor Support > XHeli/HobbyPartz Support
XHeli/HobbyPartz Support XHeli/HobbyPartz Vendor Sponsored Customer Support Forum
Old 04-03-2011, 03:47 PM   #1
Suburban92
Default blue lipo 3000mah has bad cells? EDITED: ALL IS GOOD
EDITED::: I DRAINED PACK TO MUCH FORGOT TIMER LVC didnt catch it either
I bought 2 blue lipos from you guys they have 5 cycles on them and after todays flight 1 cell does not register on my charger.. on the selection screen but does on the charge screen??
I never go past 66% discharge and only charge them at 2.1 amp on a skycharger also purchased from you..
is there anything you can do???
ID:	219564   Click image for larger version
ID:	219565   Click image for larger version
Raptor 50 w/upgrades; HK500 w/Align parts; BeltCPv2 w/ trex style head; Belt CPX w/Trex style head.
Still learning...
Last edited by Suburban92; 04-03-2011 at 06:12 PM.. Reason: NOTHING WRONG WITH BATTERY OR CHARGER
Suburban92 is offline        Reply With Quote
Old 04-03-2011, 04:05 PM   #2
Suburban92
update after a few minutes on the storage feature at .1 amp this is what it looks like now
hmmm.. I will mark and watch this battery
ID:	219573   Click image for larger version
Still learning...
Old 04-03-2011, 04:46 PM   #3
dannylightning
are you sure its not the charger, did you try other batterys on it..
GAUI X5. = pure awesomeness
youtube.com/dannylightning
facebook.com/dannylightning1313
dannylightning is online now        Reply With Quote
Old 04-03-2011, 05:03 PM   #4
Suburban92
I think the total voltage was LOW on the pack so that the charger thought it was a 5s until I slow slow balanced it at .1 amps all is fine now battery is charging..
I may have missed/not heard my dx6i timer and over ran the battery
Its charging now like normal
Still learning...
Old 04-03-2011, 05:42 PM   #5
Suburban92
WHOA disregard post... the charger says I put back in 3100mah.. plus whatever it took to get the cells balanced between 1st pics and 2nd set
Hope the battery is still good... GONNA GO TRY IT
Still learning...
Old 04-03-2011, 06:09 PM   #6
Suburban92
GOOD NEWS ALL well its good news for me..
just flew that battery and I flew for 7 minutes and came down well balanced at 3.81-3.82 volts per cell maintained good power and headspeed for full 7 minutes!!
these batteries are TUFF
putting it into storage charge now..
Still learning...
