Old 05-30-2011, 09:37 AM   #41
flyride
I have done all the balancing and checking I can think of so now I have parts coming to replace the shaft and hub and thrust bearings to see if it makes a difference even though they are straight. The play you say on the hub where it slides on the shaft should be gone when the set screw is tightened so how will locktite help? Do I check before tightening it or for slight movement after the screw is set?
flyride is offline        Reply With Quote
Old 05-30-2011, 10:30 AM   #42
Mystic3D
Even with setscrew it can wobble.
Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar
Mystic3D is offline        Reply With Quote
Old 05-30-2011, 01:42 PM   #43
flyride
Ok thanks for the info, I just checked mine and it is nice and tight. Entire tail balanced on a high point balancer, rechecked bearings and regreased thrust bearings, checked shaft with dial indicator and it is true. what else to check? I have new shafts, hubs, and blades coming to try that but I am not sure it is the problem also new shaft bearings. What else should I be looking at that? Tail is quite smooth without blades but when blades are installed it vibrates and my vbar picks it up with high vibration.
Old 05-30-2011, 01:51 PM   #44
Mystic3D
Okay I can tell you are OCD, get you some Rotortech 115's and it will go down. Spin it up without mains and tail rod disconnected so you can tell where it's coming from. The F3C boom. Support brace also helped.
Old 05-31-2011, 10:42 AM   #45
flyride
HaHa OCD, ya probably but my main concern is I keep getting mostly high vib and extreme vibe in the vbar instead of good health and it is in the tail. Without blades it has no vibs but with blades it has high vibs. Heli flies pretty good and If I didnt get constant high vib warnings I would just fly it the way it is.
Old 05-31-2011, 02:15 PM   #46
Mystic3D
Yea ditch the blades, green locktite the hub to the tail shaft and the vibs will go down. Been there done that.
Old 06-06-2011, 01:43 PM   #47
flyride
In_to_the_Mystic_2003
Are the bolts that come with the plastic 600n tail ok to use on the 700e or is everyone upgrading them also?
Old 06-06-2011, 04:48 PM   #48
Mystic3D
I did not upgrade the Bolts, but I would recommend upgrading them.
Reason: I want to see if the Plastic Tail holds up with stock bolts, so far 40 flights.
My theory is it's not the bolts that are the problem but rather the metal grips putting undue lateral stress on the bolts. The plastic flexes so not so rough on them.
However I am not willing to tell others not to upgrade them as it is my unproven theory...
Old 07-20-2011, 10:33 AM   #49
zaboaa
Default New heading/ topic
How about adding a topic for Align motor running very hot. I still have not got mine under control, seems to be a common question on this forum. BTW I've messed with the settings on my HV160, adjusted the pinion, and finally put a big vent ( used a screen to make it look good) in the front of the canopy. Still blazing hot when I get down. I'm just living with it, but might be some good inout out there...
zaboaa is offline        Reply With Quote
Old 07-20-2011, 11:17 AM   #50
so-fly
How hot are you talking? Mine comes down warm enough to grab a hold of with ease and im in the blazing 95-100 degree weather of houston
ALIGN TREX 250SE 450SE V2 500ESP 550E 600ESP 700E
NOVUS CP
BLADE MSR BLADE SR 120 BLADE SR
so-fly is offline        Reply With Quote
Old 07-20-2011, 01:49 PM   #51
zaboaa
I live in Dallas ( read the blast furnace ) so I feel the pain. I can't hold my finger on it for more then a second. I do not have anything to measure the actual temp. There several threads on this forum with people having similar problems, I though it would be a good fit for this thread.
Old 07-20-2011, 02:14 PM   #52
so-fly
how much pitch are you using? mine dropped a good 20 degrees after lowering my pitch movements since apparently i have horrible collective management lol
NOVUS CP
Old 07-20-2011, 02:44 PM   #53
zaboaa
+\- 12, I am not exactly great at collective management either. But it even gets hot doing an easy pattern type flight. I'm just out of ideas, I guess I will live with it till the motor burns up and try a different one. It could be it's not getting as hot as I think, but it sure feels hot. I'm sure the vent I cut will be more effective in cooler weather, the current blow torch weather here in Texas is brutal. Also, I run the slant gear with the stock motor mount so can't jack with mesh too much.
Mark
Old 12-09-2011, 08:38 AM   #54
61Espo
Hi..
This Post s AWESOME!!...
I am a new comer to this hobby and Just bought a TREX 700E...Thank You for this Info..IT'S GREAT!!
Steve
61Espo is offline        Reply With Quote
Old 05-22-2012, 05:26 PM   #55
3Diaz
FANTASTIC !!! THANKS !!!
3Diaz is offline        Reply With Quote
