Old 04-11-2011, 03:33 PM   #1
Finless
Team Taco VP
Default REVIEW - of "The Greaser"
Hey all, time for another little review of a tool that either a lot of people don't know about or gets discussed often as to it's purpose and benefit.
I discussed the possibility of a review with Ron Lund on this product due to a thread recently here on Helifreak in the main forum. This post also has some interesting discussion on types of grease to use.
http://www.helifreak.com/showthread.php?t=281909
Ron thought it would be great timing so I have to thank Ron and Heliproz South for sending me a "Greaser" and some grease to show you all how this thing works.
Personally I think this is a great tool and can save you folks on buying new bearings just because they feel rough due to lack of lubrication.
Anyway on with the video review
VIDEO -> Review of the Greaser (120 Megs)
Enjoy,
Bob
"Don't Taco My Pack Dude!"
Old 04-11-2011, 04:32 PM   #2
Jonnyrl1
Great review as always, can't wait to get mine. Your intro was great too btw!
7HV kontronik pyro700-52, ar7200bx
Trex 600EFLPro-BeastX
Trex 600N
Gaui NX4/trex450prov2/mcpx/DX8
Jonnyrl1 is offline        Reply With Quote
Old 04-12-2011, 09:58 PM   #3
ChuckJrster
Bob,
I thought that thing was some kind of "lip stick" container!
Team RCHeliWorkz
ChuckJrster is offline        Reply With Quote
Old 04-13-2011, 07:00 PM   #4
BountyHunter51
Great reveiw Bob!!
I picked up a Greaser from Ron not long ago and I'll have to agree with you that it's an excellent tool. Ron and the crew at Helipros South are first rate for service and advice as well.
Cheers! Mike
Team HeliProz
BountyHunter51 is offline        Reply With Quote
Old 04-13-2011, 07:05 PM   #5
Finless
Team Taco VP
Originally Posted by ChuckJrster View Post
Bob,
I wont say but you should hear what other people thought it was
Bob
Old 04-15-2011, 01:18 AM   #6
Luvmyhelis
Excellent vid, wont comment on your last comment. Lol.
Luvmyhelis is offline        Reply With Quote
Old 04-18-2011, 07:24 PM   #7
CNCjunkie
I've had one of these for a couple of years now and it does the job very well.
One word of caution with small bearings:
If you push down on the tip too hard, you can damage very small bearings and make them notchy. What I do is put very little pressure on the tip just to hold the bearing down and push on the inner cone piece with my fingers to squeeze the grease through the bearing. This method doesn’t put much pressure on the delicate balls and races so they won’t be damaged in the greasing process.
Just another crappy day in Paradise.... Aloha!
CNCjunkie is offline        Reply With Quote
Old 04-18-2011, 08:24 PM   #8
ChuckJrster
Yes, I can only imagine! LOL
Team RCHeliWorkz
Old 04-19-2011, 10:56 AM   #9
Finless
Team Taco VP
Hey! Thanks thats a great tip.....
Bob
Old 04-19-2011, 03:41 PM   #10
Rollingball
I did some Scorpion bearings with the Greaser. It was unreal watching the amount of trash that come out of the oiled bearings.
Trail & Error Repete
Rollingball is offline        Reply With Quote
Old 04-19-2011, 07:23 PM   #11
pinguin
How often do you have to grease a bearing? 50, 100, 150 flights?
So every certain flights I have to disassembled the heli and put the grease on the bearings? I'm not comfortable doing this. I'm afraid on disassembling a perfect flying heli, because when put it back I might miss something that cause problem to it, such as: vibration, different flying characteristic, etc.
I just replace my main shaft bearing on T500 an notice that the old one is pack with lube. What about a smaller size bearing, does it come prelube from the factory? How do I know that the bearing already lube from the factory.
pinguin is offline        Reply With Quote
Old 04-20-2011, 12:30 PM   #12
Finless
Team Taco VP
Sealed or race shielded bearings come from the factory pre-lubed. As to how often you should repack, thats up to the environment and how the bearing is used. I never take apart just to lube (except thrust bearings if it has been a while). If I have something apart I lube the bearings then.
Bob
Bob
Old 06-21-2011, 08:51 PM   #13
dwoodworker
I got mine last year and used it when I buit my raptor and love it. I used lucas grease and it says it can be used on hi speed bearings. seems to work well.
Trex 500 esp,Trex 450 pro, HK450 GT, Spectrum DX8 TX
AMA# 825713
"Just needed to read the instructions"
dwoodworker is offline        Reply With Quote
Old 07-21-2011, 11:04 AM   #14
John A
Your review sold me on this product, I just placed my order for one. Thanks Finless.
John A is offline        Reply With Quote
Old 07-21-2011, 11:25 AM   #15
edhall
Just used mine again last night.
I seem to use it a lot, but I also seem to crash a lot.
New Toys, Logo 600SE, Futaba 18MZ
Align 450 Pro V2, Mini-v
Pantera 55, Pantera XE Elec
Trex 600 ESP, Gaui 425
edhall is offline        Reply With Quote
Old 08-22-2011, 02:40 PM   #16
John A
Well I was rebuilding my head last night and I ran into some bearings 6mm that would go right down the hole while trying to use the greaser on them. So anything 6mm and under you will have to come up with some type of fixture to keep them from doing that if you want to use the greaser on them. Other than that the thing is great at repacking bearings.
Old 03-02-2012, 01:34 PM   #17
edhall
Not sure if anyone will actually see this thread here, but
What grease have people been using in the greaser.
I have been using boca lightning lube which is not real thick, and goes in to bearings very easily, but it's pretty expensive! It doesn't seem to stay in thrust bearings very long though, 10 flights and it's gone from at least the thrust bearings. It seems to stay in shielded bearings though.
Even greasing new bearings, I can go through a decent amount of grease, but when greasing used bearings with black junk comming out, I can go through even more, and I also hate trying to save expensive grease by using a screwdriver or hex driver to wipe the bearing off, and put the grease back into the greaser. It's just plain too much hassel trying to be economical with grease, lets face it, it's messy stuff.
I would love to grease them, wipe them off with a paper towel, hit the insides with a q-tip to get most of the grease out of the middle, then clean them with q-tips and 90% rubbing alcohol when using CA if I am glueing in the bearings to blade grips like I do on a pantera.
I originally bought the grease recommended by Petes Hobbies (the maker of the "Greaser", Union 76 Multiplex EP 2 grease.
U76 at least when it wasn't summer and sitting out in the sun in a pre warmed greaser, would pop the end shields off my bearings in any kind of below 70 degree temp, although the grease did stay put just like Pete said it would.
There has to be a happy medium of price vs staying power on a grease.
What is everyone using out there?
It's time for me to switch.
Not sure if I should move this to a new thread so that it's seen more.
Old 10-01-2012, 10:51 PM   #18
PcChip
necro-bump because I'd like to know everyone's answer to this last question as well!
450 Pro (VWINRC/Tarot/Hobbyking/EXI) Hobbymate HB800 FBL (BeastX v1 clone) KST DS215MG Cyclics, DS520 Tail, Scorpion -8 motor / 13T
VWINRC 550 TT (Robird G31, YEP120HV, 600MX, Align 600DFC Head, DS610 Cyclics)
DX6i
PcChip is online now        Reply With Quote
