Old 10-03-2013, 10:27 AM   #21
WI_Hedgehog
Default Update
Reference here:
http://www.rcgroups.com/forums/showthread.php?t=1862320
But anyway ... Light Cycle Oil as used for fine machinery as Sewing Machines etc. is in my opinion (as a Petrochemical Lab owner) the best for the job. It's light, it's clean, easy to apply just that tiny drop, doesn't collect crud or dust.
Nigel
After years of searching for "the best" lubricant, I have to agree with Nigel. I'm an Engineer whose expertise is not lubrication, and from experience know that when the advice of an expert makes good sense, they're most likely correct.
I skate 100% purpose-build custom quads, and they use bearings that are extremely similar to heli bearings. The suggested lube was Marvel Mystery Oil, which is very light and fast. Runs are fast and hard, generally lasting 4 hours continuous, sometimes 6. The shielded bearings are pulled, cleaned, and lubed after every run. At the advice of another Engineer I changed to a light spray grease with Teflon(tm), and found the grease has an initial "break-in" and then the skates roll faster. The same cleaning schedule was necessary, because the bearings still picked up the usual particulates. After using that for a few months I was not completely satisfied and decided to try the oil again--what a difference! No break-in, super-slippery, and the incredible performance had returned. It has the consistency of sewing machine oil, and the bearings still haven't worn out.
I added a computerized display to my truck which ties to the main computer, and have a full read on what's going on. After extensive research on engine oil I decided to switch to a synthetic 5W-30 from 10W30 and saw an increase in fuel mileage, paralleling the skate bearing experience.
I used to work for a factory that had a sewing department. Industrial sewing machines are run hard and fast, similar to helis. They packed large machine bearings with grease, and lubed sewing machines with sewing machine oil. Having been in the Quality Control department myself, I'm certain the company would have packed the sewing machine bearings with grease or switched to engine oil if it offered an overall advantage. The properly maintained equipment almost never went down.
Relating decades of tangible experiences to Nigel's expert advice, it follows he's correct: keep the bearings clean and lubed with sewing machine oil. We don't use grease to lubricate car engines, or engine oil to lubricate the axles, so why lubricate what is basically a sewing machine with anything but sewing machine oil? Experience has shown me that years back companies employed common-sense, practical-thinking, well-educated persons who got results by using proven methods. Top bearing manufacturers use a light coating of machine oil, and sell the same lube with the instructions to use one drop for ceramics, two for steel, all of which matches with what Nigel is saying, which is an informed, common-sense, practical-thinking, proven method.
Regarding cleaning frequency, "50 flights" seems to be a commonly suggested number by experienced pilots. From my skate bearings (which are still like new):
(4 hours) * (60 minutes per hour) = cleaned every 240 minutes of use
(240 minutes use) / (5 minutes per flight) = 48 flights
So cleaning / lubing every 50 flights should keep the bearings in top shape.
Thank you Nigel for getting to the bottom of this.
WI_Hedgehog is offline        Reply With Quote
Old 10-03-2013, 10:38 AM   #22
RyanW
I really does come down to the function the bearing is playing, doesn't it?
Bearings in the blade grips are highly loaded and never go through one full revolution. Light machine oil isn't what you want in those, as they would be more along the lines of axle bearings on a car.
Motor bearings- I completely agree with the tiny bit of lightweight oil. They are spinning faster than anything else on the heli and need to be as free as possible.
So when it comes down to it, I suppose you could have a different spec for every bearing on the heli, as they are loaded differently and spin at various rpm ranges.
RyanW is offline        Reply With Quote
Old 10-03-2013, 10:40 PM   #23
WI_Hedgehog
Excellent point, and I found the answer somewhat surprising: The bearings are actually high speed due to the rapidly changing blade angles, but undergo frequent start/stop cycles.
http://www.reliableplant.com/Read/528/grease
http://www.nmbtc.com/bearings/white-...brication.html
Summary: Use oil in high-speed, low torque applications, grease in low-speed, high-torque applications.
Although we consider heli parts under high torque, it's relative to the lightweight materials used. Sewing machines are considered high-speed low-torque but produce more torque than helis.
Thanks again for bringing this up, I too wondered about that and you prompted more research resulting in an answer.
Old 12-17-2013, 05:30 AM   #24
JohnTC02
I know this is an oldish thread but does anyone know if the greaser if available in the UK?
I can't find anyone stocking it.
Velos 880 Neo, Logo 800 XX Vbar, T-Rex 800 Pro DFC Vbar, T-Rex 800 Trekker Vbar, T-Rex 700 Pro DFC Vbar, T-Rex 800 F3C Vbar, T-Rex 550E DFC Vbar, T-Rex 500 Pro DFC AR7200BX, T-Rex 450 Sport V2 AR7200BX, T-Rex 250 Pro AR7200BX, VController, DX9.
JohnTC02 is offline        Reply With Quote
Old 12-17-2013, 09:05 AM   #25
Finless
Team Taco VP
I don't know but my Ron ships to the UK?
Bob
Old 12-17-2013, 09:52 AM   #26
JohnTC02
Just had a look on Ron's site and he has them in stock, looks like I'll have to get one from the US.
Many thanks for the reply Bob
BTW, love your vids mate, must have watched them all on here, very helpful
Cheers,
John.
Old 05-15-2016, 07:31 PM   #27
tony#1
I bought THE GREASER some years ago and there was a suggestion that accessories would become available in due course.
Were accessories ever produced?
EDIT Top Dollar paid for THE GREASER. Is there one available anywhere?
Any information gratefully received
tony#1 is offline        Reply With Quote
Old 06-19-2016, 07:17 AM   #28
tony#1
Default Alternative to THE GREASER
As an alternative to THE GREASER (which no longer seems to be available) there is an ABC HOBBY BEARING REFRESHER #69070.
The following link shows cleaning of a bearing for the first minute with the rest of the clip showing the use as a bearing greaser. Try:-
youtube.com/watch?v=RPmkx2AyklY
Old 10-04-2016, 07:44 PM   #29
Falung_69
Thanks Mate
Been looking for The Greaser and low and behold found this
Again
Thanks Mate
Falung_69 is online now        Reply With Quote
Old 10-04-2016, 08:55 PM   #30
RyanW
I have a spare. It might still be new... let me check.
Ryan
Mikado USA, Kontronik, Opti-Power, MKS Servos, VTX
Old 10-15-2016, 03:48 AM   #31
Falung_69
Hey Thanks Ryan
But I have received this Bearing Refresher and used it and it does repack the bearings very well , not much of a mess and really no fuss at all
But I do thank you for offering up your's man
Appreciate it man
