Old 07-04-2011, 03:15 PM   #41
bmclaurin
Ron, thanks, and I agree about the practicality of a perfect 90 degree setup. My post above was intended to be more academic than practical in nature.
And thanks for the setup procedure. I will try this next time around.
Barry
Nitro: Synergy N5c, Synergy N7
Electric: Synergy E7, Synergy E5, Logo 600SX, Henseleit TDR
bmclaurin is offline        Reply With Quote
Old 07-11-2011, 05:03 PM   #42
Mercuriell
Great post ROn - I totally agree it's unnecessary to get too carried away with geomtery to get a well set up heli - can be an interesting mental exercise though and give some insights into rotor head design. I like your practical advice to setup and do a very similar procedure myself.
John
Mercuriell is offline        Reply With Quote
Old 07-15-2011, 03:41 PM   #43
AcidDrink
According to futaba (called them) adjusting max limit in end points adjustment menu is perfectly fine and will not change gyro gain in any way.
Great videos - thanks!
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote
Old 07-17-2011, 01:06 AM   #44
rick.007
Was there a video 5 for setting up the rudder gyro?
rick.007 is offline        Reply With Quote
Old 07-17-2011, 06:08 PM   #45
Mercuriell
NO haven't done one - the principles similar to the cyclic gyro and already covered in the 701 vids but I'm happy to do one if people wish - not much to do really - set directions and play with gain - the integration with the FBL is very good and not really worth tweaking the advanced IMHO
John
Old 10-10-2011, 09:48 PM   #46
Old R/C Aviator
You may now use the PWM to S-Bus adapter and use your Fasst R617FS receiver and servos.
Old R/C Aviator is offline        Reply With Quote
Old 01-25-2012, 05:29 AM   #47
Snake_eyes
Hi, i'm a newbie with CGY750 and I'm using a 10C tx.. it was previously mentioned in this thread that the Pitch/Ail gain and elevator gain could be set up with ch 9/10... could somebody pls post a video on how to do this.. thanks in advance.. i really need help
Snake_eyes is offline        Reply With Quote
Old 01-25-2012, 08:20 AM   #48
HeliBenj
Did you watch the 4th video from John in the 1st post? Should answer your question
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote
Old 01-25-2012, 06:15 PM   #49
Mercuriell
Thanks Ben ! Principles are similar but instead of using the 8FG dedicated ail/ele gain channels you have to pick a couple of unused channels on the 10C and set the 750 to recognise them as gain channels, id start using 2 of the rotary control channels intended for hover fine tuning, Ch 9/10 from memory.
John
Old 01-26-2012, 10:01 AM   #50
frypan
Registered Users ):>
Great man!!!
Your videos are great.
I cant wait to get my CGY flying.
I flew my buddys n5c with it just had to get one
Banging them sticks.
-Dan Duzinski
frypan is offline        Reply With Quote
Old 02-11-2012, 11:09 AM   #51
simonarvestrand
Default no videos
Is there a problem with the video links? removed?
I come to a page the directs me to site root.
i want to see them
simonarvestrand is offline        Reply With Quote
Old 02-11-2012, 11:08 PM   #52
Mercuriell
Links are fine - clear your internet cache and try again !
John
Old 02-12-2012, 03:31 AM   #53
simonarvestrand
Strange, cleaning was the first thing i did, after a computer reboot it worked fine, except for det last clip with gyrogain settings that one is still something strange with.
but i have 3 clips to watch now its a couple of more days before i receieve my cgy750
and this videos helps a lot tanks.
Solved. on my eeepad it worked great.
Old 04-02-2012, 09:07 PM   #54
Zaaaguy72
Are you planning on doing any updated setup videos addressing the updates and tweaking?
Team HeliProz
Zaaaguy72 is offline        Reply With Quote
Old 04-05-2012, 06:02 AM   #55
Mercuriell
Probably not, the updating is pretty straightforward and there is much better expert advice in the 750'forum on tweaking than I could provide!
John
Old 04-13-2012, 09:21 AM   #56
PlaneHazza
Mercuriell, I bought my 750 second hand and don't have a pad. Which double sided tape can you recommend?
PlaneHazza is offline        Reply With Quote
Old 04-13-2012, 09:21 PM   #57
Zaaaguy72
3m double sided tape works great, can get it at any autoparts store.
Team HeliProz
Old 04-13-2012, 09:38 PM   #58
Mercuriell
I agree - I like the grey thin 3M stuff - I think thinner the better as long as you have a reasonably low vibe heli
John
Old 09-25-2012, 06:11 PM   #59
foolforspeed
Did I miss the gov setup video?
foolforspeed is offline        Reply With Quote
Old 09-25-2012, 10:38 PM   #60
Mercuriell
I covered some of it in the GY701 review but I am setting up a GY701 gov in my latest electric heli so I could do some more on gov setup !
John
