Old 09-26-2012, 06:59 AM   #61
foolforspeed
I'll try the 701 vid. Thank you.
foolforspeed is offline        Reply With Quote
Old 11-01-2013, 02:18 AM   #62
billy bob
Is there a vid for gonernor setup in the tx.
The gyro one was very helpful
billy bob is offline        Reply With Quote
Old 11-02-2013, 08:53 PM   #63
billy bob
Don't worry, i figured it out.
Old 06-29-2014, 07:47 PM   #64
lizza
Default CGY750 GYROS dont seem to be working NO compensation
I am REALLY stuck!
Can anyone help me?
After spending dozens of hours trying to set up my cgy750 it appears to be faulty
The rudder gyro is ok.
The ail and ele gyros are not working.I am not sure if they have ever worked?
I have been following the manual exactly and i have watched many videos.I HAVE reset the gyros many times.I have tried everything possible.
It has caused me great frustration as i have never been able to fly the heli.
The problem is because the gyros are not working there is no swash plate or linkage compensation.I will have to return both the sensor and the amplifier.
I have tried both heading avcs.and rate mode with no luck.
I am very disappointed
The tx is a futaba T8F
The rx is an sbus
The heli is a newish hirobo embla
On turning in the rudder servo twitches twice.The swash barely moves on initialization.
can someone please give me a list of every single thing in the cgy750 I need to check.
Lizza
lizza is offline        Reply With Quote
Old 06-30-2014, 09:33 AM   #65
aterren
Default Futaba CGY750 FBL install & review
Have you tried calling Futaba Service? The are usually quite good. It might be worth returning it and getting their confirmation that all is okay (or that something isn't right).
They are well set up for testing their equipment and I have always had good service from them. A phone call first might help them rush the service order too.
aterren is offline        Reply With Quote
Old 06-30-2014, 09:37 AM   #66
aterren
One other suggestion - posting the question in the futaba support forum might garner a bit more traffic and response.
http://www.helifreak.com/forumdispla...243&order=desc
Old 06-30-2014, 04:50 PM   #67
solimon
Originally Posted by lizza View Post
I am REALLY stuck!
Can anyone help me?
The rx is an sbus
Lizza
good!
solimon is offline        Reply With Quote
Old 07-05-2014, 12:13 AM   #68
skytrekin
version 1.4 is very easy to use and the best version yet. It is a simple setup and flys excellent.
For the person having trouble, is the gyro new? If so and you have tried everything, then by all means send it in to get checked out. Possible warranty.
If you are using a 8FG you need to set the radio up properly. I am hopeful you have watched the video's at the beginning of this thread for proper setup.
When you go to Futaba's website their are instructions on Ver 1.4 menu's and what they do. It is very well written.
I have just updated all my 750's to the latest version and it was so easy. All the settings transferred over and just a quick check to make sure everything was still good. It fly's very good with just the stock settings. The only one I changed was the tail piro mode from 3d to sport. I didn't want my tail to piro 3d fast.
Good luck
skytrekin is offline        Reply With Quote
