Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Closed Thread
Old 04-16-2011, 01:23 PM   #1 (permalink)
Default Build Thread - Helibug Core 7 - Discontinued - See final post
Welcome to my build thread for the Helibug Core 7 gasoline conversion
first off what is a Core 7?
Its a gasoline conversion for an Align TRex 700 model. This is the second 700 conversion offered by Helibug and is named for being a more "hard core" gasoline model.
Its typical in that the kit provides frame and certain drive train components and uses the rotor/control components from a std Trex kit.
This one is a little different in few ways:
  • the overall chassis layout is more like the 600 conversion
  • this uses the std Zenoah clutch shoe system. A common complaint for the original 700 conversion was that under heavy flight loading the drive clutch could slip. To my knowledge this is the first commercial use of this clutch system in a model helicopter. I am sure there are folks who have made custom versions for the clutch but not something that is mass produced. As you'll see this thing is quite large.
  • This is the first Helibug conversion that cannot be spin started. It can only be pull started. The stock zenoah clutch design does not support a support shaft that can be used for this.
  • it uses a different gear ratio than the original 700 conversion. It was available in 5.75:1 and 6.76:1. This model is only available in a 6.76:1 and 7.18:1 ratios which are more appropriate for high performance/high rpm motors.
  • it requires the fewest number of donor parts from an original model to complete
Okay time to get started:
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Quick reply to this message
Old 04-16-2011, 02:57 PM   #2 (permalink)
Default Whats Needed
So you need a donor kit, a Trex 700N
The first two photos show the parts you need from the original kit
You need the complete rotor head, tail boom and landing gear
the model I'm converting was configured as an FAI version of the 700. You'll see many of the mixer, t/r control and fin parts from the FAI 700
You also need the canopy, main drive components and the complete control system
This requires a different main gear so you don't need the original
Here's what comes in the conversion kit. Frames, engine mount, cooling deflector, pinion and bolts
You MUST have these parts to complete the model
  • Align Trex 700 Front Frame Mount (HN7084) - 1 pack
  • Align Trex 700 Flange Bearings (HN7067) - 1 pack
  • Align Trex 700 Aluminum Hexagonal Bolts (HN7048) - 1 pack
  • Align Trex 700 Main Shaft Bearing Block from 700E (H70045) - 2 packs
  • Align CNC Main Drive Gear/115T (HN7019BT)
  • Zenoah clutch kit - Daves Motors #GT280
  • Clutch Bell - Daves Motors #86490
Here are some optional parts that I've used in this build
  • Align Metal Elevator Servo Mount (HN7074MT)
  • Sullivan Aluminum Fuel Stopper #478
  • Miniature Aircraft Fuel fittings (1 each 0410-90, 3 each 0405) or equivalent
  • Walbro/Zenoah Fuel Pickup #125-527-1
  • Stens/Echo One Way Valve #610-079
  • Stator Gator #GGS233-RC
  • Servo Nuts (2 required) for pitch/aileron servos
  • RC Booya 7ECM TRex 700 Extreme Canopy Mounts
The TRM VX231RS Motor
The kit requires a RC format motor. Either Zenoah or CY versions can be used.
23cc, 26cc or 29cc versions can be used in stock or modified versions
this build will use the TRM VX231RS motor which is ported for a 7.18 gear ratio
You'll need a muffler
You'll want a muffler, the can muffler on the left is usually included with the motor. It is very loud but will work. I have personally run the other two mufflers. They are:
  • left = zenoah can muffler
  • top = Hatori 956 (the SB12R is the same as the 957 which is a more mid mount)
  • bottom = Zimmerman 2653 s/s
Name:	major parts lr.jpg
ID:	222128   Click image for larger version
Name:	other parts lr.jpg
ID:	222129   Click image for larger version
Name:	kit parts lr.jpg
ID:	222130   Click image for larger version
Name:	required parts lr.jpg
ID:	222184   Click image for larger version
Name:	optional parts lr.jpg
ID:	222186   Click image for larger version
Carey Shurley
Old 04-16-2011, 10:23 PM   #3 (permalink)
Default Basic Chassis Build
First build the central chassis
As with all helibug conversions, you have to install the elevator bellcrank bearings into the frame
Elevator Bellcrank Bearings Installed
in the early kits, these bearings were a loose fit and had to be glued into place. That tolerance has been resolved so now you actually have to trim the holes slightly and press the bearings in.
Next install the bearing blocks. The main shaft blocks are as the original model. The clutch bell blocks are installed so that the "open" side of the block face the top and bottom as shown
Clutch bell top bearing block
Clutch bell bottom bearing block
also install three of the frame spacers into the positions shown.
Align bearing blocks
The clutch bell cannot be installed until the frames are mated however before you fully tighten the main shaft and clutch bearing blocks, temporarily insert the mainshaft and clutch bell into their respective blocks to ensure everything is aligned. Then you can fully tighten the bolts that hold these blocks.
Bearing Blocks/Spacers Installed
the left side frame is ready to be mated with the right frame
Right Frame in position
the right frame fits as shown and the standard 3mm shoulder bolts attach the bearing blocks
Canopy Bumpers/Bellcranks Installed
the top canopy bumpers and spacer are installed along with the aileron and pitch bellcranks
Because this kit doesn't use the stock clutch bell, if you want to use a magnetic governor sensor you're going to have to fashion a way to mount the trigger magnet somewhere. If you intend to use the clutch bell to do that then you'll need to make those modifications now and glue the magnet(s) in place.
Clutch Bell components
these are the parts that make up the clutch bell. At this point the bearing blocks are already installed in the frame.
Position Clutch Bell shaft into bearings
slide the clutch bell shaft into the clutch bell bearings as shown. Note the shape on the end of the clutch shaft
Pinion gear slotted for clutch bell shaft
The pinion gear has a matching notch which will engage the clutch shaft end inside the upper bell bearing
Pinion is retained by s/s bolt into clutch shaft
This s/s bolt connects the pinion gear and clutch bell
Installing pinion
use a medium/green grade of thread lock on the bolt and install it through the pinion into the clutch bell shaft. This bolt CANNOT be fully tightened or it will bind the bell bearings. Tighten the bolt only until it is snug. The thread lock will keep it in place.
Clutch bell assembled
Here's the finished clutch bell assembly. Compared to the clutches we are used to this thing is HUGE!
Replace main gear and reassemble main drive
Install the 115 tooth main gear on the main gear drive assembly and then reinstall the t/r drive gear as shown
Reinstall main shaft/drive gear
Reinstall the mainshaft and main drive gear. Make sure you use the appropriate spacing shim to ensure that the bearing stack is not side loaded.
in the next thread the control system will be installed.
Name:	frame bearings lr.jpg
ID:	222253   Click image for larger version
Name:	bearing blocks lr.jpg
ID:	222254   Click image for larger version
Name:	right frame lr.jpg
ID:	222255   Click image for larger version
ID:	222256   Click image for larger version
Name:	clutch bell parts lr.jpg
Name:	bell position lr.jpg
ID:	222258   Click image for larger version
Name:	pinion slot lr.jpg
ID:	222259   Click image for larger version
Name:	pinion bolt lr.jpg
ID:	222260   Click image for larger version
Name:	pinion install lr.jpg
ID:	222261   Click image for larger version
Name:	main gear lr.jpg
Name:	gear installed lr.jpg
ID:	222263   Click image for larger version
Name:	pinion assembled lr.jpg
ID:	222268   Click image for larger version
Name:	bell bearing top lr.jpg
ID:	222269   Click image for larger version
Name:	bell bearing bottom lr.jpg
ID:	222270   Click image for larger version
Name:	align bearing blocks lr.jpg
Carey Shurley
Old 04-17-2011, 07:34 PM   #4 (permalink)
Default control system
So now that the basic chassis is done its the easiest time to install the electronics and control system.
you'll need two servo nuts for the throttle servo, install it in this direction. You'll have to resize the throttle rod, more on that later
Install the throttle servo first
go ahead and install the radio tray assembly now
Install the radio tray using shoulder bolts and the front canopy mounts
this installs just as it does on the nitro model
Install and connect the pitch servo, only one servo nut required
the pitch servo installs in the same way as on the nitro model. Unfortunately the servo position is slightly different so you'll have to resize the control rods
Install and connect the aileron servo. Only one servo nut required for this as well
the aileron servo also installs in the same way as on the nitro model. Unfortunately the servo position is slightly different so you'll have to resize the control rods
Install and connect the elevator servo
the elevator servo also goes in the standard position. you will have to resize the elevator control pushrods
Install the flight pack switch. Can be installed on either side.
The frames contain cutouts to mount the electronics on/off switch. The switch can be mounted on either side, I mounted it on the right frame side because its the side I've always mounted the switch on my models.
Next thread will cover engine prep and installation
Name:	throttle servo lr.jpg
ID:	222482   Click image for larger version
Name:	radio tray lr.jpg
ID:	222483   Click image for larger version
Name:	pitch servo lr.jpg
ID:	222484   Click image for larger version
Name:	aileron servo lr.jpg
ID:	222485   Click image for larger version
Name:	elevator servo lr.jpg
Carey Shurley
Old 04-17-2011, 08:19 PM   #5 (permalink)
Default Prepare/Mount Motor
okay now lets get the motor ready
if you're going to use a stator gator sensor, you might as well install the pickup in the motor now.
The RC format motor uses a high output fan and the cylinder is well shrouded. However the output air comes out of the cooling shroud at about a 45 degree angle. This can hit the inside of the frames and wind up in the canopy making the electronics hot. So to address this the conversion includes a deflector to better channel the air out of the frames.
Engine Deflector Position
here's how the deflector will be positioned in the cooling shroud
Deflector Installed
and here's how it looks when its installed
Engine Mount assembled
The engine mount is comprised of 4 parts. Because of access once its on the engine, the mount needs to be assembled and aligned before its put on the motor.
Align engine mount
Temporarily install the assembled mount into the frames using the shoulder bolts to properly align it and then fully tighten the bolts that hold the cross mounts in position
Engine mount installed on motor
now you can install the full aligned mount onto the motor
Clutch back plate installed
Install the clutch back plate onto the motor and tighten down the mount bolt
Clutch assembled and installed on back plate
Then you can assemble the clutch shoes on the back plate. This uses two bolts and 4 washers. The washers can only be installed in one order
Motor Installed
slide the assembled motor/mount into the frame and use the shoulder bolts to position and fasten it into place.
Next - install the landing gear
Name:	deflector position lr.jpg
ID:	222507   Click image for larger version
Name:	deflector installed lr.jpg
ID:	222508   Click image for larger version
Name:	engine mount parts lr.jpg
ID:	222509   Click image for larger version
Name:	engine mount alignment lr.jpg
ID:	222510   Click image for larger version
Name:	engine mount installed lr.jpg
Name:	clutch back plate lr.jpg
ID:	222512   Click image for larger version
Name:	clutch installed lr.jpg
ID:	222513   Click image for larger version
Name:	install motor lr.jpg
Carey Shurley
Old 04-17-2011, 08:41 PM   #6 (permalink)
Default Landing Gear/Pull Start
Now that the motor is installed, the bottom frame plate and landing gear can be installed
Install Landing gear blocks
install the two landing gear blocks into the lower part of the frame using shoulder bolts
Remove shroud bolts
now remove the 4 bolts that hold the shroud onto the back of the motor. they will be used in the next step
Install bottom frame plate
position the bottom frame plate as shown and use the previously removed 4 bolts to hold it in place. Don't tighten them yet.
Install landing gear
now install the landing gear as shown and fully tighten the bolts. Now you can finish tightening the 4 bolts that attach the bottom plate to the motor
Align pull start
The model can only be started with the pull starter. You have the option of pull starting from either side of the model. So align the pull started so that it faces the side of the model you want to start it from. I typically use the left side of the model so I have easy access to the carburetor/fuel lines
Motor installed
Here's the finished assembly
Next - finishing up the chassis
Name:	landing gear blocks lr.jpg
ID:	222530   Click image for larger version
Name:	remove shroud bolts lr.jpg
ID:	222531   Click image for larger version
Name:	install bottom plate lr.jpg
ID:	222532   Click image for larger version
Name:	install landing gear lr.jpg
ID:	222533   Click image for larger version
Name:	align pull start lr.jpg
Name:	engine installed lr.jpg
Carey Shurley
Old 04-17-2011, 08:52 PM   #7 (permalink)
Default Complete Chassis
The chassis is almost complete, just a few more steps
Stator Gator Sensor placement
I usually mount the stator gator sensor on the side of the frame. If you intend to use another type of sensor you will have to fashion your own bracket. Since this model uses a different clutch it does not include a place to mount a magnet in it.
Install muffler
Install your choice of muffler now
Install Tail boom assembly
The complete tail boom assembly can now be bolted in. It mounts exactly as it did on the nitro model
Install complete rotor head
The complete rotor head can now be bolted on. It mounts exactly as it did on the nitro model.
Throttle control rod
The throttle rod can be installed. You will have to resize it from the nitro model
Rudder control rod installed
The rudder control rod can be installed. I found that the 700N rod was too long. I used the rudder control rod from the 600n. It fit almost perfectly.
Next - the last steps - the fuel system and the canopy and the model will be complete
Name:	stator gator lr.jpg
ID:	222537   Click image for larger version
ID:	222538   Click image for larger version
Name:	install tail boom lr.jpg
ID:	222539   Click image for larger version
Name:	install rotor head lr.jpg
ID:	222540   Click image for larger version
Name:	throttle rod lr.jpg
Name:	rudder control rod lr.jpg
Carey Shurley
Old 04-17-2011, 08:53 PM   #8 (permalink)
Default Fuel System/Canopy
Next is the fuel system
Right up front I'll say I'm not happy about the fuel tank on this model. If you've read my process for plumbing fuel tanks you'll see I have a very specific process thats guaranteed to work and be trouble free. Unfortunately because of the tank thats used here, the way it has to be installed and the amount of room in the canopy I haven't yet been able to use that process. However what is shown is what comes with the conversion. I will depict it as it should be built using those parts. It is very similar to what is used on a number of the other conversions which have been quite successful work fine.
The kit comes with a 10oz Dubro tank. Unless you are willing to modify the canopy you wont' have much choice but to use it.
Make sure you use the gasoline friendly stopper
First off make sure you replace the black glow fuel stopper with the brown gasoline resistant stopper included with the kit. The black one will eventually melt.
You can still use the walbro felt clunk with this tank. Use a 6" piece of neoprene and connect it to fuel inlet tube in the stopper
Use the Walbro felt clunk
If you've built a fuel powered model airplane, you've built a tank with this type of plumbing. The top two tubes need to be internally bent towards the top of the inside of the tank as they are need to be at the top of the fuel level when the model is upright. The bottom tube is typically the fuel inlet where the clunk attaches internally.
Tank internal plumbing done
Tighten the clunk screw to compress the stopper which will make the tank fuel tight.
Tank positioned for installation
this is the way the tank needs to be installed. Now for the next thing I don't like. In order to get this tank into the frames you'll need to slightly spread them and shove the tank in. It fits VERY TIGHT into these frames. I guess the good news is that you won't need any foam tape to hold the tank once its in there.
Tank final position
push the tank in until the stopper almost reaches the front frame support. Positioning should be as shown
wrap some velcro around the bottom of the radio tray and around the tank and tighten it securely. In the event the tank were to vibrate loose from the frames this will keep it from flopping around
Tank velcro strapping
So now you can finish plumbing.
Tank side plumbing
  • Run a tube from the bottom fuel inlet to the inlet on the carburetor
  • Run a tube from one of the top vents to the fuel return on the carburetor
  • Attach the one way valve to the other tank vent
Carburetor side plumbing
here you can see where the fuel inlet and return connects to the carburetor
Canopy installed - model complete!
Finally the canopy is ready to install. It will fit properly without any modification if you use the stock 10oz tank and position it as shown.
At this point the conversion is complete and the model is ready to setup and fly.
Name:	tank stopper lr.jpg
ID:	222705   Click image for larger version
Name:	tank clunk lr.jpg
ID:	222706   Click image for larger version
Name:	tank assembled lr.jpg
ID:	222707   Click image for larger version
Name:	tank position lr.jpg
ID:	222708   Click image for larger version
Name:	tank installed position lr.jpg
Name:	tank side plumbing lr.jpg
ID:	222710   Click image for larger version
Name:	carb side plumbing lr.jpg
ID:	222711   Click image for larger version
Name:	canopy installed lr.jpg
ID:	222712   Click image for larger version
Name:	final tank position lr.jpg
Old 04-17-2011, 09:46 PM   #9 (permalink)
Default Initial Flight
I did put the initial flight on the model today.
my donor model was in fact a Helibug HB7-RC so practically all of the setup was already done and the motor is already broken in.
model lifted off and everything is working as expected. The clutch engages at about the same point that the Quick or Lynx clutches and much sooner than the stock clutch would.
i'll have more information and video in coming weeks.
Carey Shurley
Old 04-20-2011, 09:53 AM   #10 (permalink)
Registered User
AWESOME Thread Carey!! Thank you for sharing, excellent detail.
William James
WillJames is offline        Quick reply to this message
Old 04-20-2011, 10:26 AM   #11 (permalink)
Thanks, very well done.
How much does it weigh?
fastflyer20 is offline        Quick reply to this message
Old 04-27-2011, 07:17 PM   #12 (permalink)
about 12-1/2 lbs
Carey Shurley
Old 04-27-2011, 07:23 PM   #13 (permalink)
Default Fuel Tank - Another Option
Earlier in the build thread, I showed how the stock fuel tank is supposed to mount and be plumbed. I also indicated I wasn't happy with how it works. Its only 10oz, it doesn't fit well into the frames and can only easily be plumbed one way.
So now here's my option. I have a simple way to plumb tanks, I do them all the same way as I posted here:
Fuel Tank Plumbing - My Way
Here's how to apply that setup on this model:
First turn the tank 90 degrees, or on its side. Doesn't matter which side. Drill it to put the optional connectors in as shown. Use foam tape and velcro to secure it. Its going to have to mount slightly further forward than with the original setup. This will require canopy mods - see those in a minute.
Fuel outlet locations
Here's the tank vent, fill and return connector
Fuel inlet location
Here's the fuel pickup
Required canopy mods
To make this work, here's how you have to mod the canopy
Here's the result
Here's how it turns out. You can see the fuel level and the best part is that now you can use a 10, 12, 14, 16oz or larger fuel tank
The Bottom Line:
This optional mount may or may not be something you like. It is effective however.
Name:	option fuel tank front lr.jpg
ID:	224715   Click image for larger version
Name:	option fuel tank side lr.jpg
ID:	224716   Click image for larger version
Name:	canopy mods lr.jpg
ID:	224717   Click image for larger version
Name:	canopy mod mounted lr.jpg
Carey Shurley
Old 05-17-2011, 08:48 AM   #14 (permalink)
How is the zimmerman pipe? is that better than hatori?
Which one is the loudest between those 3 pipes?
Nice Thread anyway, keep updating
dar61 is offline        Quick reply to this message
Old 05-17-2011, 12:41 PM   #15 (permalink)
By FAR the stock can muffler is louder than just about anything else you can buy!
The zimmerman would be second and the Hatori is the quietest
I'm working on some testing between the stock can, Hatori, Zimmerman 2653, RJX and Century Torpedo for a specific set of high performance circumstances. When I'm done with that I'll publish a thread.
Carey Shurley
Old 05-18-2011, 09:29 AM   #16 (permalink)
Default Battery options for Trex 700-Core7
Need some guidance on the battery options for Trex-700-G core-7 build.
So far the electronics I have are 4xDS610s, BLS251, GY520, Rx JR790 SPCM (not 2.4G).
Should I use the Align regulator or CC or Western Digital or any other? I would like use the 6v circuit for all electronics, I heard BLS251 works fine with 6volts, everything else I have is rated for 6volts, except JR 790 receiver , dont know the voltage specs, cant find it anywhere.
I also fly Trex 450SE, so have bunch of 3S LIPOs ~2200mah, I would like to use these batteries for the 700-G, if possible.
Ideas?
jonB is offline        Quick reply to this message
Old 05-18-2011, 04:49 PM   #17 (permalink)
the bls251 is not rated for use at 6v. other people may be doing it I'm just not aware of it. I run mine at 5.2v
I've been using Fromeco regulators lately without any failures, both the Arizona and Sahara. The Arizona is big but includes a step down. The sahara would requre an additional stepdown for the rudder like the Perfect Regulator setup. I've heard good things about the Perfect regulators but haven't run them.
I run 7.2 v setups with regulators on everything now.
Carey Shurley
Old 05-20-2011, 10:09 AM   #18 (permalink)
So just talked to Ali at Helibug, due to strong customer feedback he's decided to discontinue this model and instead offer the h/d clutch upgrade for the existing HB7-RC 700 conversion thats been offered for a while.
He's offering a pretty nice replacement plan for Core-7 owners.
I'll leave this up for a bit but look for a new build thread for the HB7RC with the h/d clutch upgrade.
Carey Shurley
Closed Thread
